Amen. The sky is not falling here.
I can see how my previous post wasn't clear... my bad. Bus Errors are an issue, but I highly doubt it'll significantly impact your workflow.
Now your dual 2 G5 could be an issue. To be honest, I would not suggest keeping it much longer. I honestly think at this point, a quad processor machine is a must, even if it's a G5 Quad. At the very least a core based pci-e model dual 2 or 2.3 G5. A MacPro is a much better choice of course. The brand new Harpertown Mac Pros have some issues with the current release, mostly OS related, so waiting for them/Leopard to be approved might be the way to go. The best thing about the Mac Pros is the 4 internal SATA bays. You can drop a couple of 1TB SATA drives in there and stripe em' together... presto... 2 TB's of highly affordable high speed storage.
Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
digitaldenial:
If you are delivering in SD, why can't you simply use an HD format and deck that downconverts for you? You can use the SD downconvert for the edit.
If and when you need an HD deliverable of the program, look into upgrading and see where Avid is at at that time.
Todd Sanderson:The best thing about the Mac Pros is the 4 internal SATA bays. You can drop a couple of 1TB SATA drives in there and stripe em' together... presto... 2 TB's of highly affordable high speed storage.
Question about that: Having multiple drives doesn't create bus conflicts with the Adrenaline box and Arrays? I was always told the reason AVID couldn't play nice with commercial USB or Firewire drives is that the serial busses were all occupied by the Adrenaline and Array. Do the SATA drives not look for the same architecture?
"For every moment of triumph, for every instance of beauty, many souls must be trampled."
- Dr. Hunter S. Thompson
Firewire and SATA are two completely separate bus segments.
BLKDOG:Firewire and SATA are two completely separate bus segments.
Just making sure I have this right. The internal SATA drives, supposing you maxed out with 4 TB drives could replace a Mediadock array for HD editing and realtime playback?
That's Very intersting. Hmmmmm :D
Theoretically that's true... I personally have not used my internal SATA Raid for HD however.
Hi all,
I was wondering if some of you might want to try an experiment with me. It's recently been theorized that FW throughput could be greatly enhanced by a flush of the PMU or SMU settings on the motherboard.
On Monday I am going to open up my G5 and reset my SMU to see if my Bus errros get better. Any of you who have problems in this area are welcome to join me and let's see if anything improves....
Instructions for doing this on the Mac Pros can be found here.
'Morning Blkdog, I was installing more RAM in my G5 and so did the SMU reset. Bus errors were approx. 1-2 a week, rarely more than 1 a day. I religiously do a permissions reset on all applicable Avid and mediafile folders, especially on render heavy projects, on a every two day schedule. Will let you know if this changes. Hope this helps.
Terrific 'cat. this is just the test we were hoping for. I hope it helps your situation.
[MOD EDIT]
Removed for Speculation.
?!*/?! darn my first one since March 31st. However I admit I didn't religiously do a permissions reset on all applicable Avid and mediafile folders, so am I due for a mea culpa ??
I'' do a permossions reset and see how far I can go .
and on a totally different subject matter .... sniff sniff snowboard season is done ....... goldarn ..
Here's an odd observation- I seem to get more of my crashes in the mornings (I shut down my computer each night). Every morning, within an hour of working I might have two or three crashes and then it's usually pretty good for the rest of the day. Hmmm. I'm not going to shut down for a while and see what happens.
