Latest post Wed, Nov 6 2019 9:37 AM by jakeheat. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Mon, Sep 30 2019 4:32 PM
    MEDIA COMPOSER 2019.9 AVAILABLE TODAY 30 SEPTEMBER 2019
    The new September release of Media Composer is launching today, September 30, 2019 @ 12:00 Noon ET.
    Status of Support Plan: The ability to launch Media Composer 2019.9 software is dependent on the status of your Upgrade and Support Plan on the date this software version is released 9/30/19.
    Location at Launch: Updates to Media Composer will be made available starting at 12:00 noon from Avid Link, MyAvid and the Avid Download Center (login and password required).  Might take a bit for all the components to update so please be patient.
    What’s New in 2019.9: Listed below are the new items in 2019.9. Please refer to the What’s New Guide for the explanation and illustrations on these new features.
    • Bin Background Color in Tabs
    • Accessing the Custom Color Picker for Color Palettes
    • Bin Left Lock
    • Bin Left Lock
    • Show Bin in Sidebar
    • Project Bin Container
    • Tabbed Interface Settings Window
    • Timeline Mute and Solo Buttons
    • Timeline Settings Update
    • More Customizable Buttons in the Timeline
    • Set Clip Color
    • Increased Frame Size
    • Timeline Fast Menu Additions
    • Graphic Formats
    • Sequence Report for AAF Imports
    • Avid Titler+ Updates
    • Updates to Media Composer | Enterprise
    What’s fixed in 2019.9:  The following has been fixed:
    -  Bug Number: MCCET-3142. Using Transition Corner Display with ripple trim didn’t update the lower 3 frames correctly.
    -  Bug Number: MCCET-3158. Locked tracks became deselected when you changed export settings.
    -  Bug Number: MCCET-3122. If you exported an AAF for a second time, changing the name resulted in a crash.
    -  Bug Number: MCCET-3058. After performing an Insert Edit, returning to the Insert Edit Export option, the selected check boxes were not saved.
    -  Bug Number: MCCET-3168. The editing application would crash when opening a bin from Media Composer v8.4.5.
    -  Bug Number: MCCET-3144. OMFI did not rescan or relink properly.
    -  Bug Number: MCCET-3175. If Windows scaling was set to 150%, 3D Warp effects displayed as a negative image.
    -  Bug Number: MCCET-3211. (Windows) Video did not expand when you resized a pop-up window.
    -  Bug Number: MCCET-3110. When in Text View, you did not have the option in the Bin Window to lock columns during scrolling left and right. See the Media Composer v2019.9 What’s New for information on Bin Left Lock.
    -  Bug Number: MCCET-2951. (Nitris DX) You might have received an “Assertion failed” error. when adjusting audio using the Audio Monitor Control button in the Timeline.
    -  Bug Number: MCCET-3021. You might have received an “Exception: CC Relationship Failed” error and the editor crashed when removing Color Correction.
    -  Bug Number: MCCET-3153. In some instances, video mixdowns did not display the correct timecode.
    -  Bug Number: MCCET-3189. When performing a Digital Cut with the Digital Cut Safe Mode enabled, effects were rendered, but the render progress windows stayed on the screen when the playback starts. This blocked access to any controls in the Digital Cut window.
    -  Bug Number: MCCET-2819. Saving an Export Setting that included the Avid Media Processor option did not always retain the correct settings..
    -  Bug Number: MCCET-2972. In some instances, bins did not save after placing resize effects on clips.
    -  Bug Number: MCCET-3178. The YCbCR 2020 HLG Color Space did not carry over into the project.
    -  Bug Number: MCCET-3194. In some instances, K did not stop playback when working with JKL playback.
    -  Bug Number: MCCET-3187. Selecting File > Open Bin did not always make the bin visible.
    -  Bug Number: MCCET-3109. You could not always save a Color Correction (current/previous/next) setting as a custom setting.
    -  Bug Number: MCCET-3221. Performing a Quick Find using the Bin filter field with enable/disable reference clips did not work properly.
    -  Bug Number: MCCET-2676. Audio Meters in the Audio Mixer tool responded later than the audio meters in the Timeline.
    -  Bug Number: MCCET-3215. In some instances, if the Tool Palette was opened across two monitors, the editing application would crash.
    -  Bug Number: MCCET-2759. (Interplay) The wrong file might have been transferred when performing a drag and drop from a bin to an FTP Browser.
    -  Bug Number: MCCET-3140. In some instances, the video might have looked skewed after applying a tracker effect.
    -  Bug Number: MCCET-2854. Dragging and dropping a clip from AirSpeed Remote Console to a bin resulted in Media Composer closing.
    -  Bug Number: MCCET-3219. You might have received a “Current hardware is not compatible with this project's settings, and is being switched to inactive” error when connected to a Nitris DX or Mojo DX. The IO device should not have been disabled for supported resolutions. This has been fixed.
    -  Bug Number: MCCET-3007. MXFOP1a exports from Avid Media Processor may have had a “Timecode of first frame” value of -1 if the start of sequence had an odd timecode.
    Media Composer 2019.9 Documentation: The “ReadMe” for this release of Media Composer 2019.9 will be uploaded to the Knowledge Base - Media Composer 2019 Documentation Page at launch.
    Limitations Media Composer 2019.9:  For the list of limitations in Media Composer 2019.9, please references the “ReadMe” located on the Knowledge Base - Media Composer 2019 Documentation Page.
    How to obtain the Media Composer 2019.9 Update: The new Media Composer 2019.9 will be made available via:
    1.  Customers who have an active support and upgrade plan will be notified of the availability of the 2019.9 via Avid Link and it will be available via Link, MyAvid and the Download Center.
    2.  New perpetual and subscription Licenses purchased on or after today, September 30, 2019 will also receive 2019.9
    Media Composer 2019.11 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Tue, Oct 1 2019 12:18 PM In reply to
    Re: MEDIA COMPOSER 2019.9 AVAILABLE TODAY 30 SEPTEMBER 2019
    Wow, I just found a bug inside the first 2 minutes of working with 2019.9 - Effects Fade doesn't work with alpha channel elements in the timeline. When I select my alpha element in the timeline click on Effects Fade, I get a message: "The Effect doesn't allow the fade"
    Update: I did a full uninstall and had to manually delete a series of folders from the C: drive. Then I re-installed 2019.9.  I also Imported my user settings rather than copying them in the folder.
    This issue persists.
    Windows 10 Enterprise - Dell Precision 7820 - 32GB RAM - DNxIQ - Nvidia Quadro P4000 [view my complete system specs]
  • Tue, Oct 1 2019 12:28 PM In reply to
    • Posts 10,804
    • Points 225,640
    Marc Cebrian:
    Incredible.
    Marc
    Let me have this reproduced....
  • Tue, Oct 1 2019 12:34 PM In reply to
    Marianna,
    I have opened a Case : 03795340 - I have a quicktime alpha element (lower 3rd) in a 1080p 29.97 timeline. I click on my Effects Fade button when it happens. I can add dissovles. I can adjust keyframes. But the effect button doesn't work.
  • Tue, Oct 1 2019 1:02 PM In reply to
    • Posts 10,804
    • Points 225,640
    Marc
    adding this info to the case.
    Marianan
  • Tue, Oct 1 2019 3:14 PM In reply to
    Bug #2 - The Audio waveform in your timeline will disappear after an edit with a dissolve. If you have a same track (add edit) dissolve that ENDs at the cut, all the Audio Waveform data disappears from the rest of your timeline. If you add a dissolve that STARTs at the cut, then the Audio data does NOT disappear. All I am doing is adjusting volume.
    This is case #03795520
    Update: I did a full uninstall and had to manually delete a series of folders from the C: drive. Then I re-installed 2019.9. This issue seems to have gone away. I also Imported my user settings rather than copying them in the folder.
    Marc
    There is a 3rd smaller bug I am not reporting yet. It has to do with a button icon sticking to your timline slots even when you did not program it or actively remove it with the Command Palette. (This bug is still around).
  • Tue, Oct 1 2019 5:03 PM In reply to
    Bug #3 - You cannot add a dissolve to the end of a master clip. You have to add one at the front, then you can add it at the back. If it is at the very end of your timeline, you can add a center dissolve and then change it to end at the edit. In order to get a dissolve at the end of a clip, I have to be one frame AFTER the clip to add it. The "sensing" of where a dissolve would go at an edit point has disappeared and you must be exact to get the dissolve to appear. Otherwise, Avid "dings" at you until you get it to stick.
    Edit: You cannot add a dissolve ANYWHERE unless you are AFTER the edit point, but not BEFORE it.
    Case #03795648
  • Tue, Oct 1 2019 7:19 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 409
    • Points 5,345
    For what it's worth, I wasn't able to reproduce any of these bugs on macOS 10.14.6.
    Avid Media Composer 2018.12.8 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.4), macOS 10.14.6, iMac Pro (2017) 10-Core, 3.0GHz... [view my complete system specs]
  • Thu, Oct 10 2019 7:32 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 207
    • Points 2,465
    If AMA prores clips are grouped together and put in a timeline and the clip's audio waveform is shown, Avid intermittently displays a crash error. Clicking cancel or send report allows you to continue to work until it crashes again.
    Turning off the waveforms stops the crashing.
    MC 2019.9 Asus Prime X299 Deluxe, 64GB of Memory, Core i9 7940x @3.1Ghz, Nvidia GeForce GTX 1070 Ti. Running Win10 Pro 64bit MC 2018.4 Dell Precision... [view my complete system specs]
  • Wed, Oct 16 2019 10:22 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 409
    • Points 5,345
    I'm having a new issue with MC 2019.9 on Windows 10:
    When doing a OP1a MXF or Quicktime DNxHD 145 output, my VO track gets truncated by about two seconds at the head. The audio underneath is okay. My sequence is fairly simple with only 6 total audio tracks.
    Doing an audio mixdown results in the same truncated audio.
    I've tried two different projects and both had the VO trucated, but if I output the same sequence with MC 2019.7, the audio exports intact.
    Systems tested are HP Z840s with 32 GB RAM.
  • Thu, Oct 17 2019 1:52 PM In reply to
    • Posts 10,804
    • Points 225,640
    jd...
    I have support looking at this one - case # 03808778
  • Thu, Oct 17 2019 2:52 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 409
    • Points 5,345
    Thank you, Marianna.
    I've just exported the same sequence on MC 2019.9 on MacOS 10.14.6 and it came out fine, so this issue could to be specific to Windows version.
  • Thu, Oct 17 2019 3:04 PM In reply to
    • Posts 10,804
    • Points 225,640
    Hey jd
    did you do any Win 10 updates like to 1903 or 1909
  • Thu, Oct 17 2019 4:43 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 409
    • Points 5,345
    Marianna,
    Our Windows systems are all on 1809 while the IT department tests 1903.
    Cheers,
    jd
  • Fri, Oct 25 2019 11:37 AM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 373
    • Points 4,710
    Not sure if a bug or a "feature" in 2019.9
    In SubCap generator, when you first load the settings, if you single click the opacity of the subtitle box, the icon(dot) turns pink you type the number and that number is put into the caption, and the opacity doesnt change. If you double click the icon(dot) you can then type your number and it changes the value. After that initial double click, just a single click allows the value change again.
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2019.8 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.12.7 2x... [view my complete system specs]
