Latest post Wed, Oct 31 2012 5:31 PM by camoscato. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Oct 23 2006 11:17 PM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 501
    • Points 6,755
    When I use Avid DVD 5.2.1 and I send to DVD one step I get 4:3 DVD but I want 16:9. What to do?
    Avid Media Composer 8.4 Win 10 and MacBook Pro 2017 [view my complete system specs]
  • Wed, Oct 25 2006 9:21 AM In reply to
    • wmcole
    • Posts 573
    • Points 7,615
    Re: When I use Avid DVD 5.2.1 and I send to DVD one step I get 4:3 DVD but I want 16:9. What to do?
    Consult the Help->Avid DVD by Sonic Help menu.  When the online help manual opens look in the index under "aspect ratio->movies".
    HP z840 dual 8-core; PCI slot 3, Creative SB X-Fi audio card; 32 GB Ram; 4 x 1 TB RAID 5 internal SATA Western Digital Caviar Green Media drives (appears... [view my complete system specs]
    wmc
  • Wed, Oct 25 2006 10:40 AM In reply to
    • Ivo
    • Germany
    • Posts 501
    • Points 6,755
    But this is just when you send it to DVD Authoring, not when you use send DVD one step!
  • Wed, Oct 25 2006 6:05 PM In reply to
    • SS_Scott
    • Joined on Wed, Oct 25 2006
    • Posts 28
    • Points 330
    that's an interesting issue.  the software is not recognizing your timeline as 16:9, so you have to manually override in the movie attributes window when the application is open.  Here's a rough workaround.  Send your timeline to Avid DVD by Sonic, create a movie with it in Avid DVDs timeline.  go in the movie attributes window and change the setting to 16:9.  Close Avid DVD.  go back to your timeline in Avid and try the one-step again.  More like a 3 step, but it should work as long as the same asset is being referred to in the one step as was imported into Avid DVD.  once you change the assets aspect ratio in Avid DVD, it should be changed for all future projects using that asset.
  • Mon, Oct 30 2006 8:27 AM In reply to
    • Ivo
    • Germany
    • Posts 501
    • Points 6,755
    Unfortunately it´s not working. The 16:9 setting is not in the project preferences settings saved. So I get the 4:3 DVD again.
  • Mon, Oct 30 2006 2:32 PM In reply to
    Try the track asset itself. Click on the track, and check it's property. It should have an option in the track property for 4:3 and 16:9. Select 16:9.
    Alex Alexzander
  • Mon, Oct 30 2006 4:13 PM In reply to
    • Ivo
    • Germany
    • Posts 501
    • Points 6,755
    There is no possibility in the track asset. I can see the aspect ratio in the movie properties but I can´t change them in the timeline just the movie propertries for the whole dvd. Even when I set the Q-Ref to 16:9 it´s again 4:3
    in the movie properties.
  • Fri, Apr 25 2008 9:29 PM In reply to
    • wgeer
    • Joined on Fri, Apr 25 2008
    • Posts 1
    • Points 15
    Were you ever able to get DVD One Step to work for 16x9 or did you have to use an external program?
  • Sat, Apr 26 2008 8:00 AM In reply to
    • Ivo
    • Germany
    • Posts 501
    • Points 6,755
    No, I never get it to work. I could just use the send it to button to have 16:9. But mostly I use a normal DVD recorder today, so I don't have to render all effects.
  • Thu, May 27 2010 9:33 AM In reply to
    • tenorsax2
    • Joined on Fri, Mar 30 2007
    • Germany
    • Posts 43
    • Points 545
    Over two years later, any news on this?
    I have a 25i project with DV420 footage in 16:9 in MC4.0.5. Export as QTRef with Display Aspect Ratio "16:9 square pixel (1024x576). Avid DVD displays it as 4:3. Switching the "title" in Avid DVD to 16:9 results in black bars on the left and right side. Wonderful.
    I want my Liquid back. ;-)
    Is there any EASY possibility to burn a DVD from Avid MC? Avid DVD seems not to be a professional solution for me.
  • Wed, Oct 31 2012 5:23 PM In reply to
    • Matt Wielgos
    • Joined on Fri, Jan 6 2012
    • Cincinnati, Ohio
    • Posts 36
    • Points 510
    Did you ever resolve this issue? It's now 2012 and I am still not getting Avid to burn an HD DVD!
    System 1: Avid Media Composer 8.0.1, Windows 7 64 bit Pro, SP1, Intel Core i7-2720QM CPU @2.20 Ghz. 16 GB ram. NVidia NVS 4200M w/drv. 9.18.13.2078. Dell... [view my complete system specs]
  • Wed, Oct 31 2012 5:31 PM In reply to
    Anawim:
    Please don't post a question on a dead thread in a forum for a discontinued product you don't own that's a duplicate of a question you already posted that already has an answer.  :)
    Anyone wanting to help, go here:
    http://community.avid.com/forums/t/114170.aspx
    Media Composer 2018.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
