Latest post Wed, Dec 4 2019 2:32 PM by smrpix. 4 replies.
  • Tue, Dec 3 2019 5:23 AM
    Head and Tail Fade not working
    While working with some clips, i can put a head fade or tail fade on the clip, but not if it is edited next to another clip in the timeline.
    This behavior is showing in MC and MC first.
    on 2019.11 with new settings
  • Tue, Dec 3 2019 10:55 PM In reply to
    Re: Head and Tail Fade not working
    ....does that effect only work on the top and tail of a sequence?...that would explain it...
    ...i never really worked with that effect much...
  • Tue, Dec 3 2019 11:49 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 646
    • Points 7,325
    to fade out and in, keep a minimum of one frame between your clips and it will work.
    symphony 2019.11 - win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (431.86) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Wed, Dec 4 2019 12:50 AM In reply to
    ...great tip...I will try that....
    ...does that create a 1 frame gap?...or do you put black or filler there first?
  • Wed, Dec 4 2019 2:32 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,410
    • Points 17,395
    It works like a dissolve.  Black or filler are fine.  If you have it butted up against a clip it's a dissolve starting or ending at the cut point depending on whether you use the head or tail version.
    I tend to use it when I want to time my fades/dissolves visually rather than numerically.
