So if you look at the audio clips in their bin and display sampling rate and bit depth, they all identify as 48K and 16 bit? If so, go to your user settings and under "audio project" "main" tab, make sure the sample rate is set for 48kHz. If you have a mix of different sampling rates, choose "always" for the option "convert sample rates when playing".
Also, on the project timeline, in the timeline fast menu go to clip color and choose "offline". This will make any offline clip in your sequence show up as bright red, so you can verify whether the audio media you're referring to is on or off line.
emotepix:Specifically, MC gives the error:Unable to open the file: XXXnameException: DOMAIN_COPYOUT_FAILEDException: COMPRESSED_AUDIO_FORMATS_NOT_SUPPORTEDWhich is strange considering it was all in 48k 16bit stereo AIFFs...
I'm running into the exact same problem : XPro 5.8 on Mac was used to import a few sound FX from a library. Some were AIFF, some were WAV but everything was imported at 48k/16bit (conversion done by the XPress on import, maybe that's a clue), they play fine in XPress. I transfered all the OMFi to the PC Media Composer 11 and I got this error message when the application scanned the drives, and I get it each time I try to open the bin containing the sound FX. Very strange because on the XPress, they show up in the bin as 48k/16bit. So they're not compressed.
Did you ever find a solution?
