Latest post Fri, Aug 23 2019 2:50 PM by LDV20. 4 replies.
  • Tue, Aug 20 2019 9:03 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 232
    • Points 2,755
    Main Bin Container does not open in project
    When I open a project the main bin container no longer automatically opens.  I played around with unlocking the bins and using floating bins -  so I am not sure if I clicked something.  Now when I open a project I have go to file and access the bin container through the file menu.  Is there a way to get this back to the bins open automaticlly?
    Thank you
    Larry
    Symphony 2019.7- Win 10 pro (1809), Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,(431.02) 64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media... [view my complete system specs]
  • Wed, Aug 21 2019 12:41 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 625
    • Points 7,145
    Re: Main Bin Container does not open in project
    try bringing your mouse to the upper right side of the window until you see <--> and drag it to the right...
    symphony 2019.7 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (431.70) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Wed, Aug 21 2019 2:40 PM In reply to
    • LDV20
    • Posts 232
    • Points 2,755
    touviere7:
    Hi  - Yes I can do what you suggest but does not slove the issue-   Let me explain when you opne MC you get the
    project window where you select the project to work on - then I select the project and click ok - the project then opens but without the bin container or any other bins that were left open upon closing the project.  I then have to go into File and select NEW BIN CONTAINER to get it on the screen.  The bin container always used to open automaticlly.
    I tried to save the workspace that did not work - went into seettings to see if there was an option - did not see it
    So is there something I am missing or this another bug that as surfaced?
    thank you
    L
  • Fri, Aug 23 2019 7:47 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 934
    • Points 11,945
    This is a known issue. I do not know, whether Avid engineering is working on it.
    I have created a "dummy bin", which I never close when switching off MC. With the dummy bin open, MC restarts and shows the bin container with the dummy bin open.
    Joachim
    Joachim Claus
  • Fri, Aug 23 2019 2:50 PM In reply to
    • LDV20
    • Posts 232
    • Points 2,755
    I payed around with settings etc - now the bin issue is back to normal.  I do not know what did to bring it back - but know that I hear it is a bug - that explains the issue.  I will try what you suggest should I need be.  Thank you for the tip.
