Latest post Fri, Nov 1 2019 11:25 PM by Nicanor72. 0 replies.
Page 1 of 1 (1 items)
  • Fri, Nov 1 2019 11:25 PM
    • Nicanor72
    • Joined on Sun, Dec 31 2017
    • Posts 1
    • Points 15
    Maker (locator) Column - Marker (locator) Comment Column in BIN
    I am scratching my head over this one. It seems super simple....
    Each source clip in the bin has a marker (once called locators). I can call up a "marker" column where I am able to see the locator icon. But I don't seem to be able to call up a "marker comments" column. However, if I type up in the bin header a custom column "marker comments" and hit enter, the custom column becomes "marker comments1" which indicates that "marker comments" is already taken. But if I look into the dropdown menu for "Choose Columns" there does not appear to be a "marker comment" available as an option.
    I am trying to avoid typing into the markers (locators) window. Since whatever I type into the source marker carries over to the sequence, if I am able to do "COMMAND" + "D" and column copy info directly into the source marker (locator), I can speed up my workflow.
    Hope this is doable and I am just not seeing the obvious.
    Thank you in advance.
