Latest post Wed, Apr 18 2007 3:23 PM by LewS. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Apr 18 2007 3:23 PM
    • LewS
    • West Palm Beach, FL
    • Posts 9,971
    • Points 128,645
    7.2 Full Installer Download & FLV Audio Fix
    Locked Reply Contact
    You can download it from this link.  If you do not see the update on the FTP site, clear the cache in your browser and try again.
    If you have problems with audio in exported FLV files, I have attached a file to this post called xpmflvu.txt. Download this file by right clicking and saving the target. Change the extension from .txt to .xpm and put it in the export plugin folder under Program Files/Avid/Avid Liquid 7/PlugIns/export and that should fix the problem.  Be sure to save the file that is there now. Do not overwrite it with this one just in case. This problem has been reported to Avid but this fix has been tested and seems to work without creating other issues.
    LewS
