Latest post Thu, Jul 25 2019 9:18 AM by Bruno M. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jul 25 2019 4:00 AM
    • TOPDOG
    • Joined on Tue, Mar 30 2010
    • Posts 73
    • Points 965
    Does Media Composer 8.4.4 Support AMA Link
    I installed Media Composer 8.4.4 I need to edit some AVCHD footage and some P2 footage.  I go to file link to media there is no AMA Link under the file menu.  When the window opens after I select file link I select the folder with the P2 window hit ok and a window pop up saying unable to link any clips.  There is a messge at the bottom of the link window that says, Avid editing services are not running.  Please start services from the Avid Editor Services Manager.  Any assistance appreciated on this issue.
  • Thu, Jul 25 2019 9:18 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 602
    • Points 7,600
    Re: Does Media Composer 8.4.4 Support AMA Link
    Any reason why you've installed a version of MC that's nearly four years old?
    I'd start with installing a more recent version, which will work with the latest versions of AMA plugins from Sony, Canon etc.
    I'm not sure when Avid introduced  the Media Browser, but this is usually the starting point for linking (or importing) material. The browser will also show you what AMA plugin Avid thinks it needs, and although it often gets it right, there are situations where you might need to manually select the right plugin.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
