Latest post Sat, Sep 20 2008 8:20 PM by pdrg. 88 replies.
Page 1 of 6 (89 items) 1 2 3 4 5 Next > ... Last »
  • Mon, Nov 28 2005 4:21 PM
    problems with Xpress Pro and Realtek High Definition SOLUTION
    Hi, I have problem with my notebook sony VAIO that has  the soundboard "Realtek High Definition".
    I already installed Avid Xpress Pro 4.3, and when it startsup xpress appears a note "ADM_DSOUND_MIXER_OPEN_ERROR
    Does anybody knows what it means??? Can anybody give me a solution?!?!?!
    Thanx a lot, Danny.
  • Mon, Nov 28 2005 4:28 PM In reply to
    • dthompson
    • Avid Technology
    • Posts 66
    • Points 960
    • Avid Customer Service
      Avid Employee
    Re: problems with Xpress Pro and Realtek High Definition
    Hello,
    the Realtek HD card was not supported until v5.1.6 of Xpress Pro. You will need to upgrade to the HD version or purchase a "Sounblaster Audigy 2" card.
    Best Regards,
    Xpress Studio Essentials HD w/ Xpress Pro v5.2.3 HP XW4100 Windows XP Pro SP2 P4 3.0 Ghz 1.5 Gb ram Nvidia Quadro4 980XGL [view my complete system specs]
    ~David R. Thompson~ ACSR|Windows ACSR|Macintosh ACSR|Unity Avid Technology, Inc.
  • Fri, Jan 6 2006 1:57 AM In reply to
    • EHS
    • Joined on Mon, Dec 12 2005
    • Posts 80
    • Points 1,350
    Crying [:'(] Can't find any audio cards in your system!
        Hey guys.. I use Avid Xpress Pro HD.
    And when i start it, it says "Can't find any audio cards in your system!"
    so when i capture.. i can't even replay anything because there is no audio... but i have an audio card.
    my audio card is a "Realtek High Definition Audio". Isn't that audio problem fixed in Avid Xpress Pro HD 5.2?
    please help.. thank you
    Thank you very much for your support guys!
  • Fri, Jan 6 2006 11:51 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    Re: Can't find any audio cards in your system!
    yes it should be fixed in 5.2 .. you'd better go 5.2.1 though. Make sure you have the appropiate drivers installed for the card. We use the Relatek HD card on several laptops with 5.2.1 no problem.. so there must be some problem on a deeper level.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sat, Jan 7 2006 7:02 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    Crying [:'(] AW: Re: Can't find any audio cards in your system!
    Okay, I installed 5.2.1, but it still does not work. It says, that there is no audio card which is supported by Avid, whereas I use the "Realtek High Definition" audio card.
    Isn't there any other possibilities to change something or to install or let Avid recognize my audio card in the avid programm? can't i install it in avid? or something like that..?
    I use a notebook, that is the reason why i can't change my audio card...
    but when i go to my project window and then to the settings lap and then to audio project, i click on hardware, and it says "NULL Audio Device & 1394 Audio". Can't I change that?
    thank you for your help
  • Sun, Jan 8 2006 8:26 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    i don't get it... why doesn't it work...? :(
    please help...
    thank you
  • Mon, Jan 9 2006 1:16 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    heeeeeeeeeeeeeeeeeeeeeeeeeeeelp pleaaaaaaaaaseeeeee
  • Mon, Jan 9 2006 1:53 PM In reply to
    • JJx
    • Joined on Mon, Jan 9 2006
    • Posts 1
    • Points 5
    Initialising Audio
    Had Xpress Pro HD 5.1.5 but on initialising audio received messege saying:   !Exception: ADM_DSOUND_MIXER_OPEN_ERROR, was told by third party my sound card (Microsoft UAA Function Driver for High Definition Audio - Realtek 880), was not right and that Avid had fixed this compatibility problem for version 5.1.6. . So I got Avid Xpress Pro HD version 5.2.1 and then on initialising audio for this version was told no audio cards could be found in my system.
    I can use Avid with no Audio, but this is not an option for me as I need sound for my project.  Any sugesstions, please????
    Massive thanx, JJx
  • Mon, Jan 9 2006 2:28 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    Sad [:(] AW: Re: problems with Xpress Pro and Realtek High Definition
    well. i have the 5.2.1 and it says no audio card was found or is supported.
    i can't use avid xpress pro hd either because it says no sound... what can i do?
  • Mon, Jan 9 2006 2:33 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    Crying [:'(] AW: Initialising Audio
    I HAVE EXACTLY THE SAME PROBLEM! We need HELP!!!
    Thanks guys!!!
  • Mon, Jan 9 2006 2:46 PM In reply to
    Re: AW: Re: Can't find any audio cards in your system!
    I gave up trying to get my on-board Realtek audio to work with Xpress Pro months ago and bought an Audigy 2 ZS.
    Click on Web Address [view my complete system specs]
  • Mon, Jan 9 2006 2:50 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    Crying [:'(] AW: Re: AW: Re: Can't find any audio cards in your system!
    I can't do that! I have a laptop! I need to get it to work with Realtek High Definition audio card!
    HEEEEEEEEEEEEEEEEEEEEEEEEEEELP
  • Mon, Jan 9 2006 3:08 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 956
    • Points 11,600
    • Moderator: Avid Symphony Nitris
    Re: AW: Re: problems with Xpress Pro and Realtek High Definition
    ladireccion, You need to disable the on board sound and get a sound card. I know zilch about laptops so I don't know if that's possible. Or upgrade to the latest version and see if that works.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Mon, Jan 9 2006 3:12 PM In reply to
    There are USB audio hardware solutions. I don't know how well they work with Xpress Pro. Part of the problem is Xpress Pro doesn't "officially" support any audio hardware, so people who want to purchase audio hardware can't even go to a list of supported hardware and pick something that works.
  • Mon, Jan 9 2006 3:22 PM In reply to
    • EHS
    • Posts 80
    • Points 1,350
    Sad [:(] AW: Re: AW: Re: problems with Xpress Pro and Realtek High Definition
    so what can i do then?!
    I cannot buy another audio card! i have a notebook! and avid producers said that the probem is fixed in 5.2.1
    and i use avid 5.2.1
    isn't somewhere a professional avid supporter who knows how to fix that problem without buying any new stuff or without opening my notebook. that is not possible! avid said that that problem is fixed.. and i doubt it that avid lies...
