Latest post Thu, May 15 2008 11:56 AM by pinpan. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jan 10 2007 10:08 PM
    • Kman006
    • Joined on Tue, May 9 2006
    • Posts 18
    • Points 210
    Saving Filmscribe columnar files
    I'm creating neg cut lists and have noticed that in filmscribe when you create a columnar list there is no way to save it as a Word file.
    Obviously I want to be able to forward these lists to the neg house in a file format they can open.
    Is there a way to save it as a word file right from within filmscribe?
  • Fri, Jan 12 2007 5:58 AM In reply to
    • Kman006
    • Posts 18
    • Points 210
    Re: Saving Filmscribe columnar files
    I guess I should be a bit more specific.  When creating an assemble list using the "Columnar" template in filmscribe, the Preview window comes up showing the generated list.
    When I try to "save as" the only option is to save the list as a Avid .ctl file.  That file seems to be useless outside of filmscribe.  I've tried opening it up in Word, Notepad, etc, and it's just a jumbled mess.
    Am I missing something here?  Surely there is a way to save a generated cutlist out of filmscribe that can be opened in an application to edit and print!
  • Fri, Jan 12 2007 11:36 AM In reply to
    I used to create cutlists in ALE format. These can be easiliy imported into Excel or Word etc.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Sat, Jan 13 2007 8:45 AM In reply to
    • Kman006
    • Posts 18
    • Points 210
    I seem to remember the old version of Avid cut list program had more options for saving the files.
    For the life of me I can't figure out an easy way to save these things.
    I'm sending printed lists to the neg cutter, but it would be nice to e-mail him files as well.
  • Mon, Jan 15 2007 1:20 AM In reply to
    • MichaelP
    • Boston
    • Posts 1,458
    • Points 18,170
      Moderator: Film
    FilmScribe is not dongle protected. One of the reasons for doing so is that the neg cutter can open the files, or use FilmScribe to generate their own lists based on the bin send to them. I use the PDF printer file from any of my applications to create a file version I can email. Or you can export as a TAB delimited file as mentioned. I also use the HTML version that I post for the neg cutter or anyone else needing access to the information. See:
    http://24p.com/FilmScribeOutput/CStyleAssembly060105_Asm.htm
    These were the final lists for the feature documentary "Cinematographer Style" (http://www.theasc.com/cgibin/store/acsstore.cgi?user_action=detail&catalogno=cinstyle ) on which I was the post supervisor. The lists were used for pulling and the DI process.
    Michael
    HP 8600 Symphony Nitris DX v3 || MBP 15" Media Composer v3 [view my complete system specs]
    ____________ Anything 24fps
  • Tue, Jan 23 2007 6:33 AM In reply to
    • Abie
    • Telaviv
    • Posts 215
    • Points 2,595
    I find that using "open with" Internet explorer on any computer opens .ctl files beautifully. I then do save as before e-mailing the lab. However, Michael's way sounds better, I will send a copy of film scribe to my lab. It must be much easier for a Lab to be able to manipulate the lists, rather than having a print out. Otherwise, they must get some pull lists heads out, others tails out etc. Keeps them on their toes though, which isn't neccessarily a bad thing.
    6xMC 2.6.6 on HP wx8400 Lanshare LP *TB 4.2.2 1xXPpro on xw4200 w/mojo 2xXPpro on G5 1xSymphony Compaq Evo [view my complete system specs]
    Abie Edit Studios Telaviv
  • Thu, May 15 2008 11:56 AM In reply to
    • pinpan
    • Joined on Thu, May 31 2007
    • Posts 10
    • Points 115
