Latest post Mon, Apr 22 2019 12:03 PM by pjanna. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Apr 19 2019 2:34 PM
    • pjanna
    • Joined on Wed, Mar 27 2019
    • Posts 17
    • Points 215
    grading
    Hi!
    Which information the person who makes grading for the film needs?
    I don´t have the source names of some clips because I changed names before
    making auto sync. Is this a total catstrophe?
  • Fri, Apr 19 2019 2:56 PM In reply to
    Re: grading
    The original source file names and source file paths plus the related timecode.
    That should all go in the AAF.
  • Fri, Apr 19 2019 5:04 PM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    The problem is that I have changed the names of the files before autosync and I don't find
    the original file names. Do you know if there is any way to find out the source information or
    is there any way for the grader to work without original source file names?
  • Sat, Apr 20 2019 10:41 AM In reply to
    Re: grading
    Did you rename the files at finder/os level (if so why) or just rename the clips?
    When you AMA link a clip into Avid the clip name shown in the bin may start off as the filename but the actual file name is stored in the source file name column. This is whats used by the grader. Not the clip name.
    Clip names are completely user editable.
  • Sat, Apr 20 2019 1:14 PM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    I only renamed the clips in Avid, not in finder.
    Now I found out that if I right click and choose "reveal files" then I see the original name of the clip.
    The strange thing is that "source file" column is simply empty but by using "reveal file" then I´ll get the same information.
    And the source file name is what the person making grading needs?
    Thank you for help!
  • Sat, Apr 20 2019 4:45 PM In reply to
    Re: grading
    How did you ingest the sources? AMA link?
    Did you add a tape name for the clips (does the tape column have any info in it?) if a clip has a tape associated with it Avid wipes the source file and source path info.
  • Sun, Apr 21 2019 8:31 AM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    I used "input" and "source browser" for to import the material. Before that I made MXF -files DaVinci.
    The column with the tape name is visible in Avid, source file or source path are not visible.
  • Sun, Apr 21 2019 1:34 PM In reply to
    Re: grading
    Sounds like you Imported the files and not AMA linked them.
    which is a shame. Import makes new Avid media
    You will have to try sending a test AFF to the grader to see if they can access any source info.
  • Sun, Apr 21 2019 2:07 PM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    Ok, but when I click two times the clip on timeline then I can see the source name.
    Isn´t this enough for the grader?
  • Sun, Apr 21 2019 2:20 PM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    I mean, I "match frame" two times on timeline and then the source file names becomes visible. It´s a bit more work but I have created new column calle "source" and I write the source file name there manually.
  • Sun, Apr 21 2019 6:26 PM In reply to
    Re: grading
    Do you know the graders system can relink the timeline based on your new columns?
    You need to test that.
  • Mon, Apr 22 2019 12:03 PM In reply to
    • pjanna
    • Posts 17
    • Points 215
    Re: grading
    ok, I will have to check it.
    But I just realized that I have never had any information in "source file" og "source path"  -columns and everything has been going just fine. The only difference this time is that the editor wanted to rename the clips at "name" -column. So I have written original names of the files manually to another column.
    Thank you so much for help!
