Latest post Mon, Aug 12 2019 9:21 AM by olenad. 4 replies.
  • Thu, Aug 8 2019 1:40 PM
    Cannot retrieve Form NSML using CTMS
    I am currently working with 2019.6 (build 7.4.0.59) and trying to retrieve a story form. If I use the following link:
    https://cloud11/apis/avid.inews;version=0;realm=INEWS7/system/forms/S-PYC-ONC
    Then I am able to retrive the details for the form including a reference to the expected ia:form-nsml link.
    However when I use that link:
    https://cloud11/apis/avid.inews;version=0;realm=INEWS7/system/forms/S-PYC-ONC/nsml
    then the client returns with "avid.inews/not found"
    The CTMS log shows the incoming requests:
    Aug 08 14:36:58 [debug]: Operation: getQueueAttributesById
    Aug 08 14:36:58 [debug]: Parameters:
    Aug 08 14:36:58 [debug]: id: ONC.TRAINING.DUBLIN-TESTS
    Aug 08 14:36:58 [debug]: Operation: getFormByName
    Aug 08 14:36:58 [debug]: name: S-PYC-ONC
    Aug 08 14:36:58 [debug]: Operation: getFormNsmlByName
    There is no indication of any issue in the iNEWS log.
    Filed under: , ,
  • Fri, Aug 9 2019 2:49 PM In reply to
    Re: Cannot retrieve Form NSML using CTMS
    I have now resolved this as it is a manifestation of a potentially more serious issue. The root cause were missing lists that were referenced by the form. This also prevents a queue from listing in the MC|UX rundown pane but does not affect the desktop client.
  • Mon, Aug 12 2019 8:16 AM In reply to
    • olenad
    • Joined on Thu, Nov 6 2014
    • Posts 36
    • Points 395
    Hi Michael,
    I have different result in my LAB if I got issue description correctly
    So I have created empty queue in SYSTEM.FORMS.I.INEWS
    and if I GET
    https://172.22.202.88/apis/avid.inews;version=0;realm=RH75/system/forms/INEWS
    or
    https://172.22.202.88/apis/avid.inews;version=0;realm=RH75/system/forms/INEWS/nsml
    then the response is the same because the queue is empty, this is by design
    { "code": "avid.inews/not_found", "params": {}, "message": "Resource not found", "incident": "9942bba0-a06c-4b5d-bc30-4dc95a6b85c3", "exchange": "6110ce81-bcd8-11e9-b4c4-d287b2cf97f6", "status": 404 } But at the same time, this queue is listed in the response from GET of https://172.22.202.88/apis/avid.inews;version=0;realm=RH75/system/forms So it is displayed in MC|UX client in the App Browse pane in iNEWS directory structure Do you have another behavior? Thanks, Olena
  • Mon, Aug 12 2019 9:11 AM In reply to
    Hi Olena,
    Thanks for your response.
    My issue was not quite the same:
    • The form IS present
    • The form has some COMBOBOX cells which are populated by Lists
    • The Lists were missing
    I realised this when I logged in with the iNEWS desktop client and got a series of console messages warning about the missing lists.
    After restoring the lists all problems went away.
    Hope this helps.
  • Mon, Aug 12 2019 9:21 AM In reply to
    • olenad
    • Posts 36
    • Points 395
    yes, this helps
    thank you for reporting this, we will fix  :)
    Olena
