Latest post Tue, May 6 2008 11:46 AM by Fairmorn. 9 replies.
Page 1 of 1 (10 items)
  • Sat, Jun 2 2007 8:32 PM
    • Maxim
    • Joined on Thu, Dec 21 2006
    • Posts 20
    • Points 220
    green line in avid xpress 4.6
    Hi all,
    I really need your help on this one. When exporting in avid xpress 4.6 a green line is showing in the top of the screen. I have to finish a production this week for a customer, so does anyone has a solution to this problem, cause this problem is really bothering me.
    Thanks!
    Maxim
    hp xw4300 Nvidia FX 1400 2 gb RAM avidxpress pro v5.7.2 WiN XP SP2
  • Sat, Jun 2 2007 8:34 PM In reply to
    • Maxim
    • Posts 20
    • Points 220
    Re: green line in avid xpress 4.6
    Sorry,
    I meant xpress 4.8 Smile [:)]
    • Maxim
    • Posts 20
    • Points 220
    Sorry,
  • Sat, Jun 2 2007 9:14 PM In reply to
    • camoscato
    • Posts 4,120
    • Points 49,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Maxim,
    Here are the results of a forum search for "green line export".  Hopefully something in there will get you going.  If not, when you come back tell us what your system specifications are (processor type & speed, amount of RAM, type of audio & video cards).
    good luck,
    Carl
  • Sat, Jun 2 2007 9:33 PM In reply to
    • Maxim
    • Posts 20
    • Points 220
    Hey Carl,
    i've already read the extensive literature on the green line problem, but can't really see the solution.
    My system specs:
    • HP xw 4300 workstation
    • multi processor (2) Intel Pentium D CPU 3,2 ghz
    • 2 gb RAM
    • NVIDIA quattro fx 1400
    • realtek High definition audio
    Hope you can help me out,
    Maxim
  • Mon, Jun 4 2007 8:58 PM In reply to
    • Maxim
    • Posts 20
    • Points 220
    Hi Carl,
    I tried the different work arounds offered at the moment. Nothing works so far. What can I do to get a satisfactional result, because I really can't show these exported images with a green line on top to my costumers.
    Thanks already for the help.
    Maxim
  • Mon, Jun 4 2007 9:15 PM In reply to
    • camoscato
    • Posts 4,120
    • Points 49,425
      Moderator: Meridien
    Hi Maxim,
    If you've read through all the posts and none of the workarounds is solving the problem (not even cropping the top few lines?), I don't know what to tell you.
    I believe the problem was fixed in Xpress Pro, but Xpress DV is no longer being worked on.  Sorry I don't have better information for you.
    good luck,
    Carl
  • Tue, Jun 5 2007 2:21 PM In reply to
    • Maxim
    • Posts 20
    • Points 220
    I consider cropping not really as a solution, since we shot in 4:3......
    Man, I can't believe Xpress is sold as a finished product, when these kind of issues are popping up..
    Thanks anyway Carl,
    I'll contact my reseller/Avid...
    Maxim
  • Tue, Jun 5 2007 2:37 PM In reply to
    Maxim:
    You're only cropping out a few lines at the top (maybe 6 at the most), it's well behind the Action Safe area for television.  In other words, it's not noticeable.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Tue, May 6 2008 11:46 AM In reply to
    • Fairmorn
    • Joined on Thu, Jan 10 2008
    • Posts 18
    • Points 200
    Look at this topic:
    http://community.avid.com/forums/t/29570.aspx?PageIndex=1
    may be it will help you
