Latest post Thu, Jul 18 2019 8:22 AM by Bruno M. 4 replies.
  • Wed, Jul 17 2019 1:47 AM
    • persyst
    • Joined on Tue, May 27 2014
    • Posts 159
    • Points 2,060
    Avid Artist Color with Baselight in MC 2019.6
    My Avid Artist Color (Firmware 1.1.11.0 with Eucontrol 19.5.1.44 REL)  is not working with my current install of Baselight for Avid. I have Baselight 5.2.11917 installed with Media Composer 2019.6 on High Sierra 10.13.6
    Please help. Thanks!!!
    Media Composer 2019.6 Pro Tools 2019.6 Mac Pro 2013, MacOS High Sierra 10.13.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3... [view my complete system specs]
  • Wed, Jul 17 2019 7:18 AM In reply to
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 33
    • Points 395
    Re: Avid Artist Color with Baselight in MC 2019.6
    Similar setup (on MacOS 10.14.5) and works fine here.
    Baselight manages directly the Color without using the Eucon software. Did you check that the Color is not attached in the EuControl App?
    Media Composer 2019.6, w/Symphony/SS/PF options, MAC PRO 2013 3.5 GHz 6-Core Intel Xeon E5, ATI FirePro D500 3072 Mo, 64 GB RAM, MacOS 10.14.5, AJA LHi [view my complete system specs]
  • Wed, Jul 17 2019 10:54 AM In reply to
    • persyst
    • Posts 159
    • Points 2,060
    H Damien, how do I disable the COLOR from EuControl without effecting my Artist TRANSPORT and Artist MIX that I’m using in MC also?
    Thanks!
  • Wed, Jul 17 2019 2:59 PM In reply to
    • damien78
    • Geneva
    • Posts 33
    • Points 395
    I'm only using the COLOR when working with BL, so I have no experience with Tansport + Color + Mix. I usually simply close the EuControl application or remove in the  EuControl settings the color panel from the My Surfaces list. If it does not work you should probably contact Filmlight support, they are really responsive and helpful.
  • Thu, Jul 18 2019 8:22 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 602
    • Points 7,600
    persyst:
    Thanks!
    There are two ways of dealing with the Artist Color with the Baselight Editions plugin. One is as Damien78 describes - that is to stop the Eucon software. This will enable Baselight to take direct control of it through ethernet.
    The other way is to open the Eucon software panel, and remove the Artist Color from the 'My Surfaces' column.
    Since you have multiple surfaces connected, you won't want to disable the Eucon software, so method two is the one you'll need to use.
    You also need to configure Baselight to use the Artist Color, and this requires you know it's IP address. The Artist Color is normally shipped with the IP set to DHCP, which means your router will assign a free IP address. Since this can change if you switch off your panel between editing sessions, I recommend you assign it with a fixed IP address.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
