Latest post Tue, Nov 19 2019 3:27 PM by jdrouette. 40 replies.
Page 3 of 3 (41 items) < Previous 1 2 3
  • Wed, Jun 26 2019 3:53 PM In reply to
    Re: MC 2019.6 black monitors issue
    In console, try the command
    moncon cpu
    or
    moncongpu
    MC 2019.9, Windows 10, ASROCK X99M, Intel 5930K, Zotac RTX 2070 Super, 32GB RAM, Transcend 512GB M.2 SSD & Dell UP2718Q. MBP 2012 Thunderbolt, OSX... [view my complete system specs]
  • Wed, Jun 26 2019 8:10 PM In reply to
    YES !!
    Mfavards solution did it for me:
    Find solution for me, I update to the last 10.14.5 Ios mojave and update Pro Video Format 2.1 (https://support.apple.com/kb/DL1988?locale=fr_FR) Normaly after update ios, it's automatically ask to update pro video format. After that i reinstate MC 2019.6 and everythink work perfectly! ;)
    Up and running again.
    Thanks!
    MacBook Pro late 2017 Mac OS X 10.13.1 Media Composer 2018.7.1 [view my complete system specs]
  • Tue, Jul 2 2019 9:10 AM In reply to
    • bas3000
    • Joined on Wed, Dec 24 2014
    • Posts 12
    • Points 130
    Had the same problem and can confirm,
    updating to 10.14.5 fixed this for me.
    yay!
  • Mon, Jul 8 2019 8:12 PM In reply to
    I had the same problem on an iMac Pro... black source/record monitors. Undocking the panel worked, but only for one clip at a time (meaning I'd have to dock/undock the panel every time I wanted to see a clip).
    Updated the OS to 10.14.5, and also updated the Pro Video Format to 2.1, and everything appears to be working again.
  • Mon, Jul 29 2019 8:12 AM In reply to
    • gref
    • Joined on Sun, Mar 22 2009
    • Posts 4
    • Points 70
    DStone:
    Try the following: Create a new workspace (Windows->Workspaces->New Workspace)…
    Hi DStone,
    that only worked half… creating a new workspace gave me picture in the record monitor but not in source. Un docking resulted in both monitors turning black. reselcting the workspace results in only record monitor having picture.
    Cheers
    Gref
    iMac (Retina 5K, 27-inch, 2017), 40 GB 2400 MHz DDR4, 2x Radeon Pro 580 8192 MB, Ultrastudio HD Mini [view my complete system specs]
    Optimism is just lack of information!
  • Tue, Nov 5 2019 2:42 PM In reply to
    • buba
    • Joined on Wed, Dec 17 2008
    • Germany
    • Posts 31
    • Points 370
    I also still have the problem. Im already on OSX 10.14.6 and updated the ProVideoFormats and reinstalled MediaComposer 2019.9 . Still have the problem that the source monitor turns black and i can just workaround by choosing e.g. the color correcting workspace and switch back to my editing workspace; then im able to see the footage in the source monitor again until i click on the next clip or matchframe the next clip. Hope someone can help with this issue!
    Regards, Farid
    Mac: MacBook Pro (15-inch, 2018);
    2,9 GHz Intel Core i9
    32 GB 2400 MHz DDR4
    Radeon Pro Vega 20 4 GB;
    Macbook Pro 2018 with Avid Standard Support Plan // www.faridmartin.de [view my complete system specs]
  • Tue, Nov 5 2019 3:29 PM In reply to
    • Posts 10,802
    • Points 225,600
    buba:
    Regards, Farid
    32 GB 2400 MHz DDR4
    Farid - I removed the system ID for security purposes.  Please dont post that here as someone could use your license.
    I have also created a case 03820498 and asked that support look at this for you... however, since between 2019.6 and 2019.9 - there are a lot of tweaks and fixes, I suggest you upgrade to 2019.9
  • Wed, Nov 6 2019 9:54 AM In reply to
    • buba
    • Germany
    • Posts 31
    • Points 370
    Hello Marianna,
    thank you. I wrote that I am already on 2019.9 and the problem persists. Seems like that the problem is not there when i edit on my LG UltraWide only as external monitor with laptop closed and keyboard + mouse + power connected. When I edit with my laptop as second monitor and an external monitor as main monitor the problem is coming up again.
    Regards,
    Farid
  • Wed, Nov 6 2019 1:49 PM In reply to
    • Posts 10,802
    • Points 225,600
    buba:
    Hello Marianna,
    Regards,
    Farid
    Farid
    Good info.... I have added this additional data to the case so support has the whole picture.
  • Thu, Nov 7 2019 11:35 PM In reply to
    • KHerring
    • Joined on Tue, Apr 17 2012
    • Posts 9
    • Points 105
    Hi all, running into this issue as well. 2015 Mac with 32GB ram. Laptop + 1 Samsung monitor. 2019 Avid on Mojave.
    I've noticed the source monitor goes black if I use the segment tool to move clips in the timeline. Only fix I worked out was restarting the application but I will try the docking. Need a better fix.
  • Tue, Nov 19 2019 3:27 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 409
    • Points 5,345
    I'm still having this issue with 2019.11 on iMac Pro.
    It's so disruptive to my workflow that I've rolled back to 2018.12.8.
    Marianna: Any word on when we can expect a fix?
    Avid Media Composer 2018.12.8 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.4), macOS 10.14.6, iMac Pro (2017) 10-Core, 3.0GHz... [view my complete system specs]
