Latest post Tue, May 13 2008 5:41 PM by fiendish. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Apr 26 2007 10:36 AM
    • balue
    • Joined on Thu, Apr 26 2007
    • Posts 2
    • Points 40
    Super Angry [8o|] import tiff sequences into avid
    hi there!
    has anybody a tip how to handle multiple image sequences on the media composer?
    the problem is that i will receive between 100 and 200 image sequences in the same amount of folders on an external hard disk. the media composer is not very convinient when it comes to the import proces. i don't want to sit next to the computer for hours importing sequence after sequence! any help on the issue?
    it also bothers me that MC goes crazy on large image sequences (more than 2500 frames!) are they working on that?
    regards
    balue
  • Thu, Apr 26 2007 2:32 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,200
    • Points 50,435
    Re: import tiff sequences into avid
    In the options section of the import tool, highlight "autodetect sequential files".  Then select all the appropriate files in the import tool brouser and you're off and running.
    Media Composer Adrenaline PC v 2.7.7 Newscutter Adrenaline PC v 6.7.7 Pixelan SpiceMaster 2.0 plug-in Sapphire 2.05 plug-in (single platform) Windows... [view my complete system specs]
  • Thu, Apr 26 2007 3:37 PM In reply to
    • DRW
    • Joined on Wed, Nov 9 2005
    • TORONTO
    • Posts 547
    • Points 6,595
    Actually you only need to hilight the first numbered file, MCA will find the rest.
    =DRW
    MCA HD v 2.8.1 WINDOWS XP and MC v 12 Win 2k connected to FACILIS TERRABLOCK 3.6TB shared storage [view my complete system specs]
    1-800-IMRENDERING
  • Thu, Apr 26 2007 3:44 PM In reply to
    • DRW
    • TORONTO
    • Posts 547
    • Points 6,595
    balue:
    So you are going to have 200 different folders each with tiff sequences in them? Youch, that is a lot. Not sure there is any faster way to do it than to: 1. open each folder and highlight the first frame and import, 2. repeat until tired. Is there some other NLE that you have used that can manage a task like this better? Just curious.
    =DRW
    1-800-IMRENDERING
  • Thu, Apr 26 2007 4:19 PM In reply to
    • Neil J
    • Posts 130
    • Points 1,590
    Try this out. A tip from the redoubtable Mr B Sutie - it works a treat:
    If you are using a numbering system like XXSC001_001.tga (where XX is the project name, SC001 is scene1 and the first frame is 001.tga) then search the folder containing all scenes for *001.jpg   This will find the first frame of every shot.
    Select all in the search window, and drag them to a bin, sit back, go for a beer, no more select / point click/ select /point click etc etc . . .
    from a thread here:http://www.avid.com/exchange/forums/thread/164515.aspx
  • Fri, Apr 27 2007 8:54 AM In reply to
    • balue
    • Posts 2
    • Points 40
    hi neil!
    thanx! brilliant answer! usually i come up with such "fixes" by myself! :)
  • Tue, May 13 2008 5:41 PM In reply to
    • fiendish
    • Posts 195
    • Points 2,355
    Excellent find! This should be a sticky
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
