Latest post Mon, Oct 29 2007 4:27 PM by LewS. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jun 26 2007 5:10 AM
    • Director
    • Joined on Sat, May 27 2006
    • Posts 7
    • Points 75
    AL 7.2 and nvidia GTS8800
    Can anyone confirm this card works OK with AL 7.2?
    If not, what should I be using in a new system?
    Putting together Q6600 cpu, 4gb ram, P35 mobo, XP pro.
    Cheers
  • Tue, Jun 26 2007 12:51 PM In reply to
    • LewS
    • West Palm Beach, FL
    • Posts 9,971
    • Points 128,645
    Re: AL 7.2 and nvidia GTS8800
    No. There are issues with this card. It is being worked on but the resolution may take awhile yet. I would recommend you go with an ATI card at this time. Do a search of the forum, there are many threads on this.
    LewS
  • Wed, Jun 27 2007 3:36 AM In reply to
    • Director
    • Posts 7
    • Points 75
  • Sun, Oct 28 2007 10:15 PM In reply to
    • Director
    • Posts 7
    • Points 75
    Does anyone know if the new 8800 GT card has the same issues as the GTS and GTX?
  • Sun, Oct 28 2007 11:05 PM In reply to
    • editzz01
    • Joined on Wed, Nov 23 2005
    • Montreal
    • Posts 730
    • Points 8,725
    I believe that there are issues with all of the 8800 series of cards. Liquid really does work well with ATI cards. It also works well with the 7 series of cards from Nvidia, along with the Quadrofx cards (I have the Quadrofx 3450)
    Dual 3.2 Xeon 2.0MB L2 Cache Tyan Thunder i7525 800 FSB 2 gig DDR II PNY QUADROFX 3450 74 gig, 10 000 SATA WD Raptor OS Drive 4 x 300 gig SATA Seagate... [view my complete system specs]
  • Mon, Oct 29 2007 4:27 PM In reply to
    • LewS
    • Posts 9,971
    • Points 128,645
    As Mark said, there are issues with those nVidia cards. The problem is complex. It appears the Liquid 3D render engine needs to be re-written to work correctly with those cards. At the moment, there are also no good workarounds. I cannot give you a date when the patch will be released to fix this but Munich is working on it right now so hopefully soon. At the present time, you should avoid these cards with Liquid.
    LewS
