Hi Editors:
I have a few clips recorded on an Atomos Ninja Star external micro video/audio recorder. The video clips where recorded in Pro Res 422 @ 1080p 23.976 with a total of 4 audio channels. The audio tracks are grouped as two seperate Stereo pairs as part of the clip. MAC OS can see there are indeed 4 tracks. However Media Composer doesn't want to import the files. I get a strange error message...... "An unexpected error occurred while importing the Quicktime Audio Tracks. The imported audio tracks maybe unusable. Would you like to continue the import ?" If I continue the import MC hangs. (??) I went through the knowledge base and this forum but could not find a scenario which fit my exact issue. I am running MC version 8.5.0 Are there proper settings for this ? I am assuming MC can well import video clips with more than two channels ? What are the settings ?
Sincerely,
Mark Job
The thing is don't peak too early in life.
What happens if youl link the xclis rather than import them?
Alt drag the clips to an Avid bin or use the source browser under input after right clicking in a bin.
I view import as a legacy ingest method as it gets few updates where as AMA linking is being updated all the time.
Broadcast & Post Production Consultant / Trainer VET
Hi Pat:
Pat Horridge:What happens if youl link the xclis rather than import them?
Thanks Again Pat,
Mark
It depends on how you output but to be sage you can consolidate/transcode those clips to make Avid Media just to end up just as if you had imported them.
If Avid supports the codec you should be able to consolidate the clips. If it doesn't then Transcode.
Pat Horridge:If Avid supports the codec you should be able to consolidate the clips. If it doesn't then Transcode.
Thanks Again,
Try consolidate first.
Also if you make sub clips (selects) of your rushes and consolidate those you will reduce the amount of Avid media you need.
Or consolidate the complete clips for coplete copies.
The bueaty of subclipping is you can name those subclips with meaningful names and that will ripple across to the consolidated clips.
Yes this is quite useful information. Thanks.. I never really had hopped on the AMA Wagon before, as 90 % of my post was traditional ingest and output, but now I'm getting handed more and more interesting and multi-faceted media to wrangle, so this process is definitely faster and uses much less hard drive space then a straight ingest does.
Unless people have a speciific workflow AMA linking is king. It also makes the conform a lot easier. Batch importing is inefficeint.
Also when you AMA link you can do it by source folder so it will automatically create a bin structure to match the source folder structure. Cool.
Pat Horridge:Unless people have a speciific workflow AMA linking is king. It also makes the conform a lot easier. Batch importing is inefficeint.
