Latest post Wed, May 14 2008 12:35 AM by Edit2007. 23 replies.
Page 2 of 2 (24 items) < Previous 1 2
  • Sat, Mar 24 2007 2:43 AM In reply to
    • TMVC
    • Posts 71
    • Points 960
    Re: is the mojo built to last?
    no disagreements with anyone here.  the point is with competitors trying harder and harder - and pushing the options - i think the avid boys have to try harder.  it's easier to swap a dead card than a dead mojo - at least in my parts.  avid has become for better or worse - a target for what is not good in editing, much as sony in my parts has become less responsive than say panasonic.  i think the new avid upgrade pricing / assurance plan for $ 995 (that i see on the Media Composer forum) is a good idea and shows that they're trying to respond to where the market is going...
    Avid is a superior editing machine because of its track record and legacy but when suites are looking to upgrade and expand big time, the choice is less clear.
    System 1: MC Adrenaline version 2.27 HP xw8200 3.4 dual xeon 3 gb RAM Huge Mediavault U320 3 x 200 gb RAID 3 System 2: Avid Xpress Pro 5... [view my complete system specs]
  • Sat, Mar 24 2007 3:12 AM In reply to
    • Julian Ridi
    • CANADA
    • Posts 343
    • Points 4,020
    berga:
    The conventional visdom says that electronical things like computers and Mojos will fail during the first month they live. This because most problems is due to faulty hardware or bad ensambling. Therefore, it is a good idea to let the Mojo be on during the first cople of month and hope some overheating will crack the fautly hardware.
    ditto..Berga
    I leave mojo's on all week and off on the weekends. The mojo's power plug is always left pluged in. We have it on a switched Monster Cable power bar along with other electronic devices. No issues
    Leave it on and get a good surge protector or better yet a UPS for it. They didn't put a power switch on it for a reason - I'm told told to leave it on! Avid makes the same grade of electronics as everyone else does - even FCP hardware is equal.
    Power surges/spikes/bumps are fatal to any electronic gear. Protect it properly the first time
    J
    15" MBP
  • Fri, May 9 2008 5:45 PM In reply to
    • Edit2007
    • Joined on Tue, Dec 5 2006
    • Posts 43
    • Points 540
     But leaving it on all week ....doesn't that speed the process towards the dead of the hardware.....I thought that you would need to turn it off every night. I have a new SDI and I do turn it off....but I have to admit I have trouble connecting (I always do connect eventually) back the next day. I pull the AC connector from the back of the Mojo....should I unpluge it differently? before or after the PC is off? I never toush the firewire cable. if you can , let me now. Thanks
  • Sat, May 10 2008 3:15 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 2,993
    • Points 34,290
    Edit2007:
    That's a popular belief, and it's WRONG.  Every time that you turn on a piece of electronic equipment from cold it is stressed.
    When you apply power the impedance the mojo presents to the mains is quite low.  It dynamically rises to operating levels quite quickly, but briefly, it will draw very much more current than its steady-state conditions require.  This "starting surge" stresses the components in the mojo, thus shortening its life.
    For example, in the early days of 2" videotape the television station at which I was then working used to turn off the VTRs every night and restart from cold the next day.  Maintenance requirements were high.  We then adopted a partial shutdown regime, putting the VTRs into a stand-by mode overnight.  Maintenance instantly dropped to under 10% of what it was previously.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Sat, May 10 2008 3:42 AM In reply to
    I don't know about others but we have a HIGH rate of RMA for our Decklink, Multbridge Pro and Extreme (1/3 in fact). Mojo''s failure rate in our experience is much lower than Blackmagic stuff but not as good Adrenaline.
    Intel E6600, Windows XP SP2, EVGA 8800 GT, 3GB RAM [view my complete system specs]
  • Sat, May 10 2008 3:48 AM In reply to
    • raspago
    • FL, USA
    • Posts 708
    • Points 8,775
    EditSix:
    I've installed and supported a LOT of Analogue Mojos and a handful of SDI Mojos. Of those I've only had 4 DOA and 4 that died a few months down the line and only one DOA Mojo SDI. But then I've installed hundreds of DSR11 and 45s and there have been some DOA or faulty.
    Or Macs.
    Or xw8200s.
    Or... well, I could go on...
    The point is, that it happens, it's not a reflection on Avid's build quality.
    Most places don't even shut their Mojos down with no problems. My own Mojo has been running for near 2 years, sometimes out on the road or on hire. No problems.
    I've not had as much good fortune with Decklink or Kona cards. When they work, they're awesome, when they don't, it's a nightmare. I have more faith in the Mojo, frankly.
    .-Indisputable truth.
    My Mojo has been working perfectly since 2005.
    My audio card (E-Mu 1212m) is not approved but works perfectly with my Avid with no special cofigurations, workarounds or else.
    I've seen Decklinks, Macs, XW8400s, Digibetas and other equipment DOA.
    I've seen Konas failing bad and giving a lot of trouble (audio sync, no edit to tape, etc)
    And, finally, I HATE when people try to make others believe FCP-Kona-Decklink is the magical solution that never fails.
    NO, is not!
    Custom made Intel core 2 duo 2.4 (overclocked to 3 [view my complete system specs]
  • Mon, May 12 2008 1:48 PM In reply to
    • Edit2007
    • Posts 43
    • Points 540
    I am leaving the Mojo on all day and overnight....but now I can't comunicate with it...I restarted twice my HP and the warning saying Avid Mojo not Found keeps showing up with the option to also Continue. What should I do to avoid turning off and on muy Mojo (I know it is going to comunicate after I do that). In the Mojo SDI I see 48KHZ HOST and POWER lights on.
    using MC with HP8200 Dual 3.2  with 2GB of RAM. I have a client monitor conected to Component output on Mojo SDI and zinc cable to a Horita black box.
  • Mon, May 12 2008 2:35 PM In reply to
    With Mojo off, go to Device Manager and uninstall your firewire controller. Shutdown. Turn on Mojo. Turn on PC.
    See if this works.
  • Wed, May 14 2008 12:35 AM In reply to
    • Edit2007
    • Posts 43
    • Points 540
     I first deleted the Texas Instruments OHCI Compliant IEEE 139...Controller inside IEEE 1394 Bus host controller on Device Manager....then after it did worked once, then if didn't in a second reboot. Then I thought may you meant to delete the SBP2 Compliant IEEE 1394 device inside SBP2 IEEE 1394 device. .....but after rebooting, all files are back but the problem not finding the Mojo is there.....as I said I always end up power cycling the Mojo and after that it does work....is this my destiny in everytime I turn off or restart my PC? Just a note I am attaching my Mojo to a new 1394 card I installed thinking that by doing that my problems with connection would be over.
    Please let me know what do you think when you can. Thanks
    MC/MojoSDI/HPXW8200 dual.
