Latest post Thu, Sep 12 2019 11:06 PM by Sam Beckett. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Sep 10 2019 9:23 PM
    • acbrock
    • Posts 155
    • Points 1,880
    Project Size is Huge because of User Files
    Is there anyway to force the Avid to store the Seach Data Locally?  We have anywher from 8-12 systems hitting our Project.  Each one creates a search folder that is over 2Gigs.  So our Project that shoud be under 20 Gigs is over 40 and growing. Any way to get these save locally or at least not in our Project Folder on the ISIS?
  • Thu, Sep 12 2019 11:06 PM In reply to
    Re: Project Size is Huge because of User Files
    Yes, but what version of Avid are you using?
    Typically, when you create the project, there should be an option to set the Search Data Directory to Local Default.  If that option isn't in your version, then open the Find window and click the Gear icon in the lower left to display the Search Settings where you can also change it to Local Default.
    After you've done that, delete the SearchData folders from each user's folder to recover the space.
    • MC 2018.12.7 [NEXIS 19.8.0.2 | Avid Artist DNxID] • iMac Pro (2017) [OS 10.13.6 | 3.2 GHz Intel Xeon W | 32 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176... [view my complete system specs]
