Latest post Thu, Apr 18 2019 2:07 PM by Martin in Chicago. 7 replies.
  • Wed, Apr 17 2019 10:26 PM
    Fastest, Cleanest Workflow Avid to Vimeo
    I'm trying to put nice, clean screeners from my Avid to Vimeo. Most of the suggestions I see start with Squeeze. With Squeeze no more, what is the best approach? Media Encoder, I think, no longer takes QT Refs and when I send my huge Same as Source export to Media Encoder, I get no picture and incorrect dimension information (this, after checking the file in QuickTime Player).
    Sadly, I've been away from Media Composer for a while and am now a bit lost on this front.
    Any ideas?
    Martin
    MC 2018.11.0, OS 10.13.6, Early 2009 Nehalem MacPro4,1, 2 X 2.6 GHz Quad-Core updated with Samsung 850 EVO 1 TB system drive, 32 GB RAM and ATI Radeon... [view my complete system specs]
  • Thu, Apr 18 2019 12:21 AM In reply to
    Re: Fastest, Cleanest Workflow Avid to Vimeo
    My worflow is same-as-source QT, then Handbrake to encode to Vimeo specs. Pretty fast, looks good.
  • Thu, Apr 18 2019 3:05 AM In reply to
    Martin in Chicago:
    Squeeze is no longer supported, but if you have it on your system it still works fine, especially for YouTube/Vimeo, and it accepts QT ref.   I find encoding to MP4 works best for YouTube/Vimeo.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Thu, Apr 18 2019 7:56 AM In reply to
    • TrevorA
    • Posts 1,148
    • Points 13,005
    I use watch folders, with an intermediate export, to generate H264s. Either Adobe Media Encoder (transcodes & uploads to vimeo) or MXFtoMP4 from Bouke at videotoolshed.com and upload manually.
    The latter is quicker as it starts the transcode as the Avid is exporting. Both can burn in logo and timecode.
    For the intermediate export I mostly use:
    XAVC-L 25 (if using AME) which is reasonalby quick and small, but fastest intermediate export so far acheived with
    DNX85 (used for MXFtoMP4). AME doesn't seem to read the 1440x1080 nature of DNX85 correctly.
    You could post here http://community.avid.com/forums/t/196684.aspx and see if there is any development...
  • Thu, Apr 18 2019 12:17 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,373
    • Points 16,955
    Adobe Media Encoder 2019 does not handle QTRef -- but AME 2017 still does.  If you have a 2019 CC licesnse you can dowlnoad and use 2017.  There are no conflicts having both versions.  AME is a lot quicker than Squeeze.
  • Thu, Apr 18 2019 1:27 PM In reply to
    smrpix:
    I'd really like to have that as an alternative, but I no longer have 2017 loaded and when I search for it, I only see cracked versions. Is there a legit way of getting it?
    Martin
  • Thu, Apr 18 2019 1:41 PM In reply to
    • GT
    • South Africa
    • Posts 389
    • Points 4,255
    Martin in Chicago:
    If you have the Creative Cloud subscription go to the Apps menu, then to Media Encoder. Next to the Open button there is a down arrow. Click on that and then on Manage and then Other Versions. That allows you to install previous versions.
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
  • Thu, Apr 18 2019 2:07 PM In reply to
    Ah, thank you GT. I had looked in the Apps menu, but not, foolishly at that arrow, just at the one on the other side that tells you what's new.
    I really appreciate it.
    Martin
