Latest post Sun, May 20 2007 8:28 PM by marekbudzynski. 5 replies.
Page 1 of 1 (6 items)
  • Thu, May 17 2007 3:30 AM
    Please forgive me ...I searched without an answer...can FCP and AVID MC 2.7 coexist
    on the same CPU?  Avid is telling us no but that seems nuts.
  • Thu, May 17 2007 3:44 AM In reply to
    • kmac
    • Auckland New Zealand
    • Posts 113
    • Points 1,340
    Re: Please forgive me ...I searched without an answer...can FCP and AVID MC 2.7 coexist
    check this out... http://www.avid.com/exchange/forums/thread/105067.aspx
    iMac 27inch Retina 5k, 4GHz Intel Core i7, 32 GB Ram, AMD Radeon R9 M395X OSX 10.11.13 Media Composer 8.5.3 with Symphony, DaVinci Resolve 12.5 Blackmagic... [view my complete system specs]
    Ninety thousand frames per hour
  • Sun, May 20 2007 2:02 AM In reply to
    anyone else...this doesn't seem definitive.
  • Sun, May 20 2007 3:05 AM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Jacksonville, FL
    • Posts 1,442
    • Points 18,630
    Install them both and find out.  There was a problem where FCP would act up if the Avid codecs were installed (installing Avid installs them), so maybe that'll be a problem.  Otherwise, install both and try it--if they don't run, uninstall and pick your editing poison.  Ghost your drive before hand in case you run into problems.  It'll be faster than waiting for "definitive" reply.
    Michael.
  • Sun, May 20 2007 5:25 AM In reply to
    I'm running them both, w/no observable deficiencies.  At least on Avid.  I can't say I've used FCP for more than 10 times or so.  I really air out the Avid 2.7, so I can say it's solid w/the FCP install.   Now that I've received the FCP w/Motion 3, I'll be using that more.  Motion 3 changes everything again. Well, that and Color.
    No wait, this is an Avid board.  Pretend I didn't type that...
    2 systems: Mobile: 15-inch Macbook Pro Retina 2.6GHZ i7 w/16 gig RAM, 1TB SSD, OS 10.12.6 running MC 2018.6 Legacy - MC v5.5.4, OS 10.5.8, QT 7.6, on Quad... [view my complete system specs]
  • Sun, May 20 2007 8:28 PM In reply to
    I've got both on the same cpu and I haven't noticed any difference. They both seem to work fine even if they are both running at the same time. That is if I'm doing a major export or render on the Avid I can still edit on FCP with Avid working in the background. I would suggest that you keep your media on separate drives though.
    System 1: Macbook Pro Retina2.6Ghz i7 OSX 10.11.6 8gigs RAM Nablet 4.5.5 Media Composer 2018.11 [view my complete system specs]
