Latest post Fri, Apr 25 2008 11:41 AM by bazzybaz. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Thu, Oct 19 2006 12:52 PM
    • Greyo
    • Wales
    • Posts 488
    • Points 6,580
    Export 24fps footage to 25fps QT REF file
    Hey,
    I was wondering if someone could explain to me how to take 24fps footage and export a 25fps QT movie so that I can use it to create DVD's.
    I have tried manually changing the frame rate of the QT file as it exports but this just adds a duplicate frame which causes a lag effect on the footage especially during motion. Is there a way to get the footage out by speeding up? I don't have a Mojo.
    Is it as simple as adding a motion effect with a 4.1x speed change?
    Have help would be much appreciated
    All the best,
    Ian
    Windows XP Duel Xeon CPU 3.06GHZ 1.00GB of Ram Nividia Quadro NVS with AGP8X [view my complete system specs]
  • Sat, Oct 28 2006 10:33 AM In reply to
    • Nice Guy Dave
    • Brighton, England
    • Posts 57
    • Points 790
    Re: Export 24fps footage to 25fps QT REF file
    Hi Ian
    Yes I agree there should be a simple way of changing the framerate of a video-only movie.  Perhaps in Quicktime Pro you can edit the metadata?  I'm not sure.
    My workaround is to export to a targa stream then re-import into a 25fps project.  The audio resampling is done in audacity, imported into the same project and combined with the video for a new export.
    Slow and expensive space-wise (especially if you're doing a whole feature) but it's the best option I've found so far.
    Good luck
    David
    MC 3.0, Analogue Mojo, HP xw8000 Dual Xeon 3.06GHz, 3GB RAM WinXP Pro SP2, Quadro FX 1100, nVidia driver as included in 3.0, 2Tb of G-Sata on... [view my complete system specs]
  • Sun, Oct 29 2006 12:56 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,338
    • Points 38,415
    Nice Guy Dave:
    I do something similar, except that I use After Effects.
    I export a QT ref file from Avid which simultaneously exports an AIF file of the audio.   I open that AIF in Audition, speed it up the by 104.17% and save it as WAV.   Next I open the WAV and the QT ref file in AE and interpret the video footage as 25 fps.
    I drop both the interpreted QT ref and the WAV onto a timeline and mute the QT ref.  Render the lot to a suitable format and you're done.
    The process with AE is slow, but it would have to be faster than the targa path if you have access to AE.  You could also do something similar with Premiere.  I've been told that you can also resample the audio in Premiere but I've never done that.
  • Sun, Oct 29 2006 1:01 AM In reply to
    • Greyo
    • Wales
    • Posts 488
    • Points 6,580
    I've found that you can speed the audio up in avid using audio suite time compression plugin and it works fine for what I wanted to do. Though it certainly aint a mastering technigue.
  • Sun, Oct 29 2006 12:45 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    This is indeed a workflow black hole for PAL film people. My workaround has been Cinema Tools on the Mac for some time as it has a conform to frame rate feature which will speed a 24fps QT up to 25fps. The only problem is that it won't work on a QT ref file, so you will need to export a self contained QT out of Avid and then process. It handles the audio speed also. Mac only of course.
    Of course the easiest way to make quick 25fps DVD's is to playout of Mojo with Film options set to 25fps and use a set top DVD recorder. If you had a spare laptop with FCP on and a Canopus box, you could also playout of Avid at 25fps and capture direct to FCP and encode from there.
    If Avid were prepared to use the full QT toolkit this could be accomplished direct inside the Avid software. QT files playback speed is simply determined by a few flags inside their track structure. You can look at this using a small tool like Dumpster:
    ftp://ftp.apple.com/developer/Quicktime/Tools/Programmers_Tools/Dumpster.dmg
    There is a really good tool which can do this with QT ref files, but it comes as part of a package for $99. The frame rate converter is a separate app, but the developer won't sell it separately, so its $99 for this solution.
    http://homepage.mac.com/dvd_sp_helper/Commerical/DFT.html
    --Mark
    MacBook Pro 2.16 , G5 Dual 2.0 , MC 3.0.5 [view my complete system specs]
  • Mon, Oct 30 2006 11:58 AM In reply to
    • pierreh
    • Paris, London
    • Posts 588
    • Points 7,105
    mark.burton:
    Hi Mark,
    I do that too when I need to make a DVD for instance. Export as Ref works, as long as you force the Avid to mix the tracks - which creates a new AIFF file in the export folder. Then you can batch conform the clips to 25 and it works perfectly. It's faster because only the sound gets processed when you export, and also it takes much less space.
    Pierre
    At home: MacBookPro 2.5Ghz, 4Gig Mem, Mojo At work: MacPro 2.6Ghz, 3.5Gig mem, Mojo SDi [view my complete system specs]
  • Mon, Oct 30 2006 12:09 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    Hi Pierreh,
    Thats odd. I have never had a QT Ref file convert between 24 and 25 in Cinema tools without getting strange results - usually after the first clip in the Ref file, the movie turns to coloured static.
    The audio file is always mixed down though, so not sure how that makes any difference.
    Can you explain what you mean by 'batch conform the clips' as surely you only have one QT ref file after the export?
    Mark
  • Mon, Oct 30 2006 7:18 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    It seems that by using Dumpster you can alter only a few values in a Quicktime file to make it play at 25fps instead of 24fps. This way you can export a 24fps Quicktime reference file from Avid (much faster) and by making four value changes to the file in Dumpster (takes 20 seconds) it will now play with 1:1 frame acuracy at 25fps with audio also sped up to match. Perfect for making DVD's with no pulldown.
    I made a quick webpage to explain this procedure for the Mac, see if it works for you:
    Convert 24 to 25 Mac
    --Mark
  • Mon, Oct 30 2006 7:33 PM In reply to
    Great job! Thanks.
  • Mon, Oct 30 2006 9:05 PM In reply to
    • doronsuliman
    • Joined on Sat, Oct 28 2006
    • Tel Aviv, Israel
    • Posts 20
    • Points 280
    Can't change anything on file's metadata. Additionally, screenshot looks nothing like what I got (WinXP version) - see screenshot.
  • Mon, Oct 30 2006 9:08 PM In reply to
    • Greyo
    • Wales
    • Posts 488
    • Points 6,580
    Does it only work on MAC's?
  • Mon, Oct 30 2006 11:09 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    Sorry guys. I should have made that a bit clearer. I have updated the page to reflect the fact this was done with the Mac OS X version of Dumpster.
    Although there is a Windows version of the app which should be able to do the same, its a bit more complex as it uses 'strings' to represent the values. I was able to find all the relative entries in the Windows version Dumpster apart form one - the sampleRate value in Sample Descriptions.
    In order to change the values you need to know the equivalent string value to represent the number. For example for the timeScale value, $00000271 would equal 625.
    I could not figure out what the string would be for 50000 and there seems to be a section not being displayed anyway, so it might not even be possible. Sorry about that.
    --Mark
  • Tue, Oct 31 2006 7:23 AM In reply to
    • doronsuliman
    • Tel Aviv, Israel
    • Posts 20
    • Points 280
    :( Thanks for updating the site, though.
  • Tue, Oct 31 2006 7:39 AM In reply to
    • pierreh
    • Paris, London
    • Posts 588
    • Points 7,105
    mark.burton:
    Sorry, I should have mentioned that I often export many mini-sequences and therefore have quite a few QuickTime files in the export folder. Then I use the Batch Conform feature of Cinema Tools to convert all of them in one go.
  • Tue, Oct 31 2006 12:05 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    Looks like you can use the Windows version of Dumpster to do this job. Its not as elegant as the Mac method, but still very quick and easy:
    Convert 24 to 25 PC
    --Mark
