Latest post Thu, Oct 19 2006 7:05 PM by anomaly_7. 17 replies.
  • Thu, Oct 19 2006 3:55 PM
    • anomaly_7
    • Joined on Fri, May 12 2006
    • New York
    • Posts 94
    • Points 1,215
    No Audio During Capture!!!
    I am currently running AVID Media Composer 2.6.1 on a Quad G5 PPC with Mac OSX 10.4.6.
    Before I installed the upgrade the Audio was fine, I had levels and heard the audio just fine. After I upgraded to 2.6.1 I lost the audio.
    Can someone please help?
    Sean
    2.5 Ghz Intel Core 2 Duo Macbook Pro, 4GB Ram. Mac OS X Leopard 10.5.5. Avid MC 3.1.2. [view my complete system specs]
  • Thu, Oct 19 2006 4:00 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Re: No Audio During Capture!!!
    Possibly but can you please tell us how your audio is connected? FW?> Analog? Mojo? No Mojo?
    It's all in the details.
  • Thu, Oct 19 2006 4:04 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    I have a DVD player connected to my dv deck via rca. the dv deck gets levels and the speakers conected to the deck produces audio. The deck is connected to the Quad via firewire 400. I tried another firewire cable but nothing happened.
  • Thu, Oct 19 2006 4:06 PM In reply to
    And the audio input settings on the capture tool are set to....?
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Thu, Oct 19 2006 4:21 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    Host-1394...
  • Thu, Oct 19 2006 4:25 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    In that config, you must capture video at the same time...even if it's black. Are you?
  • Thu, Oct 19 2006 4:32 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    the audio and video are coming from the same source thru the same firewire cable...does that mean anything? When I do capture, I see the picture...just no sound.
  • Thu, Oct 19 2006 4:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    And is the audio input set to OHCI?
  • Thu, Oct 19 2006 4:56 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    that is not an option in Media Composer...Line In, Digital IN and Host-1394 are my only choices
  • Thu, Oct 19 2006 5:19 PM In reply to
    Have you actually captured?  In the past there was an issue with FW audio not registering on the meters during capture, but once the clip was captured it was there and fine.  Is that happening?
  • Thu, Oct 19 2006 5:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Host -1394" is the same thing. They just changed the description.
  • Thu, Oct 19 2006 5:25 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    Tried but not successful...I hit record for a bit and then stopped, when I hit play the picture was good but still no audio...
  • Thu, Oct 19 2006 5:35 PM In reply to
    Jeez... this is an odd one... a few total long shots:
    Does the CPU mute button make any difference?
    44.1 vs. 48khz issue?
    You have audio from the DVD player to the DV Deck, and audio out via the speakers.  But what about audio out via FW?  Can you test that?  Can you pop in a normal DV tape and get audio into the Avid?
  • Thu, Oct 19 2006 5:55 PM In reply to
    • anomaly_7
    • New York
    • Posts 94
    • Points 1,215
    Odd indeed! I just popped a DV tape into the deck and got levels into the AVID...but that's not all. Then , I played the DVD thru the deck and got levels as well! But that's not all! I removed the tape from the deck and the audio was still there, and as I started to write this email I switched back to AVID and guess what...no levels.
    The audio plays from the DVD player for a mere few seconds then cuts out. If I put a tape in the deck the audio plays from the DV tape and that's all. If I stop the tape the audio plays from the DVD player for a few secs.
    P.S. The mute button doesn't make any difference and it's not the 44.1 vs. 48 either. I tried both.
  • Thu, Oct 19 2006 6:15 PM In reply to
    OK... but this tells us that the Avid is in fact correctly receiving an audio signal directly from the DV deck.  So the issue is what is causing the audio from a secondary device, piping through the DV deck, to conk out?  If you leave a DV tape in, stopped, does the DVD audio maintain?  Is there possibly a feature that dictates whether audio out of the DV deck is coming off the record head or the playback head?  I'd explore the audio out settings on the deck.
