Latest post Mon, Jun 10 2019 2:59 AM by Telegram!. 6 replies.
Page 1 of 1 (7 items)
  • Sat, May 11 2019 6:52 PM
    • Schmidtsk
    • Joined on Thu, Jan 18 2007
    • McGregor, South Africa
    • Posts 109
    • Points 1,345
    Timecode burn-in displays N.A. on video mixdown.
    I've done this dozens of times: tc burn-in effect on top video track. Video mixdown. Use mixdown for client viewing or audio reference.
    Out of the blue, when I do the mixdown the display shows "N.A." instead of the code, even though the code displays correctly in the timeline. Have rebooted, tried changing project format, fresh tc burn-in effect.
    It seems to work fine if I render the whole effect before doing the mixdown, but it's a huge timewaster.
    Has anyone had this happen? Suggestions would be welcome. Thanks.
    MC 2018.12.1 (Symph) on iMac 4.2. i7 40GB (OSX 10.14.2). Also MC 7.0.5 on MacPro 2.66 11 GB (OSX 10.7.5) [view my complete system specs]
    Plant a tree
  • Sat, May 11 2019 7:56 PM In reply to
    Re: Timecode burn-in displays N.A. on video mixdown.
    Are you sure the mixdown is on the same V-track number that the burnin effect is reading from?
  • Sat, May 11 2019 8:46 PM In reply to
    • Schmidtsk
    • Posts 109
    • Points 1,345
    Yes. If I render the effect it's correct. If I do a mixdown after the render it's correct: Master TC in this case.
    Plant a tree
  • Mon, May 13 2019 3:35 PM In reply to
    • Robert Bowlus
    • Joined on Thu, May 20 2010
    • Los Angeles
    • Posts 8
    • Points 110
    I just experienced the same thing. Typically, if it's working during playback the video mixdown will render it, but in this case everything looks fine in realtime playback but the video mixdown doesn't render correctly until the generator effect is rendered.
    This must be a bug. For window burns, this effectively doubles your export time.
    -Robert
    System 1: 2018 Imac Pro 2.5 Ghz Intel Xeon W 14-core Radeon Pro Vega 64 16GB VRAM 64GB System RAM System 2:Late 2014 5K IMAC 4 GHz Intel Core i7... [view my complete system specs]
  • Mon, May 13 2019 3:42 PM In reply to
    • Schmidtsk
    • Posts 109
    • Points 1,345
    Vinnie on the Avid FB page said it was a logged fault, so I rolled back from 1018.12.3 to 2018.12.1, and it's working fine now.
    It's really puzzling that something like this would get broken with an update.
    Plant a tree
  • Sun, Jun 9 2019 9:43 AM In reply to
    • Netti
    • Joined on Wed, May 16 2012
    • Switzerland
    • Posts 8
    • Points 100
    Yes, it's puzzling - and stealing time from us....
    MC 8.7, Symphony Option, Artist Color, HP Z640, Quadro m4000, Win7 Pro [view my complete system specs]
  • Mon, Jun 10 2019 2:59 AM In reply to
