Latest post Wed, Dec 11 2019 2:56 PM by pierreh. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Nov 19 2019 2:08 PM
    • Posts 10,890
    • Points 226,880
    Media Compposer 2019.11 available.
    Great news…….  a new November release of Media Composer has just launched.
    Status of Support Plan: The ability to launch this Media Composer 2019.11 software is dependent on the status of a customer’s Upgrade and Support Plan on the date this software version is released - today November 18th, 2019.
    Location at Launch: Updates to Media Composer are available from Avid Link, MyAvid Master Account and the Avid Download Center (login and password required).
    What’s Changed in 2019.11:  The following has changed in Media Composer v2019.11.
    IMPORTANT: macOS Support
    - Media Composer v2019.11 does NOT currently support macOS v10.15 (Catalina).
    Drawing Shapes and Text with Titler+
    -  In previous releases, when working with shapes in Avid Titler+, drawing a shape displayed in the middle of the screen. You could then move the shape to the desired location. With this release, you can simply draw the shape at the desired location.
    -  When creating text with Titler+, simply click and type. There is no need to draw a box first.
    Additional Support for XAVC HD Intra (CBG) Class Resolutions
    -  Additional XAVC HD Intra CBG resolutions are supported with this release. The following table lists the XAVC HD Intra CBG Class resolutions.
    Note that XAVC HD Intra CBG Class 200 MXF is not supported for OP1a export or media creation. It is supported for OP-Atom media creation.
    What’s fixed in 2019.11:  The following has been fixed.
    * Bug Number: MCCET-3346. You might have received an “Exception: Audio Buffer for TMF Export” error when performing a Send to Playback.
    * Bug Number: MCCET-3321. When importing an XML with markers, the markers appeared in the Timeline but the Markers window was blank.
    * Bug Number: MCCET-3343. With a Japanese locale, characters appeared corrupted in the Project format tab of the Settings window.
    * Bug Number: MCCET-3327. When entering fade values in a Fade Effect, the opacity in the fade would go from 0 to 1 instead of 0 to 100.
    * Bug Number: MCDEV-12124. Typing in the Effects Palette search field would crash if a Symphony Color Correction relationship effect had been deleted or muted in the Timeline.
    * Bug Number: MCCET-3192. The Timeline jumped to the blue bar if you clicked one of the segment mode buttons on Timeline Palette.
    * Bug Number: MCDEV-11970. Reloading frames when opening multiple bins in Frame view was very slow.
    * Bug Number: MCDEV-11982. If the Motion Effect Editor window was open, pressing the K (pause) key did not stop playback.
    * Bug Number: MCDEV-11827. The Timeline Video Quality menu reverted to a previous setting when a project was re-opened.
    * Bug Number: MCDEV-12099. When in Frame View, subclip thumbnails recached every time the bin was opened.
    * Bug Number: MCDEV-12055. Match Frame selected clips from the wrong track.
    * Bug Number: MCDEV-11989. The bin did not refresh after a save when Set Bin Display was set to Show Reference Clips.
    * Bug Number: MCDEV-11998. In some instances, performing Waveform Sync on a sequence resulted in an “AutoGainPane EXCEPTION not handled” error.
    * Bug Number: MCDEV-10649. Performing Choose Column did not place the newly added column to the right of the selected column.
    * Bug Number: MCDEV-11048. Creating a new bin or renaming a bin temporarily blanked out Side Bar data.
    * Bug Number: MCDEV-11772. (Mac) In some instances, Media Composer crashed when turning off Dual-Monitor configuration and switching between workspaces.
    * Bug Number: MCDEV-11895. In some instances, deleting media files from a bin deleted columns and caused Media Composer to crash.
    * Bug Number: MCDEV-11906. Long clip and sequence names were cut off.
    * Bug Number: MCDEV-12000. Changing the default Transition Manipulation icon in Timeline toolbar did not persist between launches.
    * Bug Number: MCDEV-12002. Transition Manipulation was unexpectedly disabled when clicking in the ruler if the Timeline Settings were set to click the TC Track or Ruler Disables Smart Tools.
    * Bug Number: MCDEV-12017. The Color picker didn’t show the selected bin background color.
    * Bug Number: MCDEV-11565. The Composer and Timeline windows sometimes used an incorrect font.
    * Bug Number: MCDEV-11918. Show Bin in Sidebar failed if the bin was in a folder.
    * Bug Number: MCDEV-12034. Media Composer vaporized when running out of space during render.
    * Bug Number: MCDEV-12031. (Mac) (Titler +) Grouping was not working with Title +.
    * Bug Number: MCDEV-12018. (Titler +) Field interpolation was lost when adjusting roll/crawl position.
    * Bug Number: MCDEV-11945. (Titler +) In some instances, spaces were inserted at the beginning when typing text for a title.
    * Bug Number: MCDEV-10457. (Titler +) The contents of the title did not change correctly when adjusted using the Global|Foreground Level slider.
    * Bug Number: MCCET-3198. (Mac). In some instances, dragging items from Interplay Access did not always place the selected items in the bin.
    * Bug Number: MCCET-3121. You might have received a “PMM insufficient media” error when performing an Audio Punch-In.
    * Bug Number: MCCET-2618. The HW/SW button might not have detected an attached hardware device.
    * Bug Number: MCCET-3082. Group clips did not match-frame accurately if the group clip had a different frame rate than the project.
    * Bug Number: MCCET-3205. In some instances, MXF DV25 420 files could not be imported.
    * Bug Number: MCCET-3188. When a search was filtered, Media Composer would freeze when editing Timeline Clip Notes in the Timeline Clip Notes window.
    * Bug Number: MCCET-3203. Audio waveforms were offset on a muted audio clip, if the previous segment on the Timeline had a dissolve effect added that ended on a cut.
    * Bug Number: MCCET-3057. Group clip names were not in order.
    * Bug Number: MCCET-3271. You could not adjust 3D warp border and perspective parameters by 1 using arrow keys.
    * Bug Number: MCCET-3232. Linking BWF files linked as non-drop frame even if drop frame was selected.
    * Bug Number: MCCET-3240. Media Composer inadvertently allowed you to drag sequences without frame-rate conversion from Interplay into the Source monitor.
    * Bug Number: MCCET-3185. Effects became unrendered after a sequence was consolidated twice. This fix applies to media consolidated with this release.
    * Bug Number: MCCET-3141. Media Composer would intermittently hang, vaporise, and display a Breakpad message, when performing the following actions: adding In and Out points, trimming, double clicking on clip from Product Management window (to be loaded on Source Monitor), loading a sequence from the bin, clicking on the Lift button, entering Timeline Fast menu from right click.
    * Bug Number: MCCET-3173. In some instances the Text View button, Frame View button, search field, thumbnail slider, and scrollbar would disappear from the Source Browser.
    * Bug Number: MCCET-3182. Sometimes the system would hang when performing Loop Play and then switching workspaces.
    * Bug Number: MCCET-3076. Color space metadata was not included in QuickTime when AMA linking.
    * Bug Number: MCCET-3254. You might have received an Exception error after dragging and dropping the Stabilize effect to a segment on the Timeline.
    * Bug Number: MCCET-3075. Some DPX exported images were distorted/corrupted.
    * Bug Number: MCCET-3290. You might have received “FatalAbort VDM Scheduling failed” and “MultiFrameCombiner” errors when trimming.
    * Bug Number: MCCET-3253. Newly created bins using shortcut keys Cmd+N (Mac) or Ctrl+N (Win) could not be renamed easily.
    Media Composer 2019.11 Documentation: The “ReadMe” document for this release of Media Composer 2019.11 is available on the Knowledge Base.
    Limitations Media Composer 2019.11:  For the list of limitations in Media Composer 2019.11, please references the “ReadMe”.
    How to obtain the Media Composer 2019.11 Update: The new Media Composer 2019.11 is available today,  Monday November 18, 2019 @ 12:00 Noon ET.
    1.  Customers who have an active support and upgrade plan will be notified of the availability of the 2019.11 via Avid Link and it it is available via Avid Link, MyAvid and the Download Center.
    2.  New perpetual and subscription Licenses purchased on or after Monday November 18, 2019 will also receive 2019.11.
  • Tue, Nov 19 2019 9:12 PM In reply to
    • Andrew
    • Joined on Wed, Apr 6 2011
    • Costa Mesa, Orange County, California
    • Posts 117
    • Points 1,350
    Re: Media Compposer 2019.11 available.
    I will agree that taking care of all the bugs first is more important than making it compatible to Catalina.
    Avid MC v2019.12.0, macOS Mojave 10.14.6, iMac 21.5-inch, late 2015 (purchased new on Jan. 2017), Processor: 2.8 GHz Intel Core i5, Memory: 16 GB 1867... [view my complete system specs]
  • Wed, Nov 20 2019 2:02 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,237
    • Points 14,950
    Andrew:
    Especially as it's still in its early stages - and widely known as Catastrophy-lina, or the Windows Vista of the Mac... Stick out tongue
  • Wed, Nov 20 2019 4:16 PM In reply to
    • Andrew
    • Posts 117
    • Points 1,350
    pierreh:
    Andrew:
    Oh gawd, I downloaded Catalina on my Mom's iMac (she doesn't have Avid).  I was not aware that this new OS is buggy.
  • Tue, Dec 10 2019 8:19 AM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 117
    • Points 1,420
    Well, 2019.11 is two steps forward, one step backward.
    Source and/or Record goes black after a while, there are already some reports about this.
    MC sometimes hangs at start up, for me it is during loading BCC.avx.
    Bins become unresponive after Transcode/Consolidate, after these sometimes you can't do anything in the bin. Selecting clips or sequences is grey instead of my chosen highlight color, closing with cmd+w is not possible, saving does not help, you have to close by clicking the x. After reopening everything is fine.
    Saved toolsets still get lost, I don't know how often I arranged my windows and tool but after a while the tool are gone again. For me it happens with the AudioTool, AudioSuite, EQs, TC-Window. I arrange them, so I habve them in sight and after a couple of days they are gone again.
    2019.11 is still better than the versions before but not quite perfect.
    Doyle
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.13.6, Avid MediaComposer 2018.12... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Wed, Dec 11 2019 2:56 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,237
    • Points 14,950
    Been using 2019 for the past 48 hours and beginning to like it. When I use the "Find Bin" button, it automatically opens the bin in a new Bin Container. Is there a setting somewhere that forces the bin to open in the Bin Container which is already opened?
