Latest post Tue, Dec 10 2019 4:52 PM by Tom Pearson. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Sep 16 2019 9:15 AM
    • Erik Bäfving
    • Joined on Sun, Nov 13 2011
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Serious problem with playback MC 2019.7.0
    I have two serious issues that maybe are related in some way.
     - The first issue is that the playback of the video suddenly stops working. The playback button green light goes on and off while I press it but the video doesn´t play at all, nor the sound. I doesn´t matter if I press play through the keyboard or the interface. To get out of this problem I can save the project, and restart the computer. It appears totally unexpected.
    - The second problem is that the spinning ball comes up, and I´m not able to do anything. It spins for about 10 seconds, then stops, before it starts again. And in that short space where it doesn´s spin I´m able to move the cursor, but I´m not able to press any command. To get out of this problem I have to force quit the program, restart the computer and the program. I really can´t see any connection to any special command leading to this issue, but possibly that I´m doing a series of commands in a quick pace. Usually it leads to some work lost.
    Both of these problems appear maybe ten times a day, almost periodically.
    Yes I have created a new user. Totally deleted the old files from the MC version before.
    Tech spec: MacBook Pro, 2,5 GHz Intel Core i7, 16 GB 1600 MHz DDR3
    Graphic: NVIDIA GeForce GT 750M 2048 MB, Intel Iris Pro 1536 MB
    Grateful for some help on this one...
    /Erik
    MacBook Pro Retina 15" 2,5 GHz Intel Core i7 16 GB 1600 MHz DDR3 NVIDIA GeForce GT 750M 2048 MB Media Composer 8.2.0 [view my complete system specs]
  • Wed, Sep 18 2019 6:01 PM In reply to
    • gorbi
    • Joined on Mon, Mar 31 2014
    • Zurich, Switzerland
    • Posts 18
    • Points 240
    Re: Serious problem with playback MC 2019.7.0
    Hi
    I just teached new Avid MC 2019.8 in class on OS X 10.14.6 on iMacs with no external video card (just iMac monitor) and we had several times the same issue. Suddenly no video in source or record monitor. Resizing the composer window fixed the problem or changing from dual to single composer monitoring. I could not figure out when this happens. I thought I have read this was fixed in 2019.7?
    Btw: New user profile was created.
    Best,
    gorbi
    MacBook Pro (Retina, 15-inch, Mid 2015), 2.8 GHz Intel Core i7, 16 GB 1600 MHz DDR3, AMD Radeon R9 M370X 2048 MB, OS X 10.14.6, AVID MC 2019.11 [view my complete system specs]
  • Thu, Sep 19 2019 7:42 AM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Thanks for your reply Gorib. I will try this next time the issue appears. I have two external screens connected to my Macbook Pro, one through HDMI, and one through the mini-display. Maybe this could cause the problem. The thing is that I didn´t have the problem on the old version 2018 of Mediacomposer, with the same setup of screens. So hopefully Avid is looking into this.
    Cheers
    Erik
  • Fri, Nov 29 2019 10:37 AM In reply to
    • gorbi
    • Posts 18
    • Points 240
    Hi Erik
    I had latley the same problem with the spinning ball. It turned out, that Avid MC versions > 2019.6 have really problems with older projects. My solution was: Setting up a new project in 2019.6 or higher and copy all bins from the old project into the new one. Then everything worked again.
    But I still have the problem that my source monitor goes black from time to time. Only resizing the windows or reload the workspace helps.
    Best,
    gorbi
  • Mon, Dec 2 2019 8:20 AM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Thanks Gorbi,
    I´ll check it out as soon as I have the time. I hope it works!
    All the best
    Erik
  • Tue, Dec 10 2019 4:13 PM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    It seems like the problem have ended when I changed drive. I tried to copy all of the materal to another drive and I´ve been working all day without the issue to appear. Very relieved. Thanks for your help everyone....
  • Tue, Dec 10 2019 4:52 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,178
    • Points 23,340
    Yes drive speed  thru put can cause stalling issues are you using usb 2.0 by chance I always use a thunderbolt raid on my mbp with no issues
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
