Latest post Wed, Apr 30 2008 11:34 AM by Fairmorn. 237 replies.
Page 15 of 16 (238 items) « First ... < Previous 12 13 14 15 16 Next >
  • Fri, Jan 11 2008 2:07 PM In reply to
    • Fairmorn
    • Joined on Thu, Jan 10 2008
    • Posts 18
    • Points 200
    Re: thin green line in composer / exported quicktime
    mark.burton:
    Hi Fairmorn. Can you tell us a little more about your workflow and setup. Are you shooting to an interlaced format?
    If "shooting" meaned "capturing", than I capture analog and digital video through Sorenson Squeze - there is no any settings for capturing - all automatically.
    Captured file always have some interlacing on move between fields ( so called "combs" or "stairs" ).
    After that I converting this captured file through Canopus Pro Coder choosing in Target "Non-Interlaced" mode.
    Target I choose "QuickTime6 - DV for Avid Xpress - PAL" "Apple DV - PAL".
    And after convertion I import new deinterlaced file to Avid.
    Result always very good
  • Fri, Jan 11 2008 2:10 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    May be too many steps, but even when I captured digital video directly in Avid, I always had interlacing in captured video...
  • Fri, Jan 11 2008 4:12 PM In reply to
    • mark.burton
    • London, UK
    • Posts 544
    • Points 6,785
    Try the imports with DV25p 420 selected in the Import Resolution. From what I have found this is mostly OK, but if you do start to get the green line, you could choose 14:1p.
    MacBook Pro 2.16 / G5 Dual 2.0 [view my complete system specs]
  • Fri, Jan 11 2008 4:32 PM In reply to
    • JOEmedia
    • Joined on Mon, May 22 2006
    • Brisbane, Australia
    • Posts 1,000
    • Points 11,685
    mark.burton:
    This is the Media Composer forum, therefore its expected that people will have 1:1, 2:1, 3:1 etc, however if you are using Xpress Pro, the best you can do is choose 14:1p
    Ahhh I see now, yes I was assuming MC.
    Windows XP32 SP2 Intel Pentium D950 3.4GHz Dual-core (OC to 3.83GHz) Asus P5LD2-Deluxe Mobo, Onboard Realtek Audio and TI based IEEE1394 Nvidia QuadroFX... [view my complete system specs]
    (- =) Joe
  • Fri, Jan 11 2008 7:41 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    when I import file green line don't present
    it start to appear only after rendering of filter or effect - not always - AVX2 filters don't have it, but others...
    Anyway - Mark said realy working method - my Respect again and again for this!
  • Thu, Jan 17 2008 5:34 PM In reply to
    • prisca
    • Joined on Tue, Dec 12 2006
    • Posts 66
    • Points 790
    To the "engineers":
    Another very good method to minimise the green line is by usimg an evil eye bead.
    Any blue stone will do but turquoise is the best. (avoid transparent stones...)
    You simply hang the bead somewhere at your screen, that's all.
    Some people have experienced a speed increase in rendering, I'm not sure about that.
    And it is Vista compatible too !
    Good Luck !
    Prisca
  • Fri, Jan 18 2008 7:07 AM In reply to
    • curiosity
    • Boulder, CO
    • Posts 609
    • Points 7,705
    You could try working in the nude. I'm sure no one would see a thin green line in your QT files then... :)
    Macintosh: Intel 2.8GHz(8C - 2007), 4GB RAM, SUNIX [view my complete system specs]
  • Fri, Jan 18 2008 9:01 AM In reply to
    • prisca
    • Posts 66
    • Points 790
    curiosity:
    I'm not sure i'm getting your point...
    Have you tried that yourself ?
    Best regards
    P
  • Thu, Feb 7 2008 5:48 PM In reply to
    Can anyone confirm whether or not this problem is still present in the latest upgrade?
    We no longer own any Avid kit. Still using MC/AXP on hire [view my complete system specs]
  • Sat, Feb 9 2008 11:54 AM In reply to
    • prisca
    • Posts 66
    • Points 790
    Post Republic:
    use your ....imagination.........
    cheers,
    p.
  • Sun, Feb 10 2008 1:24 PM In reply to
    Oh dear.
  • Sun, Feb 24 2008 7:23 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    there is no cheers, guys...
  • Thu, Mar 27 2008 12:57 PM In reply to
    • prisca
    • Posts 66
    • Points 790
    ....so ?
    Still experimenting ? or has it been solved ?
    P
  • Thu, Mar 27 2008 2:50 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 78
    • Points 900
    I'm not sure if I'm putting my turquoise in the right place, it doesn't seem to be having any effect. Does it matter if I have a dream-catcher in the room?
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Thu, Mar 27 2008 8:10 PM In reply to
    • Fairmorn
    • Posts 18
    • Points 200
    to prisca:
    it was solved - read above...
