Latest post Wed, Apr 30 2008 11:34 AM by Fairmorn. 237 replies.
Page 16 of 16 (238 items) « First ... < Previous 12 13 14 15 16
  • Sat, Mar 29 2008 12:00 PM In reply to
    • prisca
    • Joined on Tue, Dec 12 2006
    • Posts 66
    • Points 790
    Re: thin green line in composer / exported quicktime
    That's great Fairmorn....very promt responce from the engineers !!!
    could they let us know what sort of "evil eye gem" they have used or is it a house-secret ?
    Cheers,
    Prisca.
  • Mon, Apr 21 2008 4:02 PM In reply to
    • Fairmorn
    • Joined on Thu, Jan 10 2008
    • Posts 18
    • Points 200
    And, prisca, this was usefull for You or not?
    Tell me please... And others too - "enjoy the silence"?
  • Tue, Apr 22 2008 2:22 PM In reply to
    • prisca
    • Posts 66
    • Points 790
    I would never have believed it Fairmorn (and others...)
    I want to make some dvd's using the new cinemacraft encoder (Normally i use dvdit pro)
    Any tips ?
  • Tue, Apr 22 2008 9:52 PM In reply to
    • curiosity
    • Boulder, CO
    • Posts 609
    • Points 7,705
    Cinemacraft makes outstanding MPEG2 encodes. The best I've ever seen from a software encoder. It is worth it to read through the user guide's advanced options for their suggestions on settings. (Like using Zig-Zag mode for progressive source material, and when to enable upper field encoding.)
    Other than that the encoder is very straightforward and even the default settings will get you solid results.
    Macintosh: Intel 2.8GHz(8C - 2007), 4GB RAM, SUNIX [view my complete system specs]
  • Tue, Apr 22 2008 10:10 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    I use DVDit PRO too and I like this program - only one little minus I found in it - output picture little brighter than original. But in creation of menu and navigation buttons (includind animated buttons!) it very comfortable thing.
    About Cinema Craft encoder - need to see... May be it better than DVDit. Need to try
  • Wed, Apr 23 2008 9:19 AM In reply to
    • prisca
    • Posts 66
    • Points 790
    CC encodes to mpg2 .
    What do you use to create a DVD ?
    On the other hand you use a Mac and I'm a PC.
    Any ideas ?
    Cheers,
    Prisca
  • Wed, Apr 23 2008 9:22 AM In reply to
    • prisca
    • Posts 66
    • Points 790
    BTW think of that....
    Imagine, some moderator complains that we are off-topic !!!!
    That would be great.
    Let's give some life to this dead green-corner !
    P.
  • Wed, Apr 23 2008 1:45 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    This topic may be one of oldest in Internet history - moderators must to forgive us :)
    Prisca, You said that You normally using DVDit PRO. As I'am too... But DVDit PRO was exactly made for creation of DVD final disk (or image or volume). And this program have its own good transcoder.
    By other words - You just importing your video from your Avid (reference quicktime are best for import - program sees them with sound at ones), cut on chapters, create menues (may be animated menues), choose transcoding bitrate (for DVD5 or DVD9 - in DVDit PRO HD You can to burn even Blu-Ray) and choose "Burn" in menu - that's all !!!
    I didn't understand - for what you need Cinema Craft after DVDit PRO?
  • Wed, Apr 23 2008 3:40 PM In reply to
    • prisca
    • Posts 66
    • Points 790
    You are right Fairmorn, DVTitPro does it all and well !
    On the other hand cinemacraft as encoder has 4x the price of DVDitPro, it.s just my curiosity.
    to see what goes on.
    If you encode with cc and import to DVDit the mpeg will be reencoded so you lose time and quality...
    I have to test it !!
    Prisca
  • Wed, Apr 23 2008 7:52 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    May be pretranscoding in cinemacraft will give better result even after DVDit PRO final transcoding, but in referenses cc loses audio file - not a big problem - always can to import it manually to DVDit - global question in final quality (I did not tested it yet)
    May be a hidden reason in this...
  • Tue, Apr 29 2008 11:31 AM In reply to
    hi everyone!
    i am not quite sure if i have solved the problem, but in my case it defenitely helped to
    add a luminance-limiter (color-correction cut <16 and >235). the green line went away.
    so i think its definetive a codec and luminance problem.
    can anyone with the green-line-pal-p-problem check this out?
  • Tue, Apr 29 2008 11:58 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,198
    • Points 13,320
    thin green line is'nt that a movie title?
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Wed, Apr 30 2008 11:34 AM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    superwinter:
    hi everyone!
    this is not a codec or luminance problem (as I think)
    in my case as was wrote above, green line appears only in 25p PAL project and not after import but only after using AVX filter or effect (AVX2 have not this artefact at all)
    Mark very helped in solving of this problem. Method was simple - to change rendering setting (only rendering) to 14:1 (in Avid Xpress) with de-selected "Same as Source"
    as I said, green line presents ONLY in 25p PAL mode.
