Latest post Thu, May 15 2008 3:17 PM by echo bush. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Apr 25 2007 9:45 PM
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 421
    • Points 5,125
    Export sequence as targa files
    I have a four minute sequence on a Symphony Nitris version 1.01 which I've been asked to export as targa files.
    Normally one of our editors would do this but I've been asked and I haven't done this before does anyone have any tips ?
    As usual thanks in advance for any help.
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Wed, Apr 25 2007 9:51 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 441
    • Points 5,195
    Re: Export sequence as targa files
    I'm not at a system now... so the Help may be much more helpful to you for the exact steps...
    but... Right click on the sequence icon and choose Export.  set your destination in the Save Dialogue box.
    then click the options button.
    then there's this nice big window with a dropdown menu at the top.  click on that, and you should see something akin to Sequential Tiffs or something like that.  then you can choose the file format you want.
    hit save, then save again... and watch as it creates thousands of individual targa files.
    MC 3.0! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Wed, Apr 25 2007 10:00 PM In reply to
    • Blue Crow
    • Posts 421
    • Points 5,125
    Thanks very much I'm also at home just thought I'd put in a bit of preparation at home.
  • Thu, Apr 26 2007 3:40 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 950
    • Points 11,530
    • Moderator: Avid Symphony Nitris
    Something else to check is in the export dialogue to uncheck "use marks" and if you haven't marked an in and out in the sequence and want to export the whole thing. Ditto for "Use enabled tracks".
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Thu, Apr 26 2007 9:26 PM In reply to
    • Blue Crow
    • Posts 421
    • Points 5,125
    Thanks Scott.
  • Thu, May 1 2008 12:35 AM In reply to
    • Gerrit
    • Posts 56
    • Points 630
    Having problrms now with Targa sequence export. Symphony v 1.8.1. In a 1080p25 project, 1920x1080 Targa Export of sequential files.
    Plenty of drive space, yet after 3868 frames it falls over consistently with the error: "Exception:std:exception, what: bad allocation."
    Total amount at that point of about 21GB exported.
    Any ideas why? Corrupt media? I tried exporting just the clip within which this failure occurs and that was happy.
  • Thu, May 1 2008 1:10 AM In reply to
    • Gerrit
    • Posts 56
    • Points 630
    Seems to be a memory issue - bin/seq memory usage was 30%, after restart down to 7%, this time it exported 5656. Far cry from 15000 I need, but will have to divide sequence into parts.
  • Thu, May 1 2008 4:09 PM In reply to
    • Gerrit
    • Posts 56
    • Points 630
    Having divided sequence into parts (into separate folders) I was wondering if there is a way to force the sequential file numbering to pick up from where the previous one finished, rather than starting at 001 again?
    I know I can do it in Photoshop but it freaks out seeing that many files in a folder, don't really want to do it 20 at a time.
    Cheers
  • Thu, May 15 2008 3:17 PM In reply to
    • echo bush
    • Joined on Tue, May 9 2006
    • Posts 45
    • Points 595
    XP has it's own renaming function, here is how it works,
    Create different folders for outputting first and second batches from Avid
  • Highlight the files you want to rename. (Use Ctrl or Shift to highlight multiple files at once)
  • Right-Click the first file in the series, click Rename.
  • Only the file you've right clicked will be highlighted. That's OK. Change the file name, the extension will be kept.
  • Hit the enter key to commit your change. Your files will be named "file (1).jpg", "file (2).jpg", etc..
  • Then rename the Targas accordingly so that all the files are numerically and uniquely in sequence and merge into one folder.
    HP XW 8000 2 GIG RAM X7 HP XW 8200 2 GIG RAM X1 [view my complete system specs]
    Adrenaline 1.8.1
    Symphony Nitris 1.8.1
    Thx EB
