Hello,
I need the 5-second-timer on the "Move Clip Up/Move Clip Down" command to be switchable (on, off, custom value). With the current 5 second timer tidying up a sequence or working on syncmaps with 8 or more cameras is painfully slow:
Example syncmaps: Imagine overwriting 9 videotracks with this method on 120 clips: Waiting time (5 seconds added up): At least 80 minutes!!
Example cleaning a squence: You want to move a clip from V3 to V1, but have a clip on V2 that is overlapping 2 frames. You don't notice the overlap due to being zoomed out on the sequence and wonder why your edit is different. Before the overlap would have been cut to the boundaries of the clip you moved down to V1.
The current behaviour was introduced in 2021.3, see the 2021.3 What's new document:
With this release, you can move segments in the Timeline up and down without leaving filler each time the segment is moved consecutively. This also applies to moving segments horizontally using the Trim left and Trim right keys. IMPORTANT: This only applies with repeated up/down and left/right movement. If there is a change to the segment selection or more than 5 seconds have passed after the last move, moving segments will leave filler behind.
For assistant work (mainly using syncmaps) the old behaviour (overwriting / leaving filler) is essential and is keeping me on the 2020.X versions. I'd love to upgrade my 10+ licenses in the post house I work in, but currently this is a deal breaker.
Best regards,Christian
+1
If it's possible to make it "toggle" to the old behavior (overwriting) by holding down certain keys, that would be perfection!
+2
+3
Yes please! We need this ability to toggle on and off.
+4
Editing Movie Magic.
My Equipment & System Specs
Media Composer Ultimate 2022.12.2 | Pro Tools Studio 2022.21 | Sibelius Artist 2022.12
Christian: Hello, I need the 5-second-timer on the "Move Clip Up/Move Clip Down" command to be switchable (on, off, custom value). With the current 5 second timer tidying up a sequence or working on syncmaps with 8 or more cameras is painfully slow: Example syncmaps: Imagine overwriting 9 videotracks with this method on 120 clips: Waiting time (5 seconds added up): At least 80 minutes!! Example cleaning a squence: You want to move a clip from V3 to V1, but have a clip on V2 that is overlapping 2 frames. You don't notice the overlap due to being zoomed out on the sequence and wonder why your edit is different. Before the overlap would have been cut to the boundaries of the clip you moved down to V1. The current behaviour was introduced in 2021.3, see the 2021.3 What's new document: With this release, you can move segments in the Timeline up and down without leaving filler each time the segment is moved consecutively. This also applies to moving segments horizontally using the Trim left and Trim right keys. IMPORTANT: This only applies with repeated up/down and left/right movement. If there is a change to the segment selection or more than 5 seconds have passed after the last move, moving segments will leave filler behind. For assistant work (mainly using syncmaps) the old behaviour (overwriting / leaving filler) is essential and is keeping me on the 2020.X versions. I'd love to upgrade my 10+ licenses in the post house I work in, but currently this is a deal breaker. Best regards,Christian
Good news! This feature has been added in the 2021.9 release of Avid Media Composer. 2021.9 will be available before the end of this month.
Philip Kapadia: Good news! This feature has been added in the 2021.9 release of Avid Media Composer. 2021.9 will be available before the end of this month.
Can you post a link to the "What's New in 2021.9" list?
Gerry
gswilson: Philip Kapadia: Good news! This feature has been added in the 2021.9 release of Avid Media Composer. 2021.9 will be available before the end of this month. Can you post a link to the "What's New in 2021.9" list? Gerry
I don't think there is an official one yet. It's usually posted on this forum just after it's out.
Philip Kapadia: I don't think there is an official one yet. It's usually posted on this forum just after it's out.
I know how and where the features list is posted. I'm just curious as to how you are in a position to announce contents of the "What's New" list before the Mods or anyone from Avid.
gswilson: Philip Kapadia: I don't think there is an official one yet. It's usually posted on this forum just after it's out. I know how and where the features list is posted. I'm just curious as to how you are in a position to announce contents of the "What's New" list before the Mods or anyone from Avid. Gerry
I wouldn't announce this without avid making it public on yesterday's what's new zoom meeting.
Is this feature available yet? I'm in MC 2021.12 but can't find where to toggle on/off.
Is this implemented in Avid 2022.4? or 2022.7?
I'm eager to have the old behavior back.
