After installing 5.2 the 002 option no longer appears in the Send To sub menu 9just the MBox options...any idea why?
Secondly, when I export using the default 002 option and attempt to open the AAF session file in Protools I get the following message:
"Could not create new document because an unexpected error happened while trying to determine the file's timecode format"
This is occuring on all sequences exported no matter 25p or 25i (yes I am in a PAL territory). All sequences tried from different projects start at timecode 00:00:30:00. I have restored the 002 export setting to its default in settings but no joy.
Help please!
bump
Robert Davis President/Creative Director Davis Advertising, Inc. Visit my latest blog, "Concept to Creation" on the Avid Community site
This is amazing...not one idea out there as to how to fix this problem? Avid?
Anyways, another clue might be that if I attempt to import session data (instead of creating a Protools session by opening the aaf file on startup) I get a slightly different message, it says:
"Could not complete the 'Import Session Data...' command because an unexpected error happened while reading the file's main composition sequences"
Helpful eh!...not
I have now re-installed the entire system and it still DOES NOT WORK so I think it must be project related. Is there anyway the timecode can become corrupted in a project or clip that would cause this, if so is there a way round it? (I have tried duplicating the sequence but this does not fix the problem). Is it a bug that Avid might tell us about if they get found out? (Like the playback buffers problem for example)
I have tried exporting to Protools (without the 'send to' route), consolidating and just about everything I can think of but with no luck.
I can open some older aaf sessions that were created under the SD version of the Studio suite but nothing since the HD upgrade. This combined with the Protools 002 'Send to' option missing from the 'send to' sub menu makes me wonder.
Please, someone must have a clue...surely!
Hi Jon, thanks for the response.
Yes I am exporting as aaf linked to original media. I actually have a sneaking suspicion this is related to the 25p project. I ran a test on a new test 25i project with the new 5.2.1 HD update installed and it impoted into Protools without a problem. Any progressive project I try produces the same errors.
I will try as OMF and see what happens and report back.
OK, Jon's suggestion of using OMF instead of the default AAF format worked! Not sure why AAF is not working but the problem is fixed for this job. Many thanks.
Hans http://www.AvidUserGroup.NL fcp2avid "The Technology Is Not Guilty" - Nicolas Philibert quoted in "Documentary in the digital age" by Maxine Baker (2006)
I get the same error message when I try to create pro tools session from aaf file linked to audio and video. With omf file I do not get this error, however, I can't view video in client monitor when using a pro tools session created with omf audio from avid studio hd.
Does this mean that the new Pro Tools v. 6.5.3r2 is not really a fix?
What is weed? A plant whose virtues have not yet been discovered. - Emerson
After reformatting my SCSI drives to Dynamic 4 way striped I no longer receive the error "Could not create new document because an unexpected error happened while trying to determine the file's timecode format." I am able to import aaf session data from Avid into Pro Tools. However, on playback I now get the error which version 6.5.3r2 is supposed to fix, namely, "video playback stopped due to hardware buffer underrun". Changing the buffer settings has not solved the issue.
Is there something I'm failing to do here? Please help.
I have exactly the same problem.
Sometimes an AAF will import OK but most of the time I get the error messages. I cant seem to pin down what the problem is.
If anyone finds a solution, please let me know and I will keep trying.
I am getting that same error ...
"Could not create ... unexpected error ... timecode format."
I followed the tutorial for exporting to Avid P.T. (mbox_Ref) and opening session with the Adv. Authoring Format file.
Anyone figure out what the problem is?
