Latest post Fri, Jul 19 2019 7:58 PM by Simon Tang. 4 replies.
  • Mon, Jul 8 2019 9:25 PM
    • Simon Tang
    • Joined on Thu, Oct 4 2018
    • Posts 7
    • Points 85
    AMT3: adding custom metadata to .aaf
    We got a request to add some metadata to the .AAF file.  In the output sample we received, analyzing the file using MXFDump shows that the metadata is stored in the .AAF file as a 'AAFTaggedValue'.
    Is this something that be added using the AMT3 SDK as we create the AAF file?
    If not, is there a suggestion for how this could be done?
  • Wed, Jul 10 2019 7:32 AM In reply to
    Re: AMT3: adding custom metadata to .aaf
    Hello Simon,
    In AMT3 documentation, in MediaAssetDescription.xsd, there is a section TaggedValueType which describes how to use the API to set TaggedValues in the target AAF.
    Hope this will help you.
  • Fri, Jul 12 2019 9:42 PM In reply to
    • Simon Tang
    • Posts 7
    • Points 85
    Thank you, I tried to implement this but couldn't get it to work.
    According to this, the feature is targeted to be available in AMT 3.12:
    http://cstest.avid.com/forums/p/196904/881838.aspx
    ...but currently I am using AMT-3.11.0.
    Is this info still correct?  Any release schedule info for 3.12?
  • Tue, Jul 16 2019 7:48 AM In reply to
    Here we are also working with AMT-3.11.0.
    I can confirm that by passing to AMT3
    <taggedvalue>
        <name>foo</name>
        <value>bar</value>
    </taggedvalue>
    We have in the AAFdump :
    Object of Class: TaggedValue
       Value: (indirect type: aafString) "bar"
    And it's visible in MediaComposer when showing corresponding column in the bin.
    Hope this helps you.
  • Fri, Jul 19 2019 7:58 PM In reply to
    • Simon Tang
    • Posts 7
    • Points 85
    Thank you!  I updated to a newer AMT version and it now works fine.
