Latest post Thu, Jul 25 2019 12:40 PM by ShadenFreude. 39 replies.
Page 3 of 3 (40 items) < Previous 1 2 3
  • Mon, Jun 24 2019 7:32 AM In reply to
    Re: Media Composer 2019.6 AVAILABLE NOW - 20 June 2019
    Hi Keith,
    Monitors are installed on 1920X1080  2 x LG24MB35 24 ", the text size is 100%. With version 2018.12.3 everything was fine.
    Sergej
  • Tue, Jun 25 2019 3:43 PM In reply to
    I had a problem opening a specific project on an Isis 5000(but no other projects weirdly).  It would open the project in AMC 2019.6 but only the trash was listed in the bin container.  I updated the Nexis client to 2019.5 and that cured the issue.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440/800/820 PC's on W7 x64. 2 x Mac, 4 x PT 2019.5 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X 2. [view my complete system specs]
  • Tue, Jun 25 2019 10:11 PM In reply to
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    Just to resolve this particular issue. Rolling back to 10.14.0 fixed teh dx driver issue I was having with my mojo dx. Seems to be working again. Have not tried nor will i yet to update to 10.14.3 to see if that is compatible but definitely seems like 10.14.5 and dx drivers don't play well....
    Avid MC 2018.12.3, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.0, Radeon RX 580 8g, 9TB Internal Storage... [view my complete system specs]
  • Thu, Jun 27 2019 7:37 AM In reply to
    • cls105
    • los angeles
    • Posts 458
    • Points 5,950
    FluidMotion rendering still uses 15% cpu.  I'd say that's still on par with 2005 technology.
  • Thu, Jun 27 2019 1:45 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,716
    • Points 61,585
    cls105:
    Is that 100% of a single core?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.11 | QT 7.7.9 | Continuum 2020 | Sapphire 2020 | Mocha Pro 2020 | Titler Pro 7 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Jul 10 2019 1:12 AM In reply to
    • cls105
    • los angeles
    • Posts 458
    • Points 5,950
    Renaming the numbered folders inside the UME folder to a different number really messes things up.
    Even if I delete database files and recreate them I get a std::exception error on the clips.
    This is unlike the previous versions where I could rename the folders to another number in the mxf folder.
    If I rename them back to the original number ie __bg.1 then the clips link up again.
    This kind of feels like a beta version hoping for a dot upgrade soon.
  • Fri, Jul 19 2019 1:55 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 607
    • Points 7,220
    Having a few performance issues with 2019 around export.  Also find the interface has lag and functions don't always work as expected.
    HP Z420 16gb FX 1500 MC 8.4.0 Blackmagic deckink 4k extreme HP Z400 24gb FX3800 MC8.4.0 Aja express HP Z400 16gb FX3800 MC8.4.0 Blackmagic deckink 4k... [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Fri, Jul 19 2019 2:21 PM In reply to
    • Posts 10,826
    • Points 226,045
    Sasquatch:
    I hate everthing about this new interface, It takes me twice as long to do most things.  Performance is terrible.
    Mike
    If it is so bad, why dont you get on the horn with support and see what is going on.  The interface is one thing - performance another.  I can get a case going for you as I would rather you find out what might be wrong than just post like this which is not constructive.
    Let me know if you want me to get a tech on it for you.
  • Wed, Jul 24 2019 11:09 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,716
    • Points 61,585
    cls105:
    This sounds bad. Should probably be it’s own post to get some attention.
    Steve
  • Thu, Jul 25 2019 12:40 PM In reply to
    If it has not been pointed out already but entering a timecode into the edit window causes MC to hang.
