Latest post Wed, Apr 24 2019 10:58 AM by Lembit Soobik. 4 replies.
  • Tue, Apr 23 2019 1:01 PM
    • Lembit Soobik
    • Joined on Sun, Sep 2 2007
    • Freising - Germany
    • Posts 281
    • Points 3,665
    Audio keyframes only all on or all off
    I have a sequence where I cannot select any existings audio keyframe alone. If I select one, all turn on. I can turn all together off with shift click.
    I have however a similar sequence where the audio keyframe selection works as it should. I have compared the timeline settings and find no difference. I have looked into the help file again and again and cannot find what is wrong.
    Any idea what to do?
    MC 2018.5 on Windows 10// HP Z800 WS: 2 x Xeon X5570, 48 GB RAM, Quadro M4000 32GB, disks: 1 x 500 GB SATA 7200 = System/ 1 x 1 TB Samsung 840... [view my complete system specs]
  • Tue, Apr 23 2019 3:11 PM In reply to
    Re: Audio keyframes only all on or all off
    As far as I experienced: In the fast menu (Hamburger menu) >Audio Data: Audio Volume must be acitvated. The Keyframe Selection Tool (in the Smart Tool) must be activated. However the Clip and Audio Track must NOT be activated.
    Hope that helps.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Tue, Apr 23 2019 4:03 PM In reply to
    Lembit Soobik:
    It sounds like you may have in/out marks set in your first sequence, and no in/out marks set in the second.
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Apr 24 2019 10:51 AM In reply to
    • Lembit Soobik
    • Posts 281
    • Points 3,665
    Thank you, Roland,
    I had that already . But I found something else. see my answer to Camoscato
    Lembit
  • Wed, Apr 24 2019 10:58 AM In reply to
    • Lembit Soobik
    • Posts 281
    • Points 3,665
    Thank you, Camoscato,
    it has something to do with IO marks, but not directly???
    the older sequence where it worked did have an IN-mark somewhere. So I went to the new sequence and added IO markes and now I can activate or inactivate single audio keyframes as I like.
    Deleted all IO marks of this sequence and it still works. Must have something to do with Klimate change or government -LOL or ???.
    Lembit
