Hi everyone,
I hope I'm not asking a silly question, but I've looked around the forums and haven't been able to find the answer.
I'm starting a feature film as assistant editor. 35 mm, 24 Fps, working in PAL. Adrenaline 2.6. Sound is coming in BWF. I've managed to import the files with 6 tracks of audio and metadata. I'll be delivering an OMF to the Sound Editor (Protools).
Is there any way for me to link the OMF to the original BWFs instead of the wavs or aiffs created by Avid? The idea is for the sound editor to have access to all the sound tracks in the original file (say tracks 3-6), even if only tracks 1 and 2 are in the avid edit. All the OMFs and AAFs I've tried so far are linked to the Avid sound file, and since Avid creates 1 audio file for each track, there's no access to the rest. Am I doing something wrong? I can't think af any solution.
Thanks a lot for any help.
Lister.
Thanks a lot, I´ll look into Pyramix or Titan, I wasn't aware of their existence. I'm trying to avoid having to matchframe all the edits, hopefuly I'll manage to. The BWFs are fine, tc and metadata are intact after importing.
Thanks again for the information. Now I've got something to start on.
Cheers,
Waves are better since they're more metadata rich
Lister:I'm starting a feature film as assistant editor. 35 mm, 24 Fps, working in PAL. Adrenaline 2.6. Sound is coming in BWF. I've managed to import the files with 6 tracks of audio and metadata. I'll be delivering an OMF to the Sound Editor (Protools).
Phil Benson:If you can supply your sound department with ALL of the Adrenaline-created audio media (including those channels of audio it created but the picture editor has elected not to cut with), then ProTools 7.2 + 7.3 each has added software features for expanding protools regions to alternate channels.
I've imported this OMF In ProTools (7.3.1 cs4 for this test). And then imported the original Cantar multitrack monophonic file (AAD) in the session. Then, selecting a region, you can with a right-click either :
select Matches : ProTools allows you to replace existing region by any of the tracks found in the multitrack
or select Expand to New Tracks : ProTools will create as many new tracks (and regions) as there are in the multitrack, in addition to the existing region(s), sorted by Channel Name and/or Channel Number. Channel Name is the channel's name given by the audio engineer on the Cantar (Boom, Wireless mic, character's name, mix, etc.). It appears in Regions "matched" or "expanded" and in the Region List. Quite useful.
This feature only works with OMF composition linked to media (it doesn't work with "off-line" media).In this test, ProTools was able to link any OMF's regions ONLY with original's BWF multitrack. If you work in MC with imported multitracks and then import all Avid audio media files in the session, Matches and Expand functions are not activated when selecting a region. Apparently, whether you work in MC with mixdowns or multitracks, you need to import original BWF multitracks in sessions.The Expand feature works for part of a region, region(s) or an entire session's track.For this test, Audio File Format in MC was set to WAVE (I didn't test AIF as I don't see the point working with AIF when originals files are WAVE). ProTools read a lot of metadata coming from Avid audio media file, including Name, File Comment, #Channels, Sample Rate, Bit-Depth, Original Time Stamp, Clip Name, Tape, TC Rate, Scene & Take, Shoot Date (wrong in my test, might be a ProTool's bug), Rate, User Bits, Tape ID. Didn't try to add some metadata in MC, but Comments should be read by ProTools.ProTools Field Recorder Workflow Guide mention possible "Audio Misalignment" between OMF and Expanded Tracks. I didn't noticed that ; comparing an omf region and its "expanded sister" with a maximum zoom, the expanded region is in-sync within a sample.To conclude, these features must be really convenient for partial or total multitrack conforming. Just need now to test it "grandeur nature" (life-size) on a 20' sequence with 8 audio tracks...
