Latest post Tue, Aug 13 2019 4:06 PM by DONvito. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jul 30 2019 4:36 PM
    • DONvito
    • Joined on Tue, Sep 26 2006
    • Posts 54
    • Points 810
    MC 2019.7 Waveform slow down system a lot!
    Hi there,
    since updating to MC 2019, I have noticed that when apllying waveform in time line, the system start woeking very slow, and sometimes even freezes MC.
    i even set the cache folder to a M.2 NVME drive for better performance, also the MC installed in a different M.2 drive.
    although, my system specs is very high, and it wasn't the issue with MC 2018.X.X
    PC Specs:
    CPU: Intel core i7-7820x 3.6GHz
    GPU: Quadro M4000
    Memory: 32Gb
    MB chipset: Asus Prime X299 Deluxe
    colling: Water cooling for CPU
    also, when rendering or transcoding, i don't see any activity in the GPU, it all done by the CPU, i'm not sure if those two problems related but i see it wierd that the GPU is not doing anything when editing, is that posible MC not using the GPU at all?
    AVID MC 2019.6 WINDOWS 10 PRO X64 Intel® cORE i7-7820X 3.6GHZ 32GB Samsung M.2 960 Pro NVME Intel 660p 2TB M.2 NVME Quadro M4000 Blackmagic Intensity... [view my complete system specs]
  • Tue, Jul 30 2019 5:19 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,971
    • Points 21,720
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: MC 2019.7 Waveform slow down system a lot!
    Hi Donvito,
      Do you have Nvidia v353.82 driver installed?
    RalphC
  • Tue, Jul 30 2019 7:23 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 392
    • Points 5,385
    I have a M4000 card installed. RaplphC - Isn't the v411.85 the right driver for the M4000? (or 411.XX, I'm not at the machine) Isn't v353.82 the right driver for the 4000 card?
    MC 2018.10 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Tue, Jul 30 2019 7:33 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 392
    • Points 5,385
    RalphC:
    Hi Donvito,
    RalphC
    This chart shows v411.95 for the M4000. Is it the v353.83 driver or v411.95? I've been running v411.95 with 2018.10 but I haven't been using it much since going to 2018.10. v411.95 worked great with 2018.5 w/M4000 card. I plan on upgrading soon to  2018.12.7 and then 2019.XX. Several times I've seen you post that v353.82 was right for M4000 and I want to be sure. Donvito probably wants to know too. The 353.82 chart shows M4000 too. That's confusing. Thanks!
    QUADRO DESKTOP/QUADRO NOTEBOOK DRIVER RELEASE 410
    Version:
    R410 U4 (411.95)  WHQL
    Release Date:
    2018.11.15
    Operating System:
    Windows 10 64-bit
    Language:
    English (US)
    File Size:
    391.83 MB
    RELEASE HIGHLIGHTS
    SUPPORTED PRODUCTS
    ADDITIONAL INFORMATION
    Quadro RTX Series:
    Quadro RTX 6000, Quadro RTX 5000, Quadro RTX 4000
    Quadro Series:
    Quadro GV100, Quadro GP100, Quadro P6000, Quadro P5200, Quadro P5000, Quadro P4000, Quadro P2000, Quadro P1000, Quadro P620, Quadro P600, Quadro P400, Quadro M6000 24GB, Quadro M6000, Quadro M5000, Quadro M4000, Quadro M2000, Quadro K6000, Quadro K5200, Quadro K5000, Quadro K4000, Quadro K4200, Quadro K2200, Quadro K2000, Quadro K2000D, Quadro K1200, Quadro K620, Quadro K600, Quadro K420, Quadro 410
  • Sun, Aug 11 2019 2:23 PM In reply to
    • DONvito
    • Posts 54
    • Points 810
    i have Driver vierson 431.02 installed, i saw in a forum post that this is the recommended driver for MC 2019.7.
    i'll install the driver you have suggested and update.
    Best.
  • Tue, Aug 13 2019 4:06 PM In reply to
    • DONvito
    • Posts 54
    • Points 810
    same issue with Driver 353.82
