Latest post Wed, Jul 11 2007 4:19 PM by joelrmorgan. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Nov 3 2006 7:14 PM
    • MediaGuy4
    • Joined on Mon, Jan 16 2006
    • Foxboro, MA
    • Posts 17
    • Points 230
    No Audio on Capture
    Seeking help...
    I just upgraded from 5.2.4 to 5.6.2
    When I attempt to capture analog video, looping through a JVC BR-DV3000U MiniDV VTR, I get video, but no audio through the 1394 connection.  When I capture directly from a MiniDV tape I have no problems, audio from the VTR through the firewire 1394 works fine.
    Before upgrading, this setup of capturing analog video through a lopping setup worked fine.
    Any suggestions?  No Mojo involved.
    Avid Express Pro HD v.5.2.4 NO MOJO Quick Time 6.5.2 Windows XP Pro, Service Pack 2 Intel Pentium D 3.20GHz, 800Mhz FSB, 2MB L2 Cache RAM: 2 GB... [view my complete system specs]
  • Fri, Nov 3 2006 8:11 PM In reply to
    • dennislink
    • Denver
    • Posts 348
    • Points 4,035
    Re: No Audio on Capture
    One possible problem is a feedback loop.  If you are using a mixer and have audio from both the computer and the analog source feeding the camera, the 2 will sometimes cancel each other out.  The solution here is to turn off or disconnect the computer's audio.
    Good Luck.
    Core Duo 2.4 GHz 2GB RAM nVidia Quadro FX 550 [view my complete system specs]
  • Fri, Nov 3 2006 8:28 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 707
    • Points 8,565
    MediaGuy4:
    I went from 5.2.4 to 5.6.1 and now have the exact problem with a DSR-45 (video no audio).  My solution is to simultaneously record to a tape as I go thru the deck and out via firewire and capture in Avid.  I reuse this tape over and over.  At least this way, I get audio, and I don't have to capture to tape first and then capture to Avid again.
    If you find a solution to this please post back.
    JR
    Media Composer v3.1.1-IE7-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial/Max set to 2048/4092MB... [view my complete system specs]
    That's right...an xw8000.
  • Fri, Nov 10 2006 10:09 PM In reply to
    • MediaGuy4
    • Foxboro, MA
    • Posts 17
    • Points 230
    Great solution! Thanks.  I'm not happy with 5.6.2...  Also having problems with the Media Creation settings not saving.  What gives?
  • Wed, Jul 11 2007 11:24 AM In reply to
    • niCKed
    • Posts 154
    • Points 2,105
    I am having the exact same problem with my DSR-11... it's a real pain in the ... neck.
    Come on AVID.. sort it out!!
    (Maybe it's a conspiracy to make us go over to FCP ?)
    Intel P4 3.00Ghz 2 Gb RAM WinXP Pro GeForce 7600 GS Audigy2 Asus P4C800 MB 80Gb System Drive 1500Gb Capture Drives ADS Pyro Card DSR-11 [view my complete system specs]
  • Wed, Jul 11 2007 4:19 PM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 143
    • Points 1,880
    This has been an ongoing problem first reported here in September of last year.  Supposedly, a fix is in the works.  We can only hope and wait.
    Check out the following threads:
    http://www.avid.com/exchange/forums/thread/148840.aspx
    http://www.avid.com/exchange/forums/thread/210910.aspx
    http://www.avid.com/exchange/forums/thread/231541.aspx
    - Dell Precision 670 - Dual Xeon processors (2.8) - 4 gigs of Ram - nVidia 1400 (driver 7.7.1.8) - Creative SB X-Fi sound card - 120 Gig boot hard... [view my complete system specs]
