Latest post Sun, Sep 8 2019 9:32 PM by touviere7. 12 replies.
Page 1 of 1 (13 items)
  • Fri, Sep 6 2019 5:08 PM
    Viewing Media Files outside of MC
    I have a bunch of old external hard drives containing AvidMediaFiles.   Is there a way of viewing these without using MC?
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Fri, Sep 6 2019 5:21 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 625
    • Points 7,145
    Re: Viewing Media Files outside of MC
    vlc media player  or  telestream switch  both can read avid .mxf
    symphony 2019.7 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (431.70) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Fri, Sep 6 2019 5:40 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,395
    • Points 17,240
    Small and light, MPC-HC (Media Player Classic - Home Cinema) has been my go-to for years.
    Thank you.   I will try VLC first.
  • Fri, Sep 6 2019 6:21 PM In reply to
    • touviere7
    • los angeles
    • Posts 625
    • Points 7,145
    smrpix:
    sorry, but even the latest black edition, beta version, doesn't seem to read avid .mxf files...
  • Fri, Sep 6 2019 7:24 PM In reply to
    • smrpix
    • Posts 1,395
    • Points 17,240
    Not sure what to say, it's definitely working here.  64-bit version, not black.
    I find VLC bloated, but if it's working for you, that's what matters.
  • Fri, Sep 6 2019 8:48 PM In reply to
    • touviere7
    • los angeles
    • Posts 625
    • Points 7,145
    mea culpa!
    playing around once again with the regular version 64bit, i was able to open files from within the app.
    but i didn't find a way to conveniently click open the files directly from an avid folder... :-(
  • Sat, Sep 7 2019 10:05 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 609
    • Points 7,675
    MPV is a free, cross-platform open source player that will play all sorts of media files, including the MXF OP Atom files found in the Avid Mediafiles/MXF/1 folder. Make sure you read the Help file on the shortcut keys, as some of these aren't obvious from the player screen.
    https://mpv.io/
    It also can play HDR files on non-HDR displays, remapping the tonal levels to give a decent display on SDR monitors.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Sat, Sep 7 2019 3:21 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 508
    • Points 6,060
    VLC is fine,
    it will play anything it has a codec for.
    Which is a lot, but not everything you can encounter.
    touviere7:
    Righ click any mxf file -> open with -> Choose default
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sat, Sep 7 2019 4:17 PM In reply to
    • touviere7
    • los angeles
    • Posts 625
    • Points 7,145
    Lukas Boeck:
    i know that, but what i was saying is that i couldn't do it with mpc successfully!
  • Sat, Sep 7 2019 7:53 PM In reply to
    • Richard
    • Joined on Fri, Aug 17 2012
    • Los Angeles
    • Posts 40
    • Points 510
    ACG Player in my Windows 10 works for me.
    Home-grown IntelCore i7 3.07GHz, 24GB ram, Quadro K4000 (Nvidia driver 340.84), Win 10 Pro 64, MC current update, Quicktime version 7.76.80, Acer, dual... [view my complete system specs]
  • Sat, Sep 7 2019 10:14 PM In reply to
    • smrpix
    • Posts 1,395
    • Points 17,240
    touviere7:
    You can associate .mxf files with mpc-hc (or any player) through normal windows "open with."  (Some players --I'm looking at YOU VLC -- will just comandeer the function withoput asking your permission.)
  • Sun, Sep 8 2019 9:32 PM In reply to
    • touviere7
    • los angeles
    • Posts 625
    • Points 7,145
    smrpix:
    i must me missing something obviously, but i'm gonna try in a very simplistic way to describe my work flow in this little insignificant fonction:
    usual set up : default player: vlc
    within avid mediafiles folder, i can double click on any file, and it will play instantly.
    if i right click and chose open with "switch" for example, a double click on a file will also open it right away.
    now, if i right click and chose open with "mpc", a double click everytime will ask me if i want to basically install the app, and if i do, it will install the app and nothing else...Confused
    however, as i said before, taking many steps within "mpc" does allow me to open files, yes, but really not what i like to do...
    in other words, i have NOT find a way to open files with "mpc" within an avid mediafiles folder by simply double clicking on it.
    but, as my tag line says:   "the time you enjoy wasting is NOT wasted time..."  Wink
