Latest post Fri, Sep 13 2019 2:59 AM by Kenny. 2 replies.
  • Tue, Sep 10 2019 7:45 AM
    • Kenny
    • Pomona CA
    • Posts 77
    • Points 1,175
    Export settings for 4K
    Hello all,  I need a little help here.  I am just a hobbies but just edit my first 4K project in Media Composer 2019.7. Before I edit I transcoded my footage to DNXHR 59.97 UHD 3840x2160.  I want to export it so I can stream it on my Plex media server. Is there workflow were I can down-converter to 1920x1080p or just export it as 3840x2150.  I using mostly PC windows  computers.
    AMD Ryzen X1700 MB Asus Crosshair 6 Hero Asus GTX1070 8MB Memory 32GB Avid Media Composer 2019.7 [view my complete system specs]
  • Tue, Sep 10 2019 12:09 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,395
    • Points 17,240
    Re: Export settings for 4K
    You're asking two separate questions.
    Yes, you can export to any resolution you like.  The easient way to switch between UHD and HD is to simply change the project resolution under settings.
    Plex requires either h.264 files or h.265 files in .mp4 containers.  Avid does not do h.265 and is kind of clunky at h.264 -- so export as .mxf then re-encode through a 3rd part encoder such as Adobe Media Encoder of TMPGenc Video Master Works.
  • Fri, Sep 13 2019 2:59 AM In reply to
    • Kenny
    • Pomona CA
    • Posts 77
    • Points 1,175
    Thank you
