Latest post Sat, May 18 2019 12:29 PM by Joachim Claus. 4 replies.
  • Wed, May 15 2019 11:33 AM
    Media Composer 2018.12.5 AVAILABLE 14 May 2019
    Good news! Media Composer 2018.12.5 is now available. This is a patch release, and is only available through the Download Center. You will not see it in your My Avid account or on Avid Link.
    The Windows version of Media Composer v2018.12.5 is a patch release. You must have v2018.12.3 already installed. Then use the 2018.12.5 patch to update to this release.
    Fixed in Media Composer v2018.12.5
    The following has been fixed:
    ➤ Bug Number: MCCET-2999. You might have received an Exception error when deleting an asset from a bin.
    Fixed in Media Composer v2018.12.4
    The following have been fixed:
    ➤ Bug Number: MCDEV-10783. You might have received errors when trying to log into the MediaCentral Cloud UX server.
    ➤ Bug Number: MCCET-2822. In some instances, the .mxf extension was not appended using Send to Export, therefore “Auto Launch” could not open mxf files.
    ➤ Bug Number: MCCET-2927. Intermittently, saving bins resulted in Exception errors.
    ➤ Bug Number: MCCET-2902. In some instances, a video mixdown included the effects from an upper nested layer.
    ➤ Bug Number: MCCET-2897. After importing, certain WAV files may have had an incorrect start time.
    2
    ➤ Bug Number: MCCET-2748. If a sequence with media from a P2 card was loaded into the Source or Record monitor, relinking to add an extra clip would take too long.
    ➤ Bug Number: MCCET-2867. In some instances, rendering some effects on linked H264 media resulted in mixed up frames.
    ➤ Bug Number: MCCET-2862. (Windows 10) The Audio Tool was not updating when scrubbing with CAPS lock enabled.
    ➤ Bug Number: MCCET-2937. In some instances, if you captured with a single track that was not A1, the capture would abort immediately.
    ➤ Bug Number: MCDEV-10869. Clicking the yellow bin lock icon maximized bins that were minimized.
    ➤ Bug Number: MCCET-2967. (Avid Artist DNxIO and DNxIQ) Audio meter levels were not displayed in the Audio tool when recording.
    ➤ Bug Number: MCCET-2952. The Audio Punch-In Tool did not remember the last bin selected.
    ➤ Bug Number: MCCET-2914. In some instances, when exporting JPG, if you changed the name of the export, the file may have been unusable.
    ➤ Bug Number: MCCET-2942. You could not perform an insert edit export of DNxHR HQX media.
    ➤ Bug Number: MCCET-2946. (Interplay) In some instances, Media Composer would crash during check-in of sequence.
    ➤ Bug Number: MCCET-2910. Importing a non-shared user profile created a duplicate and prevented the application from closing.
    ➤ Bug Number: MCCET-2913. The Property Merge window would inadvertently appear when checking in a clip for first time into Interplay.
    ➤ Bug Number: MCCET-2901. Media Composer would hang when playing back an Avid Titler+ title in the effect editor.
    ➤ Bug Number: MCCET-2729. You might not have received the correct find results when searching group clips in PhraseFind.
    ➤ Bug Number: MCCET-2931. After upgrading from Media Composer v2018.12.1 to v2018.12.2 or v2018.12.3, batch re-import of Matte Key clips was not working.
    3
    ➤ Bug Number: MCCET-2878. The UHD video output is converted to HD when consolidating HD media in a UHD project.
    ➤ Bug Number: MCCET-2859. Switching camera angles in Multicam stopped playback if the group contained mixed frame rates.
    ➤ Bug Number: MCCET-2857. If you were working on a system using Chinese locale, you might have experienced consolidate and transcode audio issues.
    ➤ Bug Number: MCCET-2957. Insert Edit Export failed if only video tracks were selected.
    ➤ Bug Number: MCCET-2966. You might have been unable to import an EDL.
    ➤ Bug Number: MCCET-2915. The metadata might have been incorrect after importing an ALE.
    ➤ Bug Number: MCCET-2841. Saved presets did not always retain the last keyframe.
    ➤ Bug Number: MCCET-2805. The Raster Dimension column in a bin was incorrect for thin raster media.
    ➤ Bug Number: MCCET-2925. In some cases, after performing a render operation, the green dot remained in the Timeline on PNG clips including a Matte Key effect.
    ➤ Bug Number: MCCET-2930. You might have seen performance issues when editing a long AVC Long GOP 25 clip.
    ➤ Bug Number: MCCET-2973. Changes to Audio Reference Level settings changes were not properly reflected when you switched between Normal and Narrow Mixer View.
    ➤ Bug Number: MCCET-2960. (Mac v10.14.x) When linking to media on a shared network drive, the UNC path in the Drive column might have had the network user name in the path.
    ➤ Bug Number: MCCET-2732. When consolidating AVC Long GOP subclips created new master clips that were too long. A new check box has been added to the Consolidate/Transcode dialog
    boxes. Select the “Re-encode AVC Long GOP media to ensure shortest subclip durations” option when you consolidating AVC Long GOP subclips.
    ➤ Bug Number: MCCET-2923. (Mac) You might have received “not authorized” errors when trying to use PhraseFind or ScriptSync.
    ➤ Bug Number: MCCET-2947. You might have received errors when trying to set target the Dynamic Relink settings in an SD 25i PAL project.
    4
    ➤ Bug Number: MCCET-2936. If Dynamic Relink was enabled, imported DaVinci Resolve AAF media was offline.
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, May 16 2019 1:38 AM In reply to
    • Ramster92
    • Joined on Thu, Jan 11 2018
    • Posts 5
    • Points 55
    Re: Media Composer 2018.12.5 AVAILABLE 14 May 2019
    The cursor bug I reported for 2018.12.4 (after a few commands the cursor does not change to smart tool cursors) is still there...
  • Fri, May 17 2019 12:18 PM In reply to
    Ramster92, I noticed this in 12.4 but didn't have time to report it. I also opened a case for the same thing in 2018.12.5. It happens after you render a few times. The mouse cursor no longer changes from the computer default no matter what tool you are using. You must restart the application to get it to come back. I'm glad I'm not the only one.
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Fri, May 17 2019 4:52 PM In reply to
    • Revenger
    • Joined on Wed, May 11 2011
    • Estonia
    • Posts 76
    • Points 950
    +1 to cursor bug.
    MC 2018.12.5; HP Z800; Windows 10 Pro 64-bit; Dual Quad-Core Intel(R) Xeon(R) X5570 @ 2.93GHz; 24GB (6 x 4GB) DDR3 1333 ECC RAM; NVIDIA Quadro FX 4800... [view my complete system specs]
  • Sat, May 18 2019 12:29 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 918
    • Points 11,745
    The patch did not install. I got an error message
    "Database: Transformation: One line is not available and cannot be updated. Table: RemoveFile"
    I uninstalled MC2018.12.3 and re-installed it, however, the patch still creates the same error.
    Why do we not get a full installer?
    Joachim
    Joachim Claus
