Latest post Mon, Oct 7 2019 2:19 PM by TrevorA. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Sep 21 2019 5:07 AM
    • TrevorA
    • Posts 1,184
    • Points 13,320
    Insert edit export - a great feature
    Currently there is no send to playback at 59.94P, so we have to file export to scan folder to get files to EVS for playout.
    Advantage to this workflow was that we could use, for the first time in anger, ‘insert edit export’. This was great.
    We had to fix our highlights show - 3 little paints in a 12 minute segment. Drop ins take seconds, rather than an 8 minute export.
    Caveats:
    Insert edit export always defaults to export all tracks - you can modify in options to 'selected tracks' but beware:
    a. clicking OK in this option menu goes straight to exporting
    b. the 'selected' video tracks are exported as-is (i.e. select one video track and that is effectively soloed, tracks below are not output)
    c. Exported audio appears to *only* be direct out (limited to number of tracks in file being inserted to). So my accidental audio insert to stereo master was just fx (timeline tracks 1&2) without the commentary (timeline track 3). This would be ok in 5.1/5.1.4 workflow as we’d have had to do a multiple mixdown->direct out export for original file.
    d. You have to choose ‘selected tracks’ every time, it always defaults to all tracks
    Feature requests:
    More visual indication on what is going on with export (what tracks are going to be inserted, what audio configuration is being used).
    Remove ‘use marks’ from options menu as it is redundant
    OK in options menu should   labelled ‘export’
    Cancel in options menu shouldn’t cancel whole export
    Setting to always export using selected tracks
    Selected video shouldn’t solo, should be all tracks below
    Should be an option to insert edit export as mono/stereo/direct etc
    Should be an export option (also for straight file export) for audio to be exported ‘as monitored’
  • Sat, Sep 21 2019 9:07 PM In reply to
    Re: Insert edit export - a great feature
    Yes
    Yes
  • Mon, Sep 23 2019 4:23 AM In reply to
    • TrevorA
    • Posts 1,184
    • Points 13,320
    TrevorA:
    readme for recent version:
    ”. If prompted, select between direct out audio and mixed audio.
    Media Composer will attempt to determine if the original export was done in direct out or by an audio mix, by comparing the tracks layout in the sequence to those in the existing file. In some case, it is unable to tell the difference. , in this case you will have to choose a selection when prompted.”
    So it must have assumed my file was direct out, even that it only had two audio tracks. Bug?
    Points to more info on insert export ahead of performing the edit (eg track selection and audio output config).
    ’Edit review’ would also be useful (link to file, play in to out with pre and post rolll, release file).
  • Mon, Sep 30 2019 9:02 PM In reply to
    • TrevorA
    • Posts 1,184
    • Points 13,320
    Still apparent in 2019.6
    https://www.dropbox.com/s/o3vvvsirujhszl1/Insert%20Edit%20Export%20Audio.mp4?dl=0
    Shows inserting into a stereo file only inserts the first two timeline tracks.
    https://www.dropbox.com/s/87pwe3ozry7cui5/Insert%20Edit%20Export%20-%20Solos%20selected%20track.mp4?dl=0
    Shows how 'use selected tracks' for video effectively soloes the selected track(s) when inserting. Can't imagine why you would want that behaviour
  • Tue, Oct 1 2019 1:37 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 939
    • Points 11,990
    Until MC 2019.8 there was a bug with Insert Edit. If you had selected "mixdown to Stereo" with the first export of the sequence, Insert Edit only considered the first two tracks and misses all other tracks. This led to corrupted sequences.
    With version 2019.9 this has been solved. Now Insert Edit mixes down all audio tracks to stereo if the first exported sequences was also a mixdown. By doing a mixdown first and then insert it into the existing export file, the result is a correct sequencee with just the part of the sequence replaced with new (correct) tracks.
    Joachim
    Joachim Claus
  • Mon, Oct 7 2019 2:19 PM In reply to
    • TrevorA
    • Posts 1,184
    • Points 13,320
    Joachim Claus:
    Joachim
    Just tested in 2019.9.0
    1. Sequence must be same duration as file being inserted to.
    2. Timecode does not need to match - it will insert based on time from start of sequence/file
    3. Now defaults to 'use selected tracks' and 'include inactive audio tracks' (use marks is redundant).
    4. Clicking OK after choosing options still exports (and so should be labelled as such).
    5. Stereo does now insert correctly but inserting with only audio tracks selected results in: 'Insert edit export failed. File is not supported for insert edit.’ (bug in 2019.9)
    6. Direct insert does not appear to be possible at all (now always mixes down to stereo, regardless of number of tracks in sequence).
    7. Make sure to select all video tracks required - or it will mute those not selected - DANGEROUS
    8. Will insert inactive audio tracks by default (but not muted clips) - DANGEROUS
    9. Ignores timeline solos and mutes - DANGEROUS
    10. Individual clip mutes are respected (a good thing)
    11. Will insert (even though it says it has failed) if file is AMA linked. Better to delete that master clip in Avid before attempting to insert.
