Latest post Wed, Oct 23 2019 2:40 PM by Leo Baker. 4 replies.
  • Thu, Oct 17 2019 6:45 PM
    • berperson
    • Posts 30
    • Points 345
    Timecode of QuickTime export defaults to 00:00:00:00?
    I am exporting QuickTime files, same as source, from Avid.  When I imported the QuickTimes into Compressor I noticed that the timecode track is no longer at 01:00:00:00; rather, it is defaulting to 00:00:00:00.
    I have confirmed that the original TC track is indeed at 01:00:00:00.  Cannot find any setting that would reset it to 00:00:00:00.
    Using Media Composer 2018.12.7 on Mac.  Is this a bug in the software?
    Thanks.
     - Bob
    ** Update: Looking at TC in QT Pro, it appears the TC track is accurate; problem may be in Compressor v4.4.4.
  • Tue, Oct 22 2019 1:19 AM In reply to
    • Leo Baker
    • Joined on Wed, Oct 5 2011
    • Posts 423
    • Points 4,980
    Re: Timecode of QuickTime export defaults to 00:00:00:00?
    Hello Bob,
    Is that version of Compressor the latest? I'll download Compressor to my computer later this morning as I can only get the latest I presume your also on the latest version from Apple. Did you export a QuickTime movie or reference? What were your frame rate and compression. I can double check and test here then report back to you.
    Kind regards,
    Leo
    Avid Media Composer 2019.7, Pro Tools 2019.6 MacPro6.1 Late 2013 Intel Xeon 12-Core 2.7GHz 64GB RAM Graphics: AMD FirePro D700 OSX Mojave 10.14.6 [view my complete system specs]
  • Tue, Oct 22 2019 11:50 PM In reply to
    • Leo Baker
    • Posts 423
    • Points 4,980
    Dear Bob,
    I've had an issue logging into Appstore, so apologies in my delay. I needed to reset my passwordto gain access even though it worked previous. I've just downloaded the latest APPLE COMPRESSOR. I exported a Quicktime Apple Pro Res from my edit timeline from Avid Media Composer and the correct timecode came across 01:00:00:00. I'll test later this morning with SAS Same As Source from Avid then report back.
    Kind regards,
    Leo
  • Wed, Oct 23 2019 2:38 PM In reply to
    • Leo Baker
    • Posts 423
    • Points 4,980
    Dear Bob,
    I am on Media Composer latest 2019.9 and using the latest Apple Compressor 4.4.5 on OSX Mojave 10.14.6. I made a Quicktime PRORES 422 HQ from Da Vinci Resolve.
    With-in Avid Media Composer I made a new project 1280x720 23.98. I cut the video clip PRO RES 422 HQ onto the Avid timeline. I did two tests defualt starting tiemcode of my sequence as 01:00:00:00 and another as 02:00:00:00.
    I then exported Quicktime Movie, and set same as source audio and video as it's a stereo audio clip left/right and un-checked use AVID Codecs.
    I opened each video file which were exported from Media Composer and both show the start timecode as 01 and 02.
    Kind regards,
    Leo
  • Wed, Oct 23 2019 2:40 PM In reply to
    • Leo Baker
    • Posts 423
    • Points 4,980
    Dear Bob,
    Have you tried another version maybe 1 version back of Media Composer to see if the same whereby the tiemcode is not reading in Apple Compressor?
    Kind regards.
    Leo
