Latest post Wed, Sep 11 2019 4:10 AM by John Lynn. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 20 2019 7:47 PM
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 33
    • Points 405
    [EDIT] Seems to be solved in the timeline by choosing default setup.
    I've just uninstalled 2018.12.5 and installed 2019.6 on my MAC PRO running 10.14.5, and created a new user.
    I've spotted severe font issues on my HD 1920x1200 UI monitor (Eizo CS2420).
    Timecode in particular in the timeline windows, also clip names/information (also in Composer). Other texts seem to be OK.
    Is it a known issue? Is there any solution to modifiy font/font size?
     Thanks in advance!
    Media Composer 2019.6, w/Symphony/SS/PF options, MAC PRO 2013 3.5 GHz 6-Core Intel Xeon E5, ATI FirePro D500 3072 Mo, 64 GB RAM, MacOS 10.14.5, AJA LHi [view my complete system specs]
  • Thu, Jun 20 2019 8:46 PM In reply to
    • t3chfaith
    • Joined on Tue, Oct 10 2017
    • Posts 38
    • Points 365
    Re: 2019.6 UI Font issue [PARTIALLY SOLVED]
    I couldn't even transcode on 2018.12.5/10.14.5. Are you running nexis or local drives?
  • Thu, Jun 20 2019 9:30 PM In reply to
    It may be pulling out a strange font. Mine started with OCR A, and I switched to Myriad Pro.
    Select the Composer (or Timeline) window and then choose Window > Set Font and pick a new one.
  • Thu, Jun 20 2019 9:56 PM In reply to
    • Posts 10,676
    • Points 224,040
    Spot on Kevin!
  • Fri, Jun 21 2019 10:56 AM In reply to
    • damien78
    • Geneva
    • Posts 33
    • Points 405
    Great, Thanks!
    Solved my problem, far more readable now. By the way I did not know that you could change font this way, I was looking in the user preferences only.
  • Wed, Sep 11 2019 4:10 AM In reply to
    • John Lynn
    • Joined on Sun, Jul 9 2006
    • Orlando, FL
    • Posts 11
    • Points 205
    Re: 2019.6 UI Font issue [SOLVED]
    Hi Everyone:
    I'm like most seasoned editors that never stop learning.  At some ponit, a feature was implemented to allow you to change fonts and font sizes for each Primary Media Composer Window (i.e, Composer Window, Timeline Window, Bin ContainerWindow). Thank you Avid!
    The reason I am adding to this post is because, I've encountered an inssue upgrading from older versions of Avid Media Composer where the operating system(s) on MAC and PC didn't carry over the font settings from the previous settings.  It made the Timline names unreadable.
    I'm not sure when this feature was added.  I'm running 2019.8
    Make sure you select a Primary Window before navigating to the Windows menu to set the font/size.  I've included a link with screen shots on Adjusting Media Composer Font Sizes.
    This is especially great for enlarging font sizes within the Composer Window and/or Timeline Window. These simple features  go a long way on improving efficiency.
    -John
