Latest post Fri, Jul 24 2009 3:08 PM by MovieMaker76. 15 replies.
  • Sun, Apr 1 2007 12:59 PM
    • jan.t
    • Joined on Sun, Feb 25 2007
    • Posts 24
    • Points 320
    Export as Quicktime Movie -2GB file size limit
    Export as Quicktime Movie gives me the best (compared to Quicktime Reference) and acceptable results when burnt to DVD, but the films I have are much larger than 2 GB. When I try export longer films I get:
    "Error exporting file to disk. The file can not be created because it would exceed the two gigabyte file size limit. Export a shorter duration or change your export settings".
    How can I avoid this problem? Can I avoid this problem in Avid or shall I export the film in segments and use a program to join them together before I encode to Mpeg2? Is there such a program? Or shall I solve it some other way? (The background is this: I have had problems with blockage in dark areas of the DVD when I use qtref export and this blockage disappears when I burn a qtmov file).
    Jan
    from Sweden
  • Sun, Apr 1 2007 2:46 PM In reply to
    • camoscato
    • Posts 6,322
    • Points 75,685
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Export as Quicktime Movie -2GB file size limit
    Hi Jan,
    The 2GB file size limit usually only applies to AVI export, not QT.  Check your export settings and make sure you haven't inadvertantly selected AVI.
    If that's not it, how are your drives formatted?  FAT32 or NTFS?
    good luck,
    Carl
    MC 4.0.5, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
    There is no such thing as a video emergency.
    I've got a new website for 2010!
  • Sun, Apr 1 2007 3:04 PM In reply to
    • jan.t
    • Posts 24
    • Points 320
    Hello!
    I go to file-export and choose Quicktime Movie. I click options and it is quicktime movie. I use NTFS on all my drives. I use Avid Xpress DV 2.0.
    Look, I REALLY NEED an answer to this problem. I tried to export with compressor: "Animation", "None" and got the same result.
    (When I try to export "Same as Source" I get error: "Unable to Export Bin". When I click more I get: "Unable to Export the Bin. Exception: Parameter error! This export format may require audio or video tracks." I downloaded the the recommended Quicktime Player 7.1.3 but it didnt work.)
    I tried exporting to another hardware disc also formatted in NTFS - no go...
    If there was a program to join the exported (less than 2 GB) segments together I would use it right away..
    Where shall I start?
  • Mon, Apr 2 2007 1:26 PM In reply to
    • camoscato
    • Posts 6,322
    • Points 75,685
      Moderator: Meridien
    jan.t:
    Hi Jan,
    Xpress DV 2.0 probably doesn't work with Quicktime 7.  Check your ReadMe file to see if there is a version of Quicktime specified for your system.  If not, try Quicktime 6.5.2 (this is the version that works on my machine with XPress DV 4.8).
    good luck,
    Carl
  • Wed, Apr 16 2008 5:53 PM In reply to
    • chawilk
    • Vancouver Canada
    • Posts 26
    • Points 315
    I'm having problems exporting a 1/2 hr 1080i show as a Quicktime Animation (trying to get project exported in best quality so it can be colour corected & dubbed to HD Cam at post house).
    I keep getting the "exceeds 2 Gb files size limit" warning.  I have QT V7.2, my 1 TB drive is NTFS, I'm exporting as a Quicktime Animation, not an AVI.
    By my calculations the file size of this 30 minute show will be just over 100gigs.   Cutting it up into 2 gig pieces will result in 50 pieces, not really an option.
    Any thoughts on how to export this?
    Charles
    Pentium 4 CPU 3GHz, 3 GB of ram. Nvidia Quadro FX 3000 256mb 8x. Sound card: M-Audio Delta Audiophile. 3 - 500 gig Maxtor IDE drives. Windows XP SP... [view my complete system specs]
  • Mon, Jun 23 2008 7:38 PM In reply to
    • conleec
    • Los Angeles
    • Posts 674
    • Points 8,815
    I'm getting this error, too. This is a new situation, as I've exported QTs up to 100Gbs in the past. This has only started occuring since upgrading to v3. Has anybody else confirmed this, and more importantly has anybody found a solution to this problem?
    Chris
    MacPro 2.66Ghz 8 Core (Nehalem), 6Gb RAM, nVidia GeForce GT 120, Adrenaline HD, Leopard 10.5.8, MC 4.0.3, QT 7.6.2 [view my complete system specs]
  • Tue, Jun 24 2008 9:25 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,391
    • Points 15,735
    Export a ref file then use Quicktime Pro an covert to an Movie file....
    MC 4.04 QTime 7.6 2x Vista Ultimate 64bit sp1 2x XW 8400 2 x 3.0gig Xeons 5160 146.8GB 15K Ultra320 o/s drive 8 gig ram FX 1500 4 1tb 32 mb... [view my complete system specs]
  • Tue, Jun 24 2008 3:52 PM In reply to
    • conleec
    • Los Angeles
    • Posts 674
    • Points 8,815
    Thanks. I'll try this. But I don't understand why this suddenly began occuring. It used to work perfectly straight from the timeline.
    Chris
  • Mon, Jul 21 2008 3:27 AM In reply to
    • MovieMaker76
    • Joined on Tue, Mar 25 2008
    • Los Angeles
    • Posts 212
    • Points 2,755
     Has anyone found a solution to this.  It is so frustrating because I have a pretty big file I need to export, and I don't want to export as a reference.
    What is the deal?  Anyone find any help with this?
    Todd
    Intel Core 2 Duo E 6700, RAID(0), NVIDIA Quadro FX 3450/4000, 4GB ram, Vista64, MC 3.5 [view my complete system specs]
  • Mon, Sep 15 2008 1:56 PM In reply to
    • cjpaul99
    • Posts 6
    • Points 90
    Carl,  I need to export about 6 hours of footage for a client to AVI files and notieced this post.  Is there any way around the 2 gig limit?  We were hoping to do this in 15 min. chunks, not 2 min.  I loaded everying into the avid from Beta-SP to DV25.  Any tips would be greatly appreciated.
    Chris
    Avid Media composer 2.8.1 running on a duel 3.6 xenon. 4 gigs ram [view my complete system specs]
  • Mon, Sep 15 2008 10:09 PM In reply to
    • camoscato
    • Posts 6,322
    • Points 75,685
      Moderator: Meridien
    Hi Chris,
    The only way I know to avoid the 2GB AVI limit is to not use AVI as a format.  I'm sorry I don't have a better answer for you.
    good luck,
    Carl
  • Mon, Sep 15 2008 10:24 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,644
    • Points 114,550
      Moderator: Meridien
     Jan:
     Perhaps you should consider a real time playout of the timeline to a stand alone DVD recorder.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Wed, Dec 17 2008 3:44 AM In reply to
    • R&B
    • Metro Atlanta
    • Posts 183
    • Points 2,235
    • Moderator: Avid Xpress DV PC
    I was always led to believe that the 2 GB file size limit was a Windows limitation, having nothing to do with Quick Time or .avi.
    Randy
    iMac, running OS X 10.5.5 Leopard on a second HD partition to keep application separate from Pro Tools LE. 3.06 GHz Intel Core 2 processor. 4 GB RAM... [view my complete system specs]
    Randy Brown
    President
    Brown Media, Inc.
    www.brownmedia.net
    "Voice Imaging for Radio and TV"
  • Wed, Dec 17 2008 4:38 AM In reply to
    "... the 2 GB file size limit was a Windows limitation ..."
    It is if using a FAT16 File System ...
    http://support.microsoft.com/kb/118335
    http://support.microsoft.com/kb/310561/
    Here is a table that lists the maximum file sizes for different operating systems and file systems*:
      Windows 95
    (pre-OSR2)
    Windows 95 OSR2+,
    Windows 98/SE/ME
    Windows NT 4.0 Windows 2000/XP
    FAT16 2 GB 2 GB 4 GB 4 GB
    FAT32 N/A 4 GB N/A 4 GB
    NTFS N/A N/A Nearly unlimited Nearly unlimited
    * http://neuron2.net/LVG/filesize.html
    Media Composer 4.0.4 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware 9690SA... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Fri, Jul 24 2009 1:38 PM In reply to
    I am experiencing the same problem today on one of my two MC stations: I exported a 60-minutes timeline as quicktime animation on a LOCAL DRIVE. I could see the .mov file growing in size - 40 GB, 60 GB. Then just as it was finished the export failed and I see the error message: "exceeding 2GB file size..." and the mov file disappears from my drive.
    I went to my other station and the export worked flawlessly. I had this problem before and the only way I found to get rid of the problem was to perform a clean re-install of XP and all the software - this is not something I do for fun, it take me a full 8-hours day of work to reinstall and reconfigure a station.
    Last week I had performed a similar export from the same station and there were no problems, yet yesterday it failed, on the apparently same software. I believe the problem does not originate from Avid. It does not come from a specific version of Quicktime (I did a lot of testing!). It must be caused by a plugin or some obscure small app or download from the last weeks. I asked my editor if he installed anything special but he does not remember... I will revert to my last ghost image and I expect that the problem will be gone.
    HP xw8400 - Media Composer Adrenaline HD / HP xw8200 - Media Composer Mojo / 4TB EditShare shared storage [view my complete system specs]
    Pierre Corbeil
