Latest post Wed, Mar 31 2010 9:19 PM by danielm. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Aug 2 2006 7:23 PM
    • ekatarina
    • Toronto
    • Posts 74
    • Points 1,040
    DID_READER_SAMPLE_SIZE_INVALID
    Hello everyone,
    I hope the heat wave will stop any second in North America, or maybe... going back to Avid. I have tried to decompose one short sequence with a lot of effects in it. A few seconds later decomposing stopped with the message:
    - Exception:DID_READER_SAMPLE_SIZE_INVALID
    I have never seen this before but it caused me not to be able to reopen the sequence I was planning to online, not even version from the attic from the day before. Other sequences work without any problems, but just this one.
    Anyone, please?
    Vito
    Avid Xpress Pro 5.6.2. Dell Precision Workstation 530 Xeon Dual Processor 2.4 GHz RAM 3 GB; 480 GB ATA external; 1 X 320 GB external Fire wire Drive;... [view my complete system specs]
    Repetio mater studiorum est.
  • Wed, Aug 2 2006 10:01 PM In reply to
    Re: DID_READER_SAMPLE_SIZE_INVALID
    Sounds like a corrupt file.
    In Console type 'repairsequences'
    See if it flags a particular file or two. You can also split the sequence up temporarily and decompose. Maybe you can find out where the problem is.
  • Wed, Aug 2 2006 10:40 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    Hmmm.. sounds like a chunk of bad audio- can you open the sequence with your media drives offline?
    JDS
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
  • Fri, Aug 4 2006 8:27 PM In reply to
    • ekatarina
    • Toronto
    • Posts 74
    • Points 1,040
    Corrupted file for sure, "repairsequances," did not work. In console I do recall on the day when my problem happened, there was a message that mentioned audio sample rate. I did try fixing and changing the sample rate of all audio clips used in the sequence, although I am sure they are all the same.
    Anyway, at the end by accident I tried deleting video track 1, than video track 2, and I found that all my title cards for just one sequence are corrupted. I recreated them, and it is smooth now. It is scary to know that it just could get corrupted like that.
    Thanks for suggestions.
    Vito
  • Fri, Aug 4 2006 9:53 PM In reply to
    • Doc Avid
    • Posts 2,321
    • Points 25,890
    That's interesting to know- usually a "sample" error refers to audio.
    JDS
  • Wed, Mar 31 2010 9:19 PM In reply to
    • danielm
    • Joined on Tue, Jan 23 2007
    • Denver, Colorado
    • Posts 10
    • Points 120
    Found this thread while encountering my own DID_READER_SAMPLE_SIZE_INVALID error message.
    I found that the sequence would not play if I isolated Video Track 2 on playback.
    I took my sequence and subclipped it into two halves.  One played, the other didn't.  I took the one that didn't play and subclipped that into two halves.
    Eventaully I would up with a subsequence about 30 sec long.  I was able to find one bad .TIFF import.
    Reinserted the .TIFF from the bin to the original sequence and all was well.
    HP Workstation xs8200,dual Xeon 3.40 GHz. Nvidia Quadro FX 1400. Windows XP SP3. Avid Media Compose Adrenaline HD, Avid software 2.2.7. Quicktime version... [view my complete system specs]
