Latest post Sun, Nov 24 2019 12:57 PM by helmar7. 14 replies.
Page 1 of 1 (15 items)
  • Sat, Oct 19 2019 8:10 AM
    • helmar7
    • Joined on Wed, Jun 10 2015
    • Posts 13
    • Points 135
    Avid 2019.9 Performance Issues
    Hey all,
    i built a new System. Everything is freshly installed.
    I have the problem that the Avid performance is a bit laggy when i go through the timeline, zoom in an out, i scroll through the bins, go to trim mode etc. i have nearly always a slightly lag (0.5 sec).
    I able to work with avid, but it really annoying me!
    So some systemspecs:
    i9 7940x, system on ssd, 64gb ram, nvidia gforce 1070 (studio driver 430.86), avid 2019.9
    some more ideas would make me happy!
  • Sat, Oct 19 2019 12:06 PM In reply to
    Re: Avid 2019.9 Performance Issues
    What is your project format/frame rate, and what is your footage format/frame rate/file type? Does the problem happen with linked footage, or with media that has been transcoded/imported, or with all footage?
    Media Composer 2019.11 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Sat, Oct 19 2019 12:35 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    Seems to be a general problem!
    The one project is a dnxhd36  and no amas, the other a mixed project, both 25p 1080. So not really a big thing!
  • Sat, Oct 19 2019 2:30 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 207
    • Points 2,465
    What display size and screen resolution are you using. These all sound like instances in which Avid has to redraw some of the interface.
    Try reducing your display resolution to see if that improves performance.
    MC 2019.9 Asus Prime X299 Deluxe, 64GB of Memory, Core i9 7940x @3.1Ghz, Nvidia GeForce GTX 1070 Ti. Running Win10 Pro 64bit MC 2018.4 Dell Precision... [view my complete system specs]
  • Sat, Oct 19 2019 3:00 PM In reply to
    Open the Console. While you edit, see if any error or warning appears. Post it here.
    MC 2019.9, Windows 10, ASROCK X99M, Intel 5930K, Zotac RTX 2070 Super, 32GB RAM, Transcend 512GB M.2 SSD & Dell UP2718Q. MBP 2012 Thunderbolt, OSX... [view my complete system specs]
  • Sat, Oct 19 2019 3:54 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    Memory stats: physical = 65211 MB, virtual = 134217727 MB, restriction = 0 MB
    WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
    Set persistent image cache limit: 200.0 MB in C:/Users/Public/Documents/Avid Media Composer/AvidImageCache
    AWin32Mixer::Open inputMixerID = 4
    AWin32Mixer::Open - Failed to validate output mixer: outputMixerID 0 is invalid mixer
    Created ADM Device : 1394 Audio
    DirectSound ADM running on Windows OS Version Major=6 Minor=2 Build=9200
    Created ADM Device : DirectSound Audio
    AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
    MCBootstrap::gwhoami = 30
    Avid Media Access: Device monitor successfully initialized
    AVX Library V1.5
    OpenGL implementation found:
    vendor = Brian Paul
    renderer = Mesa OffScreen16
    version = 1.5 Mesa 6.4
    This OpenGL implementation does not support hardware texture render
    maximum render dimensions: = 1920 x 1080 at 8 bits per pixel channel
    vendor = NVIDIA Corporation
    renderer = GeForce GTX 1070/PCIe/SSE2
    version = 4.6.0 NVIDIA 430.86
    This OpenGL implementation supports hardware texture render
    AME CPU Buffer Deallocator Registered Successfully
    AME GPU Buffer Deallocator Registered Successfully
    MonCon Painters: GPU, CPU
    ACPL Transfer Type: OGL
    ACPL Transfer Buffer Type: Persistent
    ACPL Transfer Mode: NonOverlapped
    ACPL GPU Memory Pool Capacity: 4096 MB
    ACPL GPU Memory Pool Host Capacity: 1952 MB
    ACPL GPU Private Memory Pool Capacity: 3584 MB
    ACPL GPU Private Memory Pool Host Capacity: 0 MB
    ACPL GPU VRAM Capacity: 8192MB
    Newer CPU<->GPU bus speeds detected (3.6025)
    AAF DLL loaded from : C:\Program Files\Avid\Avid Media Composer\AAFCOAPI.dll
    AAF DLL version : 2.0.6 (10030) [1]
    DFM loaded. 244 entries initialized. Scripts directory 'C:\Program Files\Avid\Avid Media Composer\SupportingFiles\CodecToolkit_Config\'
    Setting chained toggle /Q7Container/EnableInternalProcessing_H264:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_AAC:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_MJPEG:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_TIFF:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_JPEG:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_PCM:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_ProRes:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_MPEG-2:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_DNxHR:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_DNxHD:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_Alpha:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_RLE:false
    Setting chained toggle /Q7Container/SupportMediaWithRoundedTrackLength:true
    Setting chained toggle /Q7Container/RedirectToQ7_26_IfAvailable:false
    Setting chained toggle /Q7Container/RedirectMediaWithRoundedTrackLengthToQ7_26_IfAvailable:false
    Setting chained toggle /Q7Container/Disable16BitImageFormatsSupport:false
    Setting chained toggle /GenericMXFContainer/MXFSuppressMCAMetadata:false
    Setting chained toggle /GenericMXFContainer/OverrideUnsupportedDistinguishedFrameLayout:true
    Setting chained toggle /Q7Container/TruncateMasterMobEssenceSlotsToMinumumCommonDuration:false
    Setting chained toggle /Q7Container/TreatVariableFrameRateAsConstantAverage:true
    Setting chained toggle /QuickTimeMediaContainer/TruncateFractionalStartOffsetsToFullFramePrecharge:true
    Setting chained toggle /AMPPlugin/Enable_DNx:true
    Setting chained toggle /AMAFI-SDK/DisableLoggingErrorMessagesOnContainerHandlerProbing:true
    Setting chained toggle /Q7Container/RedirectMediaWithMasterMobFillerToQ7_26_IfAvailable:false
    Setting chained toggle /AMPPlugin/Enable_DCP_J2K:false
    Setting chained toggle /AMPPlugin/Enable_IMF_J2K:true
    Setting chained toggle /AMPPlugin/Enable_J2K:true
    Setting chained toggle /AMPPlugin/Enable_DV_Based:true
    Setting chained toggle /AMPPlugin/Enable_CAT_AVCI:true
    Setting chained toggle /AMPPlugin/Enable_H264_Proxy:false
    Setting chained toggle /AMPPlugin/Enable_DNxU:true
    Setting chained toggle /GenericMXFContainer/SetDefaultLengthInStaticSlotComponents:true
    Setting chained toggle /GenericMXFContainer/EnableRedirectionToAvidOPAtom:false
    Setting chained toggle /WaveAiffReaderMovMediaContainer/AudioTimecodeUseBEXTOriginationDate:false
    Setting chained toggle /AMAFI-Tiff/TiffReturnCompressedEssence:false
    BigBufferPool 0x000000015BACACF0:
    Total Free: 2147483648 (2.00G)
    Largest Free: 2147483648 (2.00G)
    Memory Chunk 0x0000000017273A50, ADDR=[0x00007FF3051F0000]
    Number Allocs: 0
    Max Allocs: 0
    MSM directories:1
    LocalMDB::LoadMobsFromMDB() inCallback=0000000000000000 sourceOnle=FALSE
    mediaDirPath phyMobs logMobs
    "C:\Users\Public\Documents\Avid Media Composer\Avid_MediaFiles\" 0.01 sec
    total time=0.01 mobs=0
    Media Drives:
    ASUS (B:), OSVolID = 66, 236156 totalKB, 0 freeKB, 0 realFreeKB
    Windows10SSD (C:), OSVolID = 67, 438917124 totalKB, 267886128 freeKB, 267362913 realFreeKB
    WorkSSd (E:), OSVolID = 69, 976744444 totalKB, 857916464 freeKB, 856240846 realFreeKB
    Ramtatata2 (F:), OSVolID = 70, 2930134012 totalKB, 2349317148 freeKB, 2344728638 realFreeKB
    Yeepeeyaa (G:), OSVolID = 71, 2930134012 totalKB, 1484228584 freeKB, 1481329701 realFreeKB
    Ohyeah (I:), OSVolID = 73, 2930134012 totalKB, 2642939928 freeKB, 2637777936 realFreeKB
    BigYiepeh (J:), OSVolID = 74, 11720980476 totalKB, 6766605812 freeKB, 6753389786 realFreeKB
    Schnabbidup (U:), OSVolID = 85, 9766418428 totalKB, 7660632408 freeKB, 7645670236 realFreeKB
    MAX_INDEXES_TO_READ set to 10240
    MXF Indexes in Memory changed to 524288000: Old Size 524288000
    In Init ARO Cmds
    MTSC state = 0The single frame player will be built for a length of 3600 frames
    Viewer: OpenCL and OpenGL are compatible
    MSMRescan() took: 0.593000s
    LocateBuffer Resize from 2048MB to 15360MB
    CATException[80000008]codecs::FillCTVideoFormat, ..\..\CAT\core\extra\ctop.cpp:208 -> CAT_EXPECT_TRUE( width && height )
    WARNING: Requested LocateBuffer size 15360MB is the same as current size 15360MB.
    The default render wait time is 50
    PreReads will bias DueTime by 0.000000 seconds.
    Reloading plugin: AudioCodecManager.avx
    Reloading plugin: CMAvidMPEG1Layer2AudioCodec.avx
    Warning: 16 audio clips required Audio SampleRate Conversion.
    Please convert these files to avoid underruns and improve audio quality.
    Destroying Bin Container without closing
    HERE the console! no really problems i guess!
  • Sat, Oct 19 2019 3:57 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    Hey,
    iam using a 16:10 Hd display and a 4k Monitor at 125% Windows zoom.... i tried to disconnect the 16:10 and set the 4k monitor to 100%... Micro freezes again!
  • Sat, Oct 19 2019 3:58 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    this is shown in the console !
    is this a problem?
  • Sat, Oct 19 2019 5:32 PM In reply to
    • Erik
    • Austin, TX
    • Posts 207
    • Points 2,465
    Just for experimentation, try changing your display resolution from 4k to 1920x1080. If that works well try a slightly higher resolution and continue in increments until it starts getting sluggish again.
  • Sat, Oct 19 2019 5:59 PM In reply to
    Have you tried the standard Nvidia drivers instead of the Studio version?
  • Sat, Oct 19 2019 6:26 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    Will test it tomorrow.
    and yeah i was on the standard driver before!
  • Sun, Oct 20 2019 8:28 AM In reply to
    • helmar7
    • Posts 13
    • Points 135
    Wow, it seems to be really the problem.. when i  go on the 4k display to HD the performance increases! when i go to 2k its sluggish again. Do u know a solution for thisa problem? or have i think about a new graphic card?
    king regards
  • Sun, Oct 20 2019 1:04 PM In reply to
    • Erik
    • Austin, TX
    • Posts 207
    • Points 2,465
    As others have suggested, you might try changing the graphics driver.
    How much video memory is on your card?
    I have a GTX 1070 TI 8GB, running driver version 419.67 (which is an older version) and do not notice any performance issues with running a 4k display at 4k and 150% scaling.
  • Sun, Oct 20 2019 1:55 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    i will try.
    is nearly the same without the TI :)
    The other driver was not solving my prob.. just tried a bit the HD resolution... not really better :(
    UPDATE:
    I have now a geforce 2070 Super and i have the same performance probs since before... i dont really know what to do now., the lagging is really making my aggresiv :)
    Some more ideas?
  • Sun, Nov 24 2019 12:57 PM In reply to
    • helmar7
    • Posts 13
    • Points 135
    So for everybody who is interested.
    So the final solution was to change the mainboard from asus to supermicro and got a better graphiccard  (geforce gtx 1080 ti, 11gb) and finally get two 4k monitors (earlier it was HD + 4k).
    Thank u for all replies!
