Latest post Wed, Sep 11 2019 9:33 PM by Fazz Powell. 7 replies.
  • Tue, Sep 10 2019 9:31 PM
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 392
    • Points 5,395
    Nitris DX offline
    Hello-It's been months since I've fired up this machine. I upgraded to 2018.10 last year. The NitrisDX worked. Now my NitrisDX is off line and I don't know why. The Host Link and HD-SDI A lights blink, sometimes Host is steady, but none of the other lights fire-up like they used to. I've googled/searched every where. Cold booted everything.
    The old hardware cog wheel on top of the sequence has been replaced with background services, which was paused, I turned it onto to start and that turns on "dynamic mode", I don't even know what that is. I put that back on pause and when I click on the cog/settings wheel I get "must start Avid Editor Services Manager", which using help I can't find. My video output and input tools are greyed out. I saw a post on a forum and ran the .exe for ProgramsAvid\Utlilies\DXDrivers\DXDrivex64.Win7,exe, and that took forever to launch as it showed it was making changes to Avid but no change. (I had renamed DXDriver64.win10 to ".old"., but on boot it created a W10.exe...I'm on W7, and I had hever heard of that step.)
    Next to the cog wheel on the sequence is an icon for "HW/SW Disable". When I toggle that my Video Output Tool becomes un-greyed, Input still is grey. When I click on that it just offer options on the computer for output, but nothing for the NitrisDX, so it's still not being seen. I'm sorry if this is a repeat post, I've searched high and low to no avail.
    Many thinks,
    Dan
    MC 2018.10 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Wed, Sep 11 2019 12:53 PM In reply to
    • Posts 10,676
    • Points 224,040
    Re: Nitris DX offline
    Hey Dan
    I created a case # 03783411 and asked support to assist. Note that one of your plans will expire in a month or so...
  • Wed, Sep 11 2019 6:58 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 392
    • Points 5,395
    Thank you. I swapped out Nitris boxes and no joy so based on AEoFB comments they recommended the card needed reseating or was toast, then I hooked up the old one and it came back... kinda... all the lights are where they need to be and the video input and output tool is ungreyed in MC. I see the Nitris in Device Manager now in Control Panel but no picture on my monitor. I've had 1 ticket in some 15 years. How does this work? I assume there's a support phone number on youir site somewhere I can call. I'm wonder what I may need to do to ping or test the Nitris. I dunno.
  • Wed, Sep 11 2019 7:53 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 508
    • Points 6,060
    there is a test program for DX hardware.
    http://avid.force.com/pkb/articles/en_US/Download/en430911?retURL=%2Fpkb%2Farticles%2Ftroubleshoo_1
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Wed, Sep 11 2019 8:59 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 392
    • Points 5,395
    Thank you, that exactly what I was trying to find. It says it failed. I don't have anything looped through so I didn't run that, just HD-SDI and HD-Component out. HD-Component out has gone missing/isn't working.
    Diagnostics Version: 03.13.2013 [03.09]
    Current Date/Time: 09/11/19_16:53:24
    HAGRID
    Main Board SN = YBBK832044
    Main Board PN = 7030-20040-03 [ECO = C]
    Audio Board SN = YBBN830001
    Audio Board PN = 7030-20048-03 [ECO = B]
    Norbert Fpga ID = 701
    Norbert Fpga Revision = 03.12 - [0x03120000]
    Firmware Revision = 01.23-00.00
    Fang CPLD ID = FBFB
    Fang CPLD Revision = 00.11 - [0x0011]
    Power CPLD Revision = 03.0B
    CM2_S2
    CM2_S2 Fpga ID = 4AD0
    CM2_S2 Fpga Revision = 02.05 - [0x02050000]
    CM2_S2 VCID Revision = 00.0A
    CM2_S2 Board SN = YBBM829096
    CM2_S2 Board PN = 7030-20035-04 [ECO = B]
    Norbert-Board Temperature(C) Local = 35.00, Remote = 49.12
    (Volt 2) = 1.199 Volts [-0.06%] - Norbert FPGA Core
    (Volt 3) = 1.796 Volts [-0.24%] - DDR2 RAM, Etc..
    (Volt 4) = 3.254 Volts [-1.39%] - Genlock, Etc..
    (Volt 5) = 1.188 Volts [-0.96%] - SERDES Aux, Etc..
    (Volt 6) = 3.282 Volts [-0.55%] - SERDES 3.3V Analog
    (Volt 7) = 3.280 Volts [-0.59%] - HDMI IO 3.3V, Etc..
    (Volt 8) = 1.785 Volts [-0.83%] - HDMI 1.8 Core, Etc..
    (Volt 9) = 2.478 Volts [-0.88%] - Local regulation
    (Volt 10) = 3.361 Volts [+1.84%] - ATX 3.3V output..
    CM2_S2-Board Temperature(C) Local = 40.00, Remote = 54.00
    Fan 1 Speed >> code=2, tach= 9, rpm=3856
    Fan 2 Speed >> code=2, tach= A, rpm=4285
    DMA Channel 2 - Done bit won't Set!
    DMA to Buffer TIMEOUT!
    Time = 1040859 uSecs
    Time = 3718 uSecs
    Test Sequence Started - 09/11/19_16:54:27
    PCIe Link Width = x1 , Link Status = 1011
    [31000007] Norbert:PCIe Capabilities Test FAILED!
    Norbert-Board Temperature(C) Local = 34.00, Remote = 48.88
    (Volt 2) = 1.200 Volts [+0.04%] - Norbert FPGA Core
    (Volt 3) = 1.796 Volts [-0.19%] - DDR2 RAM, Etc..
    (Volt 4) = 3.252 Volts [-1.45%] - Genlock, Etc..
    (Volt 5) = 1.189 Volts [-0.96%] - SERDES Aux, Etc..
    (Volt 6) = 3.280 Volts [-0.59%] - SERDES 3.3V Analog
    (Volt 7) = 3.281 Volts [-0.57%] - HDMI IO 3.3V, Etc..
    (Volt 8) = 1.785 Volts [-0.82%] - HDMI 1.8 Core, Etc..
    (Volt 10) = 3.362 Volts [+1.89%] - ATX 3.3V output..
    Time of failure: 09/11/19_16:54:27
    [31000000] Norbert:Register RW Test.........................PASSED
    [31000001] Norbert:DCB Register RW Test.....................PASSED
    [31000002] Norbert:BCU Register RW Test.....................PASSED
    [31000003] Norbert:SDRAM Memory PeekPoke Test...............PASSED
    [31000004] Norbert:Memory INIT Test.........................PASSED
    [31000005] Norbert:Indirect-Memory Addr-Data Test...........PASSED
    [31000006] Norbert:Memory BIST Test.........................PASSED
    [37000001] Fang:LED Visual 1................................PASSED
    [3100000B] Norbert:Voltage Measurement Test.................PASSED
    [37000000] Fang:Fang Register Test..........................PASSED
    [31000008] Norbert:IIC Device Test..........................PASSED
    [3100000A] Norbert:IO Timing Setup Test.....................PASSED
    DMA Channel 18 - Done bit won't Set!
    Transfer 6, HOST->SDRAM DMA transfer failed!
    [31000104] Norbert:SDRAM Memory DMA Test FAILED!
    Norbert-Board Temperature(C) Local = 35.00, Remote = 48.88
    (Volt 2) = 1.199 Volts [-0.04%] - Norbert FPGA Core
    (Volt 3) = 1.796 Volts [-0.21%] - DDR2 RAM, Etc..
    (Volt 4) = 3.253 Volts [-1.41%] - Genlock, Etc..
    (Volt 5) = 1.189 Volts [-0.88%] - SERDES Aux, Etc..
    (Volt 6) = 3.281 Volts [-0.57%] - SERDES 3.3V Analog
    (Volt 8) = 1.785 Volts [-0.85%] - HDMI 1.8 Core, Etc..
    Time of failure: 09/11/19_16:54:39
    [2]-FM_PCIMaster1 DCB1 - DMA Done Will Not SET!
    Total Number of failures = 1
    [31000100] Norbert:PCI Master_A (FM) Test FAILED!
    (Volt 2) = 1.200 Volts [+0.02%] - Norbert FPGA Core
    (Volt 3) = 1.796 Volts [-0.25%] - DDR2 RAM, Etc..
    (Volt 5) = 1.189 Volts [-0.94%] - SERDES Aux, Etc..
    (Volt 10) = 3.358 Volts [+1.77%] - ATX 3.3V output..
    Time of failure: 09/11/19_16:54:40
    [3]-FM_PCIMaster2 DCB1 - DMA Done Will Not SET!
    [31000101] Norbert:PCI Master_B (FM) Test FAILED!
    (Volt 3) = 1.798 Volts [-0.14%] - DDR2 RAM, Etc..
    (Volt 4) = 3.253 Volts [-1.43%] - Genlock, Etc..
    (Volt 5) = 1.190 Volts [-0.87%] - SERDES Aux, Etc..
    (Volt 7) = 3.282 Volts [-0.55%] - HDMI IO 3.3V, Etc..
    Time of failure: 09/11/19_16:54:41
    [18]-TM_PCIMaster1 - DMA Done Will Not SET!
    [31000102] Norbert:PCI Master_A (TM) Test FAILED!
    (Volt 2) = 1.200 Volts [-0.02%] - Norbert FPGA Core
    (Volt 3) = 1.795 Volts [-0.25%] - DDR2 RAM, Etc..
    (Volt 10) = 3.361 Volts [+1.86%] - ATX 3.3V output..
    [19]-TM_PCIMaster2 - DMA Done Will Not SET!
    [31000103] Norbert:PCI Master_B (TM) Test FAILED!
    Norbert-Board Temperature(C) Local = 35.00, Remote = 49.00
    (Volt 2) = 1.199 Volts [-0.08%] - Norbert FPGA Core
    (Volt 3) = 1.799 Volts [-0.08%] - DDR2 RAM, Etc..
    (Volt 6) = 3.280 Volts [-0.61%] - SERDES 3.3V Analog
    Time of failure: 09/11/19_16:54:42
    [3100010B] Norbert:DMA Master Flush Test....................PASSED
    DMA SDRAM->RESULT BUFFER [0x01000000] failed!
    [31000105] Norbert:FBC One to One Test FAILED!
    Norbert-Board Temperature(C) Local = 34.00, Remote = 49.00
    (Volt 2) = 1.198 Volts [-0.17%] - Norbert FPGA Core
    (Volt 3) = 1.795 Volts [-0.31%] - DDR2 RAM, Etc..
    (Volt 10) = 3.363 Volts [+1.91%] - ATX 3.3V output..
    Time of failure: 09/11/19_16:54:44
    DMA SDRAM->RESULT BUFFER [0x08800000] failed!
    [31000106] Norbert:FBC Multi Link Test FAILED!
    (Volt 5) = 1.189 Volts [-0.92%] - SERDES Aux, Etc..
    (Volt 8) = 1.785 Volts [-0.81%] - HDMI 1.8 Core, Etc..
    Time of failure: 09/11/19_16:54:46
    [31000107] Norbert:FBC Upsizer Test FAILED!
    (Volt 2) = 1.200 Volts [-0.04%] - Norbert FPGA Core
    (Volt 3) = 1.795 Volts [-0.28%] - DDR2 RAM, Etc..
    (Volt 5) = 1.189 Volts [-0.90%] - SERDES Aux, Etc..
    Time of failure: 09/11/19_16:54:47
    [37000002] Fang:LED Visual 2................................PASSED
    DMA SDRAM->RESULT BUFFER [0x02000000] failed!
    [31000108] Norbert:SS Global Bypass Test FAILED!
    (Volt 2) = 1.200 Volts [+0.00%] - Norbert FPGA Core
    (Volt 3) = 1.797 Volts [-0.18%] - DDR2 RAM, Etc..
    (Volt 10) = 3.360 Volts [+1.82%] - ATX 3.3V output..
    Time of failure: 09/11/19_16:54:49
    [31000109] Norbert:SS Block Bypass Test FAILED!
    (Volt 3) = 1.799 Volts [-0.07%] - DDR2 RAM, Etc..
    (Volt 4) = 3.255 Volts [-1.36%] - Genlock, Etc..
    Time of failure: 09/11/19_16:54:50
    [3100010A] Norbert:SS 1-to-1 Test FAILED!
    (Volt 2) = 1.201 Volts [+0.08%] - Norbert FPGA Core
    (Volt 3) = 1.795 Volts [-0.29%] - DDR2 RAM, Etc..
    (Volt 5) = 1.190 Volts [-0.85%] - SERDES Aux, Etc..
    Time of failure: 09/11/19_16:54:52
    [3B000000] CM2_S2:Register RW Test..........................PASSED
    [3B000001] CM2_S2:MemoryA INIT Test.........................PASSED
    [3B000002] CM2_S2:MemoryB INIT Test.........................PASSED
    [3B000003] CM2_S2:MemoryA Addr/Data Test....................PASSED
    [3B000004] CM2_S2:MemoryB Addr/Data Test....................PASSED
    [3B000009] CM2_S2:Encoder VCID Manual Load Test.............PASSED
    [3B00000A] CM2_S2:DecoderA VCID Manual Load Test............PASSED
    [3B00000B] CM2_S2:DecoderB VCID Manual Load Test............PASSED
    [3B00000C] CM2_S2:Encoder VCID AUTO Load Test...............PASSED
    [3B00000D] CM2_S2:DecoderA VCID AUTO Load Test..............PASSED
    [3B00000E] CM2_S2:DecoderB VCID AUTO Load Test..............PASSED
    [3B00000F] CM2_S2:Compressed Loopback Test..................PASSED
    [3B000010] CM2_S2:Decompressed Loopback Test................PASSED
    [3B000011] CM2_S2:LM86 Functional Test......................PASSED
    [3B000132] CM2_S2:Multi Frm Mix_1 Decoder Test..............PASSED
    DMA Channel-23 (TM_Aux1ChB) TIMEOUT!
    FAILED SEQUENCE:
    0) Test Frame 0 - HD8-YCbCr-720P00000.yuv8.4E3.DECOMP
    1) Test Frame 1 - HD8-YCbCr-720P00013.yuv16.4E2.DECOMP
    2) Test Frame 2 - HD8-YCbCr-720P00024.yuv16.4E2.DECOMP
    3) Test Frame 3 - HD8-YCbCr-720P00032.yuv8.4E4.DECOMP
    4) Test Frame 4 - HD8-YCbCr-720P00040.yuv16.4E2.DECOMP
    5) Test Frame 5 - HD8-YCbCr48.yuv8.4E5.DECOMP
    6) Test Frame 6 - HD8-YCbCr-720P00056.yuv16.4E2.DECOMP
    [3B000133] CM2_S2:Multi Frm Mix_2 Decoder Test FAILED!
    (Volt 2) = 1.199 Volts [-0.10%] - Norbert FPGA Core
    (Volt 3) = 1.796 Volts [-0.22%] - DDR2 RAM, Etc..
    (Volt 8) = 1.786 Volts [-0.79%] - HDMI 1.8 Core, Etc..
    Time of failure: 09/11/19_16:55:11
    DMA SDRAM->RESULT BUFFER [0x01800000] failed!
    DMA SDRAM->RESULT BUFFER [0x02800000] failed!
    FAILED SEQUENCE:
    0) Test Frame 0 - HD8-YCbCr00.yuv8.4DA.DECOMP
    1) Test Frame 1 - HD8-YCbCr-720P00000.yuv8.4E3.DECOMP
    2) Test Frame 2 - HD8-YCbCr13.yuv16.4D9.DECOMP
    3) Test Frame 3 - HD8-YCbCr-720P00013.yuv16.4E2.DECOMP
    4) Test Frame 4 - HD8-YCbCr48.yuv8.4D5.DECOMP
    5) Test Frame 5 - HD8-YCbCr-720P00032.yuv8.4E4.DECOMP
    6) Test Frame 6 - HD8-YCbCr24.yuv8.4E5.DECOMP
    7) Test Frame 7 - HD8-YCbCr-720P00048.yuv16.4E2.DECOMP
    8) Test Frame 8 - HD8-YCbCr32.yuv8.4DB.DECOMP
    [3B000134] CM2_S2:Multi Frm Mix_3 Decoder Test FAILED!
    Time of failure: 09/11/19_16:55:17
    DMA SDRAM->RESULT BUFFER [0x00400000] failed!
    DMA SDRAM->RESULT BUFFER [0x00500000] failed!
    FAILED SEQUENCE:
    0) Test Frame 0 - HD8-YCbCr00.yuv8.CDC.IMG
    1) Test Frame 1 - HD8-YCbCr08.yuv8.CDC.IMG
    2) Test Frame 2 - HD8-YCbCr13.yuv8.CDC.IMG
    3) Test Frame 3 - HD8-YCbCr24.yuv8.CDC.IMG
    4) Test Frame 4 - HD8-YCbCr32.yuv8.CDC.IMG
    5) Test Frame 5 - HD8-YCbCr40.yuv8.CDC.IMG
    6) Test Frame 6 - HD8-YCbCr48.yuv8.CDC.IMG
    DMA SDRAM->RESULT BUFFER [0x00000000] failed!
    FAILED SEQUENCE:
    0) Test Frame 7 - HD8-YCbCr56.yuv8.CDC.IMG
    [3B00013D] CM2_S2:Multi 1920_1440 Encoder Test FAILED!
    (Volt 2) = 1.202 Volts [+0.17%] - Norbert FPGA Core
    (Volt 3) = 1.797 Volts [-0.14%] - DDR2 RAM, Etc..
    Time of failure: 09/11/19_16:55:21
    FAILED SEQUENCE:
    0) Test Frame 0 - HD8-YCbCr00.yuv8.CDC.DECOMP
    1) Test Frame 1 - HD8-YCbCr08.yuv8.CDC.DECOMP
    2) Test Frame 2 - HD8-YCbCr13.yuv8.CDC.DECOMP
    3) Test Frame 3 - HD8-YCbCr24.yuv8.CDC.DECOMP
    4) Test Frame 4 - HD8-YCbCr32.yuv8.CDC.DECOMP
    5) Test Frame 5 - HD8-YCbCr40.yuv8.CDC.DECOMP
    6) Test Frame 6 - HD8-YCbCr48.yuv8.CDC.DECOMP
    FAILED SEQUENCE:
    0) Test Frame 7 - HD8-YCbCr56.yuv8.CDC.DECOMP
    [3B00013E] CM2_S2:Multi 1440_1920 Decoder Test FAILED!
    Norbert-Board Temperature(C) Local = 34.00, Remote = 49.12
    (Volt 3) = 1.798 Volts [-0.08%] - DDR2 RAM, Etc..
    Time of failure: 09/11/19_16:55:28
    Test Sequence Ended - 09/11/19_16:55:28
  • Wed, Sep 11 2019 9:08 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 392
    • Points 5,395
    SOLVED - I see the formatting for output is under the Format tab. It was totally dead but now among the living. Mystery hardware issue.. Thanks everyone! Please close ticket Marinna, I don't wanna be in your stack of emails. :)
  • Wed, Sep 11 2019 9:24 PM In reply to
    • Posts 10,676
    • Points 224,040
    Thanks for letting me know Dan!
  • Wed, Sep 11 2019 9:33 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 392
    • Points 5,395
    Not sure if you can answer this but...when I change Format in the Project Window in 2018.10 (which used to be in the Tools\Video Output) is that just for viewing or dose it change/upres the timeline/rendered output to this format. IE: I have an SD job but would like to view in HD on the god monitor, but output to 480/24p, which is this project, No worries if its a hassle to find out. This is a strange rare SD job.
