Latest post Wed, Aug 23 2006 4:55 AM by spectell0. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Dec 6 2005 5:22 PM
    Create a countdown timer!
    Does anyone know how I can make a timer to countdown from 30 seconds to 0 seconds without having to make 30 different titles?
    Dell Workstation: 2.5 GB RAM, ATI Radeon, 550GB hardrives. Avid Xpress Pro HD Studio Essentials: Avid Xpress Pro HD, Avid FX, Avid 3D, Avid DVD, Pro Tools... [view my complete system specs]
  • Tue, Dec 6 2005 5:30 PM In reply to
    • HamNCheese
    • Los Angeles
    • Posts 360
    • Points 5,360
    Re: Create a countdown timer!
    30 different titles is the way to do it.  But for me, it's so fast to do it's not even an issue.  Probably less time than it took to type this question!  Then once done you save the sequence and you can use it again in future projects.
    freelance, I work on a lot of systems [view my complete system specs]
  • Tue, Dec 6 2005 6:35 PM In reply to
    Alright    can't i save a title that is 30 and save and reopen it and change it to 20 so it won't change position
  • Tue, Dec 6 2005 6:37 PM In reply to
    • HamNCheese
    • Los Angeles
    • Posts 360
    • Points 5,360
    Sure, that's the way I do it.  When you get to the single digits though you will have to re-center it.
  • Tue, Dec 6 2005 8:59 PM In reply to
    • erik1185
    • Maryland
    • Posts 1,045
    • Points 12,865
    I wonder if there is an easy way to do this in Marquee?
    Maybe write a script that will do this?
    Late 2013 MacBook Pro, 2.4 GHz Intel Core i5, 8 GB RAM, Intel Iris 1536 MB Graphics, MacOS 10.12.2 [view my complete system specs]
  • Tue, Dec 6 2005 9:30 PM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,677
    • Points 20,435
    • Moderator: MCA Mac
    You only need to create it once, then put it on tape and use it again and again.
    We tend to make new countdowns every few months, it's one of the things we do when we're bored with no work to do.
    HP Workstations with MC 8.4 64TB EditShare XStream Storage [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Tue, Dec 6 2005 9:34 PM In reply to
    • HamNCheese
    • Los Angeles
    • Posts 360
    • Points 5,360
    You don't even need to put it on tape to reuse it again.  Just save it as a sequence and do a "re-create title media" next time you need it.  Then if you want, each time you use it again you can just stick it over whatever background shot goes with your project.
  • Wed, Dec 7 2005 9:19 AM In reply to
    • DylanReeve
    • Posts 1,677
    • Points 20,435
    Well, yeah, or you could export a clip, or mixdown.
    We use tapes because we use the same countdowns in the linear suite, Flame, Infinity, Avids and anywhere else we can manage. If I'm making one in Avid, I quite like the highlight-a-number approach..
    I have all numbers in a row... 10 9 8 7 6 5 4 3 2
    And I make two copies of the title, one 50% grey, one 100% white. Then I keyframe the crop of the white one to reveal only th necessary number.
    Variations on this that I've done are to have another line below of frames. And also another line above of tens.
    I think I'll make an abacus countdown sometime soon.
  • Wed, Aug 23 2006 4:55 AM In reply to
    • spectell0
    • Joined on Tue, Apr 4 2006
    • Posts 48
    • Points 535
    Thank you.  Made it on a half circle/elevator style in photoshop and imported/ looks cool.
